Like Tree25Likes
Old 11-03-2014, 07:13 AM   #7366
masterhit's Avatar
Trader Rating: 15 (100%+)
Awesome job to Steven for putting it in the stock TC show with that trainwreck of a box of parts that I gave him! Just imagine if he actually drove it before that Friday?
She started life as an original kit over 2 years ago and has some good mojo for sure.
That shirt seems to suit him well!
Mike Slaughter
masterhit is offline   Reply With Quote
Old 11-03-2014, 07:11 PM   #7367
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Thinking of trying my car with out the FFG(back to normal front mount). Will still be using the aluminum chassis, so do I still need to run the AM-33-5? Will be using the top deck.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 11-03-2014, 08:16 PM   #7368
hanulec's Avatar
Trader Rating: 27 (100%+)
You wanna do run the am30/33 brace. Top deck appears more optional.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-04-2014, 08:49 AM   #7369
Cadman1981's Avatar
Originally Posted by G-rem View Post
- AT04-2: 5mm drive shaft (do not need the ball bearing support anymore)
- SD2: new spur damper. It adds the torsional flex between the spur axle and the rear diff and so gives the "belt drive" properties into A700 shaft transmission.
Hi there
Can anyone tell me if i still need SD1 damper set with these 2 parts? or i can just install SD2 and AT04-2?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 11-04-2014, 09:33 AM   #7370
hanulec's Avatar
Originally Posted by Cadman1981 View Post
Hi there
At04-2 works with stock pieces, sd1 or sd2
Sd2 replaced sd1
The at12m apart of sd1, is a great hop up for either stock parts (at20) or sd2. I have it on all of my cars to prevent failure....
Old 11-04-2014, 09:38 AM   #7371
Anyone know what the part number is for the special grub screw used in the GD2? This is the one with the end that seals inside the outdrive shaft. I've managed to lose two of them refilling diffs.
Edit: Never mind, found it. In case anyone is looking it is SS3X4-1 M3x4 DIN915 Screw x 2
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 11-04-2014, 08:26 PM   #7372
S.Stew's Avatar
Mike Slaughter
Thanks Mike!
It's really just evidence of how well this car works in stock. I pieced it together, guessed at a setup, made a few tweaks over the weekend and by Sunday I had a race car. Hands down the best TC I've driven on rubber tires. Now I'm just looking forward to indoor champs 😁.
S.Stew is offline   Reply With Quote
Old 11-06-2014, 07:17 AM   #7373
Cadman1981's Avatar
Sd2 replaced sd1
Thank you Hanulec! I'm guessing the at12m is a straight upgrade for the at20 - just for the size of the pins for the spur?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 11-06-2014, 07:28 AM   #7374
Cadman1981's Avatar
When will SD2 and AT04-2 be available on awesomatic usa soon?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 11-06-2014, 10:04 AM   #7375
hanulec's Avatar
At12m just replaces at12.
At04-2 ... On the way
Sd2 ... Back ordered
Old 11-06-2014, 10:19 AM   #7376
Xpress's Avatar
with a topdeck on an evo is there a need for am50?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-06-2014, 10:20 AM   #7377
DesertRat's Avatar
The Awesomatix Thread, where Alphabet Soup makes sense.
You guys are starting to go just as insane as oval racers.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 11-06-2014, 10:28 AM   #7378
In the description the SD2 is said to "give the feel of a belt". Does this mean when coming on power out of the corner you get a little more initial pull on the front spool and the car is a little less inclined to step out with the rear wheels if your on the power a little fast?
WF D06 USVTA
Old 11-06-2014, 01:13 PM   #7379
hanulec's Avatar
The gaps to either collar from the center FFG support is not at play with the top deck
Should feel more like a belt car.
Truth be told... I'm a bit skeptical on this myself.
Old 11-09-2014, 10:48 AM   #7380
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
So ive tried a few different setups for my mod evo and nothing seems to hook up at all, everything just has little to no rear traction and stability. Any suggestions and a setup thats just easy to drive and can be tweaked for aggressiveness from there?
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
