Like Tree25Likes
Old 01-02-2015, 12:11 PM   #7696
Originally Posted by hanulec View Post
Jacob- lol.
Kiwano- I'll tell you how tight the cups remain after a race day. The bag trick can work with open ended cups. If you saw how loose my TOP balls/cups are on my 17.5 car you might laugh. The balls just wear out over time...
Hanulec- I just changed all the ball cups on my EVO to new standard ball cups, but I still think there is some sloop. Could it come from the balls ? Does those wear down also ?
What is your experince with this ?
Shock Tower is offline   Reply With Quote
Old 01-02-2015, 12:37 PM   #7697
hanulec's Avatar
Trader Rating: 27 (100%+)
shock tower (funny name for an amtx driver..) - i'll let you know tonight. haven't built up some all "fresh" new tie rods in a LONG time.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-02-2015, 08:08 PM   #7698
geeunit1014's Avatar
The new ball cups fit very well on the st24 ball studs. On the older at21s im not sure.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 01-02-2015, 10:09 PM   #7699
hanulec's Avatar
+1
Fresh P13-4 fit well on ST24, ST24L, and new (different material) AT21
Old 01-03-2015, 05:32 AM   #7700
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Recently picked up a used A700 Evo and as such, going thru a complete tear down and rebuild.
On one of the dampers, it seems a socket cap screw was used in replacement of the button head screw normally on the top part of the damper. Could I just replace the socket cap screw with the correct screw? If so, what size/length? I understand these are sealed units, but not sure to what extent...
Anyways, the car's machine work is amazing. Easily the highest quality car I've wrenched on in all my years in the hobby.
Dan is offline   Reply With Quote
Old 01-03-2015, 05:57 AM   #7701
Trader Rating: 33 (100%+)
You want the screw (sb25x10) and little washer (p26)
http://shop.awesomatixusa.com/catalo...ult/?q=sb25x10
Monti
Monti is offline   Reply With Quote
Old 01-03-2015, 06:36 AM   #7702
Dan
Dan's Avatar
Thanks Monti! Hopefully no ill effects with this damper, not sure why the original screw was replaced in the first place.
Old 01-03-2015, 06:39 AM   #7703
Download the manual and go to page 37 it will make it all clear (maybe).
http://www.awesomatixusa.com/p/downloads.html
Monti
Old 01-03-2015, 06:41 AM   #7704
Trader Rating: 55 (100%+)
They can back out when new in my experience. Previous owner probably lost it. If it was me I would replace that shock. But that's just my opinion
Jamison R is offline   Reply With Quote
Old 01-03-2015, 06:48 AM   #7705
Dan
Dan's Avatar
Whoops, missed that part of the manual. Still tearing down the car. The damper adjustment settings are all off too, so I'll need to reset it all and recheck dampening. Might be a good excuse to try the new dampers. This is why I rarely buy used cars...
Old 01-03-2015, 08:52 AM   #7706
elee32's Avatar
Trader Rating: 18 (100%+)
There should be a separate thread on the massive headache you get from buying a used awesomatix! LOL
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 01-03-2015, 09:46 AM   #7707
erchn's Avatar
Sounds like you guys need a certified pre-owned program. :-)
erchn is offline   Reply With Quote
Old 01-03-2015, 05:15 PM   #7708
cmunro's Avatar
Does anybody have trouble with the gd2 leaking I have used ae green slime on all the rings and set screws that go in the out drives and it still slings oil out of the out drives , it is only a couple weeks old
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 01-03-2015, 07:23 PM   #7709
I have 2 gd2s. Neither leak. Ae 1000 and ae 2000 wt.
Old 01-03-2015, 07:30 PM   #7710
Xpress's Avatar
My gd2 leaks out of only one side? I'm not sure if it's thru the seal or the setscrew? I pulled the diff apart and put a wrench thru the output shaft so I could crank the setscrew. I'll know shortly if that fixed the leakage....
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
