Like Tree25Likes
Old 11-23-2014, 11:13 AM   #7441
kgombe's Avatar
anyone have an idea of where i can get a front spool... the ring gear came off of mine..
Kijana Crichton
kgombe is offline   Reply With Quote
Old 11-23-2014, 11:28 AM   #7442
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Just CA glue back on...dont use the thin ca..isnt enough time to set the ring in place..
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 11-23-2014, 11:58 AM   #7443
Hi,
still have an 2 race old Evo for sale.
If interested pm me.
Claude
toroloco is offline   Reply With Quote
Old 11-23-2014, 12:01 PM   #7444
Gridworks Racing's Avatar
If you decide you want another spool, I have a brand new one as shown:
Gridworks Racing is offline   Reply With Quote
Old 11-23-2014, 01:42 PM   #7445
hanulec's Avatar
Trader Rating: 27 (100%+)
here are some detailed instructions of how to fix a spool -- along with some compounds better than CA
http://www.awesomatixusa.com/p/spool...ar-repair.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-23-2014, 03:12 PM   #7446
-jacob-'s Avatar
I just fixed mines. Went to Napa Auto parts. Green loctite costed about $7.50. its very thin green liquid.. per instructions it cures in 24 hours. Works like a dream.. spool looks brand new and i cannot even see the glue.
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 11-23-2014, 03:56 PM   #7447
kgombe's Avatar
I don't think those fixes will work for me.. It's pretty apparently as when it's pushed all the way back i can spin it freely.. So room has to made up between gear and housing.. Also it's not very easy to come off, it's very tight when trying to take it off but loose when it all the back to the lip to stop it.... How does the front way work in stock... I have one that I got in a package deal ... Just never used it...
Kijana Crichton
Old 11-23-2014, 04:04 PM   #7448
S.Stew's Avatar
I'd be willing to bet the Loctite 648 would still do the trick. It's an incredibly powerful industrial bonding agent. I'd suggest to pull the ring gear back, clean up the mating surface with a soft wire brush, apply the 648, push the ring gear into place, then spray or drip the primer onto the gear. The primer, from my experience makes the 648 dry very quick. Putting it on afterwords is sort of like an accelerator for CA.
Hope that helps!
S.Stew is offline   Reply With Quote
Old 11-23-2014, 05:07 PM   #7449
-jacob-'s Avatar
Mines were worst. its should work...
Old 11-23-2014, 05:16 PM   #7450
geeunit1014's Avatar
CA can temporarily get you thru the day but it doesnt really stick to metal that well. The loctite retaining compound is more permanent. It is also designed to fill gaps. Like stew said, clean the surfaces, apply and let it sit. If you dont have primer it will take a couple days to fully cure
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 11-23-2014, 05:32 PM   #7451
kgombe's Avatar
Ok guys I will try it and get a new one just incase
Kijana Crichton
Old 11-23-2014, 08:07 PM   #7452
ThrottleKing's Avatar
Trader Rating: 16 (100%+)
My racing buddy has the same issue with his that came off and spins freely but upon further inspection the ring gear has actually split between the teeth. Would the mentioned epoxies work well enough to keep that together as it seems no one has them instock. Kind of ticks me off too since I just bought one myself and for the price of the cars you would think every part would be instock. Or is this a weak link type part and everyone has broken them and that is why they are out of stock. Other than short parts supply the car has been very good for me just a bit of a learning curve after having belt cars for such a long time.
Acts 2:21- And it shall come to pass, that whosoever shall call on the name of the Lord shall be saved.
ThrottleKing is offline   Reply With Quote
Old 11-23-2014, 09:11 PM   #7453
I would probably just replace it at that point. Even if it could stay together the split would likely break the input gear.
Every once in a while that happens, but it isn't often. I have a spare just to be safe. I havent heard of this happeneing on the newer style spools yet (at03ms).
Its just bad luck awesomatixusa doesnt have them in stock, i believe he sent some in a parts care package for awesomatix drivers for the us indoor champs race happening this weekend. Im sure he has already reordered. He is generally very good about keeping parts in stock
Speaking of which, for any awesomatix drivers going to the us indoor champs this weekend, since hanulec is not going i will have a care package of parts available if anyone needs anything
Mike Gee
Old 11-23-2014, 11:14 PM   #7454
Send a message via Yahoo to linkinghobby
I've a problem with spool axle AT03 in my new A700 Evo
The St07 outdrive spins freely with AT03 spool axle after about two months of life.
Thank you.
linkinghobby is offline   Reply With Quote
Old 11-24-2014, 04:14 AM   #7455
Trader Rating: 55 (100%+)
Thank you.
They are just pressed in. The new spool the outdrives screw on. I bought the new style spool and the outdrive broke after I was forced into a board. I guess it's better because I just ordered outdrives. The bad part it was on my first run with new spool. I was upset for a bit. Put in gear diff and made it through the day. The spool on the A700 imo is the weak link of this car. But I will take it over all the other cars many weak links. Jmho
Jamison R is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
