Like Tree22Likes
Old 09-23-2014, 09:44 PM   #7171
G-rem's Avatar
Originally Posted by Oleg Babich View Post
AM10-2 is a stiffer version of AM10-1.
The stiffness was increased by removing the cutout and by the increased thickness.
Thanks Oleg!
How does this stiffness have an influence on the car's behaviour? Did you realize the original part had some weak points?
G-rem is offline   Reply With Quote
Old 09-23-2014, 10:16 PM   #7172
Originally Posted by G-rem View Post
Thanks Oleg!
It influences only on a chance of AM09 steering rod popping out at the race accidents. We want to reduce it.
Oleg Babich is offline   Reply With Quote
Old 09-23-2014, 11:45 PM   #7173
Send a message via Yahoo to linkinghobby
I have problem with spur gear. Easy to break?
64p so break, 48p break too.
Everyone help me? Thanks
linkinghobby is offline   Reply With Quote
Old 09-24-2014, 03:14 AM   #7174
The space between spur gear and pinion gear must be nearly zero :-)
DustinFalk is offline   Reply With Quote
Old 09-24-2014, 04:11 AM   #7175
Trader Rating: 25 (100%+)
Hi all - can someone tell me if the A700evo us spec comes with soft springs, floating servo mount and the updated new diff.
What other parts are required?
Gtr r34 m-spec is offline   Reply With Quote
Old 09-24-2014, 04:11 AM   #7176
Old 09-24-2014, 04:42 AM   #7177
Mikkel_R's Avatar
Hello,
I am looking to switch from Xray to Awesomatix.
Ive been on the Awesomatix site looking for information about the differences between their kits but couldn't find what i'm looking for.
Could somebody explain the differences?
I normally run 13.5 boosted or blinky and both tarmac and carpet.
Cheers Mike
Mikkel_R is offline   Reply With Quote
Old 09-24-2014, 05:03 AM   #7178
hanulec's Avatar
Trader Rating: 27 (100%+)
there is now NO difference between the A700 Evo and A700 Evo USA Spec (previous difference was the inclusion of am06s hubs within USA Spec)
soft springs (spr01s)- yes
floating servo mount (am24)- no
gd2- yes
the parts lists can be see here-
http://www.awesomatixusa.com/p/downloads.html
https://drive.google.com/file/d/0B0Z...it?usp=sharing
The differences from these parts list is the inclusion of FFG1.1 and a complete GD2 diff/gears/shims/etc.
Originally Posted by Mikkel_R View Post
Hello,
Cheers Mike
http://www.awesomatixusa.com/p/kits.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-24-2014, 01:31 PM   #7179
arn671's Avatar
Trader Rating: 14 (100%+)
Default A700 Evo
I just picked up a new Evo kit and was wondering if the carbon shaft for the FFG was/is replaced by the aluminum version in the USA kit.
Is there a difference in handling between the 2 materials? Awesomatix has a "soft" and regular carbon shaft listed vs. carbon only on the Awesomatix USA site.
arn671 is offline   Reply With Quote
Old 09-24-2014, 01:35 PM   #7180
hanulec's Avatar
At31 is the new default in all kits.
Old 09-24-2014, 04:23 PM   #7181
O.Franke's Avatar
Hey guys,
its been a while since i joined the awesomatix team, but i would like to be more active in this forum from now
First of all: My name is Oliver Franke i am 21 years old and i come from germany (~90km westside from hannover). I joined the Awesomatix team last december and i am really happy with that
As you might have heard last weekend was held the ETS Pilot race (a test race, to maybe host an ETS reace next season, with high quality drivers)
We´ve been racing the same reglement as we do at the ETS Races (Ride tires, MuchMore 13.5T Motor, 5,0 Gear ratio) Only diffrence is that we could use any speedo with 0-Boost Blinky mode.
Here´s a short report:
Beside the ADAC GT 1000 we had our ETS Pilotrace at the very famous Nürburgring Boulevard. It was only a two day event so we arrived at the track Saturday morning. The first practice was to get used to the track. But already in P2 we had good traction and could start working on our set up. But our car worked really really well right from the beginning. So we only had to do small changes. After re-seating from the fastest 3 consecutive laps I was leading and we had Max in P4. So we were very confident to get the best possible result for the qualification which was also on Saturday.
In Q1 I was leading but unfortunately hit a curb onto the straight which meant traction roll. In Q2 the car worked really well and I TQ´d that one by over 2.5 sec lead. Also in Q3 our car worked perfect again which meant I could take the second TQ run and snatch up the first position in the ranking list.
Unluckily my spur gear broke in Q4. I made some tiny changes which seemed to be very good. But anyway after qualification I was TQ and the Team had a really good set up to get the best possible results for the finals.
Unfortunatly Max had some really really bad luck with traffic and losts a lot of time which costs him the A-Main
In A1 I pulled away and won by a comfortable lead.
It was much closer in A2. But without making any mistake it was nearly impossible to overtake on that track. So I won A1+A2 and also the race already at that point
Before A3 we had a closer look to our car and thought about what we could improve. And we found something to get the car more rolling and also still easier to drive. So i simply put 0.5mm under the hubs all around the car.
So I wanted to try it. And it was amazing fast. Great improvement!
All in all for me it was a really good weekend. Big thanks to the team for the great support! And we are perfectly prepared for the ETS in early December this year Looking forward to it!
I will attach the set up as soon as petitrc has uploaded it.
best regards
Oliver Franke
Awesomatix
LRP
Gforce
WTF
O.Franke is offline   Reply With Quote
Old 09-24-2014, 10:17 PM   #7182
hanulec's Avatar
http://www.awesomatixusa.com/2014/09...mup-races.html
Old 09-25-2014, 12:09 PM   #7183
Hi oleg
Today i produce the first prototyp of the redesigned am09...
Next week i hope i can produce two more 1 for oli and 1 for max ... When the prototyps work very well... Oli or max can send you the prototyp and the CAD drawing
Nices wishes from
Germany
Dustin falk
Old 09-25-2014, 12:31 PM   #7184
Anyone have a source for the Xenon 64P VSS spur gears in the 84T or 86T size? It is an odd size for the Spec-GT class at IIC Vegas to hit the 4.70 FDR limit.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 09-25-2014, 02:23 PM   #7185
Originally Posted by DustinFalk View Post
Hi oleg
Nices wishes from
Germany
Dustin falk
Dustin, thank you very much!
What material did you used for prototypes?
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
