Old 09-02-2014, 03:46 PM   #7021
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Originally Posted by OVA View Post
A700 EVO question
I have two bottom chassis ,one is the RaceBerry another the L chassis
witch of the chassis would be better for 17.5 stock carpet races?
So far I only see Josh carpet set up online. thanks
Just so you know. There are about a zillion carpet setups here.
http://www.awesomatixusa.com/p/setup-sheets.html
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 09-02-2014, 06:10 PM   #7022
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JayBee View Post
Updated with pics...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-02-2014, 10:05 PM   #7023
jdawg81's Avatar
I am thinking of getting either the A700L or the Evo but I can't decide which one I should get. I know the Evo has the new floating front gearbox but it's also a bit more expensive. I will only be racing in TC 17.5 blinky so would the A700L be good enough or is it worth spending the extra money on the Evo?
jdawg81 is offline   Reply With Quote
Old 09-02-2014, 11:30 PM   #7024
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Hi Larry
Yes I know about this Awesomatixusa set up sheet are available
I am looking for Raceberry chassis set up on carpet
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-03-2014, 04:21 AM   #7025
hanulec's Avatar
Either car would be great in stock. You can always upgrade an L to Evo too...
Hi Larry
Josh really liked the Raceberry in mod on carpet. He took his car from the pre-worlds warm-up and ran it indoors with nearly zero setup changes ... and pulled off the win.
No one else I'm aware us has run the Raceberry indoors --- nor would I recommend it is stock on carpet.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-07-2014, 12:38 AM   #7026
G-rem's Avatar
G-rem is offline   Reply With Quote
Old 09-07-2014, 12:38 AM   #7027
G-rem's Avatar
Old 09-07-2014, 12:39 AM   #7028
G-rem's Avatar
New parts questions:
1) what is the #1 set (A700-#1)
2) what is the difference between C21 and C21-2?
3) can we have pictures of the "short FFG tower" (A700-AM49-3) that is supposed to be used with AM33-5 (long stiffener)? When using AM30-5, is it useful?
Thanks for answering
G-rem
Old 09-07-2014, 02:16 AM   #7029
C21-2, AM49-3 and AM33-5 info:
AM33-5 long stiffener provides the maximal longitudinal stiffness of chassis.
Long stiffener doesn't reduce the torsional flex in case of using only one or two center screws.
So the the flex will be the same as with short stiffener that is screwed by the same one-two center screws.
But AM33-5 increases the longitudinal stiffness noticeable ( it prevents the chassis against longitudinal bending). This is the main advantage of AM33-5 especially for such soft chassis as C01AL-S.
Maximum longitudinal stiffness combined with an adjustable torsional flex provided by the alu stiffener is a key of our latest chassis flex control method.
AM49-3 is screwed directly to AM33-5 long stiffener.
C21-2 is a bit stiffer version of C21 with 3,8mm center hole instead of 6mm hole. So you have to use ST09 collar inside of the center hole of top deck instead of 6mm shims.
C21-2 and AM33-5 have the additional holes for 4 positions of AM49-3.
Oleg Babich is offline   Reply With Quote
Old 09-07-2014, 05:17 AM   #7030
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Reading this thread reminds me of what C3PO's phone would look like if he texted R2D2. haha. Carry on!
Old 09-07-2014, 05:22 AM   #7031
Dos Andos's Avatar
Trader Rating: 30 (100%+)
Hi all
Thinking of trying this kit out. Can't seem to find any instructions which is making it difficult to understand anything you guys are talking about lol...
Are there any available?
"Andy T"
www.adelaiderc.com.au - Team Driver
sales@adelaiderc.com.au
www.modelflight.com.au
*ARCR* member
Dos Andos is offline   Reply With Quote
Old 09-07-2014, 05:33 AM   #7032
I)arkness's Avatar
Originally Posted by Dos Andos View Post
Hi all
all the info you need is here petitrc.awesomatix
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 09-07-2014, 06:41 AM   #7033
hanulec's Avatar
you can also look here-
http://racerlog.com/wiki/Awesomatix_A700
Old 09-07-2014, 10:32 AM   #7034
It would be nice to have to have a conversion kit to modify al the "old" EVO's with the new parts such as the the updated FFG-1 parts, Ballcups P13-4, and maybe the soft chassis, top deck an stiffners AM30-5 and AM 33-5 and this for reasenable price..... of course )
toroloco is offline   Reply With Quote
Old 09-07-2014, 11:33 AM   #7035
G-rem's Avatar
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17199 Today 02:45 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
