Like Tree21Likes
Old 09-21-2014, 07:16 PM   #7156
KHoff7's Avatar
I have had the "same" car since 2012 and I still love my Awesomatix more than any touring car I have ever had. To go back to running something "regular" is just inconceivable for me. Before this weekend I hadn't raced since June, I put a setup on my car and it was nearly perfect and I was able to do very well.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-22-2014, 05:56 AM   #7157
Originally Posted by Monti View Post
You need to add washers underneath the body posts, about .200 to .300 worth.
Monti
Did that, a little concerned about how much material I had to ream out of the top bumper frame since the wider part of the body post is now half-way up the hole. Don't want to weaken the bumper significantly given my skills as a destructive testing specialist.
Awesomatix EP Touring Car (A700 Shaft Drive)-img_0283.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-img_0284.jpg
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 09-22-2014, 08:16 AM   #7158
Default USVTA Ballast
On a different note, tried setting up one of my chassis for USVTA racing, needed to add over 200g of weight which is really difficult on the CO1AL-S chassis since there isn't much space to stick ballast. Any chance of a tungsten and a steel version of the AM33-5? One which added 100g of additional weight for USVTA and a second that added 200g of additional weight for USVTA?
WF D06 USVTA
Old 09-22-2014, 08:50 AM   #7159
hanulec's Avatar
Trader Rating: 27 (100%+)
C01al-s in vta... Wow
I'd recommend a ton of weight under receiver/ESC and behind the battery.
I layed at least one layer of weight under all my electronics when running a700l at snowbirds.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-22-2014, 09:16 AM   #7160
The bronze version of AM33-5 gives plus 58g.
Hard temper stainless steel for C01AL-S chassis gives plus 120g...170g depending on the cutouts area.
How many sets should we produce?
Oleg Babich is offline   Reply With Quote
Old 09-22-2014, 09:25 AM   #7161
Hmmm, my thinking was the advantage of different versions of the AM33-5 for different classes with different weight limits (USGT, USVTA, CVTA) allowing quick change-outs. Although you'd have to change the chassis plate out the SS version would get you a much lower CG that putting the weight higher in the AM33-5. I'd certainly be willing to try a SS version of the chassis and the bronze brace so put me down for 2 each.
WF D06 USVTA
Old 09-22-2014, 09:50 AM   #7162
One more variant is the bronze plates with protrusions that correspond to the C01AL-S cutouts. Left and right plates are placed under battery and electronics and probably screwed to the AM33-5 with some gap to the chassis to provide the desirable chassis flex under such plates. It will give us also the "floating" mounting for battery and electronics.
Old 09-22-2014, 06:35 PM   #7163
Trader Rating: 32 (100%+)
I think you are a little to high. I didn't add any spacers in the rear.
http://racepf.com/blog/2013/07/panzi...mmer-shootout/
This is a pic of my body and you can see there isn't much front lip left.
Hope this helps.
Monti
Monti is offline   Reply With Quote
Old 09-23-2014, 02:16 AM   #7164
Hi Oleg,
I think we need updated Setup sheets with all the new options of am33-5,
am30-5, front drive shafts, wheel hubs and chassis plates an top decks, gears choice for diffs?
Claude
toroloco is offline   Reply With Quote
Old 09-23-2014, 03:55 AM   #7165
Hope this helps.
Monti
Yeah for USGT I could lower it some more, for our club races that would be considered a slammed body since to looks trimmed above the lines. I'll give it a test this weekend and see if I can get it lower without rubbing the carpet.
WF D06 USVTA
Old 09-23-2014, 11:57 AM   #7166
Trader Rating: 35 (100%+)
Anyone know where you can get the 5.3mm ball cups? Awesomatix is out of them and I'm trying to get my car ready for vegas!
XRAY T4 15' MOD:X-RAY T4 15 17.5:T.O.P Rebel WGT:VBC LIGHTNING F1
5280 RACEWAY "Racing Elevated"
MILE HIGH INDOOR CHAMPS April 17-19th 2015 @ www.milehighindoorchamps.com
Losi22 is offline   Reply With Quote
Old 09-23-2014, 12:32 PM   #7167
geeunit1014's Avatar
They are top ball ends, mayne try looking around for those
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 09-23-2014, 01:05 PM   #7168
G-rem's Avatar
Hi guys,
can you please tell me what's the difference between the newly released AM10-2 (updated steering plate) and the current AM10-1?
Thanks in advance,
G-rem
G-rem is offline   Reply With Quote
Old 09-23-2014, 01:48 PM   #7169
Originally Posted by G-rem View Post
Hi guys,
Thanks in advance,
G-rem
AM10-2 is a stiffer version of AM10-1.
The stiffness was increased by removing the cutout and by the increased thickness.
Old 09-23-2014, 03:52 PM   #7170
bhambrent's Avatar
Want to congratulate Brad Johnson on his TC 17.5 win at the U.S VTA southern Nat's..And also Thank him for his help as well.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
