Like Tree13Likes
Old 11-05-2011, 10:01 PM   #766
Some inventive guys in Russia are using Clinometer for iPhone or Android or Windows Phone 7 to measure caster on A700 now.
http://www.plaincode.com/products/
Oleg Babich is offline   Reply With Quote
Old 11-06-2011, 03:12 AM   #767
Trader Rating: 22 (100%+)
Great app! Thanks
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 11-06-2011, 10:53 PM   #768
Tbone13's Avatar
hy,
just tried that app and it works perfect tested on the A700 it says me 4,4 left and 4,6 right
thanks for that Oleg
kind regards Tom
supported by and thanks to:
Modelconcept / Absima Racing / TeamC / Hacker Brushless motors / Awesomatix
Tbone13 is offline   Reply With Quote
Old 11-07-2011, 02:40 AM   #769
Gear diff modification to extend the life of plastic gears:
Add more SH0.1 shims according to the picture after grinding of two ST20 parts.
Old 11-07-2011, 10:00 AM   #770
guys, how tight did your gear diffs feel when building them.
Ive built mine and was pretty maticulous with the grinding of the ST20 and shimming but it feels quite tight now, when assembled with Reinhard B oil.
Feels like a reasonable tight ball diff.
I am only asking as my Tamyia gear diff felt nice and free when built just trying to work out if i need to take this one apart again and make sure something is seated correctly
Cheers
Subliminal is offline   Reply With Quote
Old 11-07-2011, 10:58 AM   #771
also when changing the shock action as everyone seems to be running asymmetric how far do you need to screw the SS3X4 into the shock. Do you screw it all the way in or leave it flush with the top ??
Anyone please let me know ASAP
Old 11-07-2011, 11:23 AM   #772
Cheers
I didnt have the B oil. But did find that after my build, the gear diff seated and was as smooth as my Tamiya V2 diffs
Unsure as well with the correct use, I screw the grub screw until it stopped using as little force as possible - just in case.
TEAMORCA.SHOP
Old 11-07-2011, 12:04 PM   #773
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Maybe Oleg can give a bit of insider info on the shock internals as Im too scared to even take out the screws as oil might leak. would be good to know if they can also be rebuild as well. as overtime the oil will need topping I guess.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-07-2011, 12:04 PM   #774
ok thanks maybe ill take the gear diff apart again just to check as it feels a lot stiffer than my Tamiya V2's
I wondered if you leave the screws further out and thats what makes the difference to the shock as there is extra space where the end of the screw would be if that makes sense.
Oleg can you confirm exactly what we are supposed to do with the grub screw to change the shocks.
Old 11-07-2011, 12:16 PM   #775
ok another question regarding the build when assembling the steering rack on page 13 does the second M3x12 grub screw remain sticking out of the bottom of the rack ??? with the spacers advised its impossible to screw it all the way in
Whats everyone else done ?
Old 11-07-2011, 12:25 PM   #776
dont worry answered that one myself DOH !!!!!
Old 11-07-2011, 01:37 PM   #777
ok another question regarding the build when assembling the steering rack on page 13 does the second M3x12 grub screw remain sticking out of the bottom of the rack ??? with the spacers advised its impossible to screw it all the way in...
The second M3x12 screw must ~2mm sticking out also.
Dampers: Screw the grub screw until it stopped using moderate force. These screws prevent against dust and dirt penetration.
Some oil drops is possible on the dampers body during operation at first period.
It is normal. Some excessive oil penetrates into dampers during assembling due to technological reasons but this excessive oil is not involved in the damping.
Diff: Please play with amount of 0.1mm shims under 5x8 bearings but everytime use more shims from steel gear side than from other.
Some running-in is useful also sometimes.
Old 11-07-2011, 01:40 PM   #778
Magnet Top's Avatar
What is the size of the wheel bearings ?
edit :
answer :
MR106RS
6x10x3
Magnet Top is online now   Reply With Quote
Old 11-07-2011, 04:21 PM   #779
hana166's Avatar
I suggest you go to the site and download the instructions you will find a lot of info there
hana166 is offline   Reply With Quote
Old 11-07-2011, 05:12 PM   #780
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Or just say You don't know....
OVA is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
