Like Tree4Likes
Old 09-25-2014, 05:01 PM   #7186
hanulec's Avatar
Trader Rating: 24 (100%+)
Originally Posted by trackout View Post
Anyone have a source for the Xenon 64P VSS spur gears in the 84T or 86T size? It is an odd size for the Spec-GT class at IIC Vegas to hit the 4.70 FDR limit.
[WRONG --- 113 isn't available]
i think lee speed 84p gears will give you the best ratio.
113/50 * 2.08 = 4.7008
[/WRONG]
for 64p gears-
86/38 * 2.08 = 4.7073
lee speed @ http://teameamotorsports.com/
xenon @ http://xenon.ocnk.net/
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-25-2014, 05:57 PM   #7187
Talking
For 48p gears : 61t spur/ 27t pinion = 4.7000fdr + durability..
bertrandsv87 is offline   Reply With Quote
Old 09-25-2014, 06:01 PM   #7188
Trader Rating: 25 (100%+)
Thanks hanulec for the info.
Gtr r34 m-spec is offline   Reply With Quote
Old 09-25-2014, 09:36 PM   #7189
Originally Posted by Oleg Babich View Post
Dustin, thank you very much!
What material did you used for prototypes?
It is only simply aluminum ... Isn't t6!!! It is a bit softer ...
But for the tests,if my idea works it doesnt matter ...
You can contact me: dustin.falk@icloud.com
Dustin Falk
DustinFalk is offline   Reply With Quote
Old 09-30-2014, 10:08 AM   #7190
Cadman1981's Avatar
Hey guys,
In the summer, i will race on medium grip asphalt, but during the winter, it's on carpet high grip CRC carpet with Sweep 28s.
I have an A700L - non evo, and i have the long top arms and the top deck with not much flex.
The top guys with this chassis are using the short arms, but with more flex from the top plate being setup with ST09s.
I was looking at the setup sheets on PetitRC and i noticed for Carpet, most of the setups have the long arms.
How does the long arms with a stiff top deck (no cut outs) vs the short arms with a soft top deck (all cut outs...cut) compare? Let say the rest of the cars settings are the same but the arms and top deck. How does the cars handling get affected? I know that Flex is good for low grip, but this seems counter intuitive to me...
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 09-30-2014, 08:24 PM   #7191
hanulec's Avatar
Originally Posted by Cadman1981 View Post
Hey guys,
i think you're trying to mix two different types of settings. ignore the top deck for now.
i think the major difference amount the setups are--
1) short upper links + soft suspension
2) longer upper links + stiffer suspension
the longer link causes the car to roll 'deeper'/further. shorter links limit the roll.
softer suspension causes roll. stiffer suspension limits roll.
now top decks--
i never ran the c02 top deck with st09 collars (other than the center ones). when i tried it back to back, the stiff/solid top deck was usually better on carpet.
on asphalt or super low grip, the T-cut top deck is best.
Old 09-30-2014, 10:22 PM   #7192
hanulec's Avatar
alloy arms are now available -- http://www.awesomatixusa.com/2014/10...ved-along.html
Old 09-30-2014, 10:59 PM   #7193
Hi Hanulec,
Did you tried the C04al ?
Its not too stiff ?
Team Awesomatix - WTF - Thunder Power - Mikovic Body Painting - ToniSport - PRT Electronics
Manu_05' is offline   Reply With Quote
Old 10-01-2014, 03:56 AM   #7194
hanulec's Avatar
Originally Posted by Manu_05' View Post
Hi Hanulec,
Its not too stiff ?
I haven't tested yet. Plan on running them at Worlds and IIC. Will set Saturday on carpet.
Old 10-01-2014, 07:49 AM   #7195
Hey guys quick question my carpet season is about to start, I'm running the evo with the raceberry soft chassis. I have the am-33 on the car right now but don't know how it will handle. Will I need a top deck also, or should I just ditch the am -33 and just go with a top deck?
Bgilli26 is offline   Reply With Quote
Old 10-01-2014, 08:29 AM   #7196
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Raceberry soft chassis?? I have one on my Evo..but it is hard chassis..
with the top make the car react quicker..
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-01-2014, 11:14 AM   #7197
geeunit1014's Avatar
I would try the am33 with all the screws in it at first, and then add a topdeck if it needs to be stiffer.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-01-2014, 11:57 AM   #7198
Hey
In germany we drive the raceberry soft chassis v2.1 with topdeck and optional am30-5 or am33-5... With am33 or 30 you have more precision for wide cor ers but in little corner you lose a lot of roll speed ...
And we drive am06- m with xray balls
Dustin
Old 10-01-2014, 08:15 PM   #7199
Thanks guys I'll try am-33 first, then try top deck, one last question do you all suggest 90c 6000 mah, or 90c 7600 mah pack for more equal weight balance ?
Old 10-01-2014, 11:06 PM   #7200
For stock 6000
For modified its your choice
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
