Like Tree13Likes
Old 08-29-2014, 01:04 PM   #7006
Originally Posted by geeunit1014 View Post
If you want to do a "shock angle change", I would make only a small adjustment to the A gap, smaller for leaned in, bigger for stood up. The change you are describing would be like a shock oil change.
Ok Thanks,
but will my change be lighter oil or heavier with a bigger gap on the A setting?
toroloco is offline   Reply With Quote
Old 08-29-2014, 01:17 PM   #7007
geeunit1014's Avatar
Originally Posted by toroloco View Post
Ok Thanks,
Bigger A gap is heavier
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-30-2014, 08:08 AM   #7008
Default IIC Tuning parts?
What tuning parts should I be ordering for IIC? I have a pair of A700 Evos with the soft aluminum chassis, the brace, GD2 diffs w/XRay internals. Anything else I should be bringing? My home track is much lower traction so I won't really have a setup developed in advance.
The first car is running 17.5/17.5 Amateur and the second is Spec GT.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 08-30-2014, 08:48 AM   #7009
Magnet Top's Avatar
Top decks, you should have them with you at IIC. Grip gets very high at these big events. Usually stiffer chassis are used for a more predictable car, higher corner speed and less chance for grip rolls when grip is high.
Jake
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 08-30-2014, 11:09 AM   #7010
Trader Rating: 21 (100%+)
Swapping l/r and running asymmetrical makes it so the bump is stiff, and the rebound is soft. On the track this gives more forward drive, I think because it keeps the outside corner from dumping over and it allows the inside tire to stay on the ground better. If you run symmetric then there is no difference if you swap l/r. This change really allows you to let the car have good mid corner rotation and also be planted on power
Dialed!
MDawson is offline   Reply With Quote
Old 08-30-2014, 11:55 AM   #7011
John Doucakis's Avatar
Apologies for the question but how exactly do you swap the rear dampers left to right?
Do you remove DR6 from AM17R and place on AM17L and vice versa for DL6?
John
John Doucakis is offline   Reply With Quote
Old 08-30-2014, 05:23 PM   #7012
hanulec's Avatar
Trader Rating: 27 (100%+)
John
Leave the am17s alone.
Put the dl6 into the am17r
And the dr6 into the am17l
Run assymetrical mode (that is the only way this would be different)
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-31-2014, 06:44 AM   #7013
hanulec's Avatar
As Jake said - top deck is a good choice.
Other items would be-- p20, at21s, am19 (rear), shims, b106rs bearing replacements.
Old 08-31-2014, 09:34 AM   #7014
syndr0me's Avatar
Trader Rating: 32 (100%+)
My new kit came with some updated ball connectors. They're all the same length and have a hole molded in them. Very nice parts, they look a lot like Xray's.
Does this mean there's ball studs coming with hex heads in them?
Has anybody tried these yet? They seem to pop on/off pretty easily. Any trouble with them popping off on the track?
syndr0me is offline   Reply With Quote
Old 08-31-2014, 09:57 AM   #7015
hanulec's Avatar
Syndrome your talking about the st24 and p13-4.
I've run them outdoors... And will try them soon indoors.
Old 08-31-2014, 11:27 AM   #7016
syndr0me's Avatar
Ah, yeah, P13-4 is right. The kit didn't come with ST24 though. The P13-4's feel a little bit loose on the AT21's it came with.
Is ST24 and ST24-L enough to replace all the AT21's in the kit? I'll get some ordered up!
Old 08-31-2014, 01:00 PM   #7017
hanulec's Avatar
I'd need Oleg to opine.
I had thought st24 were coming now/soon.
Old 09-01-2014, 09:58 PM   #7018
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
A700 EVO question
I have two bottom chassis ,one is the RaceBerry another the L chassis
witch of the chassis would be better for 17.5 stock carpet races?
So far I only see Josh carpet set up online. thanks
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-01-2014, 11:46 PM   #7019
Originally Posted by OVA View Post
A700 EVO question
So far I only see Josh carpet set up inline. thanks
The stock L chassis would be my choice of the 2.
HawaiiBob is offline   Reply With Quote
Old 09-02-2014, 09:54 AM   #7020
JayL's Avatar
Yes.
I swapped my car to all p13-4 and st24 and st24L for all the inner mounts for the camber/caster turnbuckles. they are nice, tight and free. I do have ffg 1.1 as well. I did use a couple of the st24L but I can't remember which mount I used them in,pretty sure it was in the front front, will look at my car tonight
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
