Like Tree21Likes
Old 12-14-2014, 11:26 AM   #7561
Originally Posted by hanulec View Post
Hi Jose, for this transition - yes.
There could be/will be some year in the future that this could change.... And then this car would be like the rest of them
JC - the motor mount appears to only work w/ the new A700-C01AL-S and A700-C01AL-S2 chassis.
New motor mount has four flex modes.
At Mode 3 and Mode 4 the using of AM69 battery holder is not important and new motor mount can be installed without AM69 on C01, C01L, C01EX, C01AL and C01AL-H chassis also.
You can also use new motor mount even at Mode 1 and Mode 2 without AM69 on these chassis with losing of few percents of flex symmetry.
Furthermore you can install AM69 even on C01, C01L and C01EX chassis and get all flex modes after very simple filing of the chassis edge under AM69 leg.
Oleg Babich is offline   Reply With Quote
Old 12-14-2014, 03:52 PM   #7562
Hi, i have a problem with AM49-3. When i use it with am33-5 stiffener, my AT31 FFG Alloy Rod is completely stuck.
If i use AM49 long ffg tower, alloy rod moves freely, but i can't install am33-5 stiffener.
This happen on my C01AL-S chassis.
It's safe to run without stiffener? Or there is a way to unstuck alloy rod with am49-3?
guru83 is offline   Reply With Quote
Old 12-14-2014, 06:12 PM   #7563
hanulec's Avatar
Trader Rating: 27 (100%+)
i don't know what 'stuck' means. the the AM49-3 + AM33 higher? lower? you're going to have to use a caliper to try and understand what is going wrong. you'll need to measure the height differences.
you can run without the AM49 if you have a top deck c21 installed.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-14-2014, 06:17 PM   #7564
Magnet Top's Avatar
One possibility...
By chance are you mounting the awesomatix servo in the center ? If so, make sure your screws holding the awesomatix servo are short ( I believe 5mm ) so they won't run into am33-5.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 12-14-2014, 11:50 PM   #7565
Hello everybody,
I tried the new car last weekend, and i have to say that it's a big improvement !!
The new dampers are amazing with hard spring. I tried many setup and i prefer it with a softer seeting (like 5.4 in front and 5.0 in rear).
The new chassi with the new motor mount are very easy to use, very simple to change the Mode. I tried also every mode and i prefer the mode 3.
For me the car is now easier to drive and more consistent during 5 minutes.
I noticed that the car has also more mid-corner steering.
I can share my setup if you want (high grip track and CPX tires)
Team Awesomatix - WTF - Thunder Power - Mikovic Body Painting - ToniSport - PRT Electronics
Manu_05' is offline   Reply With Quote
Old 12-15-2014, 12:04 AM   #7566
Thank you, i mean the alloy rod doesn't move freely, its almost blocked. AM46-1 drag on AM54-1. I will try to measure the height of the AM49 and AM49-3 + AM33 but i think that short tower is a little lower.
Old 12-15-2014, 12:07 AM   #7567
Originally Posted by Magnet Top View Post
One possibility...
Thanks but i'm using am24 servo holder, so i have to use it on offset position with am33-5.
Old 12-15-2014, 06:30 AM   #7568
RC Professor's Avatar
I had the exact same issue. I ended up just placing a thin shim under AM49-3 where it connects to the AM33-5 stiffener, making AM49-3 sit just a little higher when connected to the stiffener. The alloy FFG rod was basically pressed up against the top flange of AM49-3, which bound up the FFG movement. The shim alleviated this, allowing the FFG to move as it should.
RC Professor is offline   Reply With Quote
Old 12-15-2014, 06:56 AM   #7569
http://www.redrc.net/2014/12/freddy-...p-with-hb-hpi/
And one more to leave the team...
toroloco is offline   Reply With Quote
Old 12-15-2014, 07:36 AM   #7570
Xpress's Avatar
One possibility...
I had to mill the center brace to run the Awesomatix servo. The ear on the servo was thicker than the notch milled in the bottom of the stiffener. Also had to mill .75mm from the side of the stiffenenr as the offset of the servo didn't clear the side of the stiffener.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 12-15-2014, 09:28 AM   #7571
Just measured AM49:
Original AM49 is 30,85mm and AM49-3 + AM33-5 is 30,5mm.
I added 0,3 mm shim under AM49-3, and i found that, using most rearward mounting hole on AM33-5, FFG moves more freely. Now is very smooth
Old 12-15-2014, 02:48 PM   #7572
JayL's Avatar
I run an evo with FFG 1.1 Raceberry chassis With C21 topdeck
Interested in Running: AT04-2
Can I dump, AM50,AM48,DT04?
Thank you
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-15-2014, 04:24 PM   #7573
Jochim_18's Avatar
Reading this thread confused the heck out of me... lol sorry to high jack your thread...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-15-2014, 04:58 PM   #7574
hanulec's Avatar
Thank you
At04-2 is designed to remove the am48 bearings on an FFG. You could replace the am48 with am50.
Top deck removes the effect of the collars (am48/50) on the FFG. I wouldn't run without the tower brace (am49) though....
If you have any suggestions on how to make it simpler pls speak up. We are trying to recommend names to Oleg right now for the new parts.
Old 12-15-2014, 05:00 PM   #7575
erchn's Avatar
10-4
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
