Like Tree13Likes
Old 12-23-2014, 02:23 AM   #7621
I can't wait to see Oleg design a damper with two separate oil chambers with separate vanes and one way bearings for fully independent compression and rebound settings. :P
-Mike
Old 12-23-2014, 03:47 AM   #7622
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by G-rem View Post
But how does it influence the damper's behaviour in comparison to AT41 with holes in the blades?
Drilling different size or different quantity of holes will allow you to adjust pack, just like in blank shock pistions.
Originally Posted by grippgoat View Post
Maybe it's just so you can drill your own holes?
-Mike
you are correct sir. AT41-0 damper vane is without holes --- for the ultimate in adjustability, but also confusion . i wouldn't recommend this for the newbie racer.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-23-2014, 07:42 AM   #7623
cmunro's Avatar
so does the new chassis require the new motor mount? and the new motor mount require the new chassis ? just wondering if it is possible to upgrade one at a time
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 12-23-2014, 08:12 AM   #7624
G-rem's Avatar
It is impossible to mount the new MM2 on C01AL-S, it requires the use of the new alu chassis C01AL-S2. I supposed it is the same if you want to mount the old motor mount on C01AL-S2...
BTW, I sell an A700 Evo + parts and options, more details by PM
G-rem is offline   Reply With Quote
Old 12-23-2014, 09:50 AM   #7625
Magnet Top's Avatar
NOT accurate !
From Oleg :
Awesomatix EP Touring Car (A700 Shaft Drive)
New motor mount has four flex modes
At Mode 3 and Mode 4 the using of AM69 battery holder is not important and new motor mount can be installed without AM69 on C01, C01L, C01EX, C01AL and C01AL-H chassis also.
You can also use new motor mount even at Mode 1 and Mode 2 without AM69 on these chassis with losing of few percents of flex symmetry.
Furthermore you can install AM69 even on C01, C01L and C01EX chassis and get all flex modes after very simple filing of the chassis edge under AM69 leg.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 12-23-2014, 10:15 AM   #7626
Jake is already ahead of me to answer.
I have to add the next:
Mode 1 is the softest and Mode 4 is the stiffest.
Our Team drivers use only Mode 2 and Mode 3 now and it seems a sufficient choice at the most conditions.
C01AL-S2 chassis and new C01L2 carbon chassis - all four modes are possible.
C01AL -S chassis - Mode 1,2,3 are possible.
C01, C01L, C01EX, C01AL and C01AL-H chassis - Mode 1,2,3 are possible but without AM69 Battery Support installation.
Yes, after very simple filing of the chassis edge under AM69 leg you can install AM69 even on C01, C01L and C01EX chassis and get pure Mode 1 and Mode 2 also.
Oleg Babich is offline   Reply With Quote
Old 12-23-2014, 01:10 PM   #7627
hana166's Avatar
-Mike
I was about to post an identical suggestion earlier today. I guess the owb's would have to be absolutely tiny.
About the holes in the new shocks, it should be easier to find the optimum pack because the rotary damper is inherently superior due to the volume being constant along with consistent low friction ballraced vanes.
A flexible plastic cover over one hole would create a one way valve which could give different compression and rebound.
So many possibilities but I guess we just have to find out what works on track and grow from there
hana166 is offline   Reply With Quote
Old 12-23-2014, 01:49 PM   #7628
G-rem's Avatar
Maybe a stupide question but how much D2-S do I need for the 4 corners of my car? 2 or 4 (come as a pair or as a single piece)?
Juste saw it now, what is D2 damper? In comparison to D2-S?
Last thing: can I still use the AM30-5 short central stiffner with the new C01AL-S2? Or only the long AM33-5 fits?
Thanks,
G-rem
Old 12-23-2014, 04:01 PM   #7629
hanulec's Avatar
A700-d2-s is one piece. You need four per car
The old braces should fit..
Old 12-23-2014, 04:04 PM   #7630
Actually, what I mentioned wouldn't work that well. I forgot that the housing has an oil chamber for each vane, with limits to how far the vanes can turn. If the vanes only turn one way, they'd hit the limit of their travel, and then badness ensues.
Rather than throw more half-assed ideas out there, I'll just continue to eat my popcorn and drive my orange car and see what Oleg comes up with next.
-Mike
Old 12-23-2014, 10:36 PM   #7631
G-rem's Avatar
Thanks for the support Mike!
For Oleg: what is D2 damper? In comparison to D2-S?
Thanks,
G-rem
Old 12-24-2014, 04:00 AM   #7632
G-rem's Avatar
Maybe an idea for a last christmas gift?
AWESOMATIX A700 Evo + options + parts
Merry christmas to all the russian car lovers (and the others too)
Old 12-24-2014, 05:27 AM   #7633
Thanks,
G-rem
D2 is RTR oil filled damper ( 500 cst oil inside is now).
D2-S is the kit for assembling (oil is not included).
Old 12-24-2014, 06:05 AM   #7634
G-rem's Avatar
Nice, thanks!
Old 12-24-2014, 06:52 AM   #7635
Silly question ! But now you change oil in dampers , do they still move in and out as well also what was the aprox wight of oil in old dampers?
mixertom is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
