Like Tree13Likes
Old 08-25-2014, 01:26 PM   #6976
hanulec's Avatar
Trader Rating: 27 (100%+)
That L/R swap has only been successfully tested in mod in the rear. Swapping the front creates a push. I haven't found it necessary in spec classes yet -- but a bumpy track could change my opinion on that...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-25-2014, 02:06 PM   #6977
G-rem's Avatar
Originally Posted by geeunit1014 View Post
We found this past weekend using 4 screws (2 around the ffg brace, and one at either end ond hole from the end) and no topdeck had very good results on medium grip asphalt. Hopefully Hanulec can post the rest of the setup on the site as well, because the car was the best car I have ever driven on aspahlt ( mod class)
Also for anyone else running asphalt looking for more corner exit/on power grip should try swapping the rear dampers left/right and run asymmetrical damping, this has been a big improvement, and should help over bumps as well
Thanks a lot for the feedback Mike, I'll surely give it a try as soon as I can hit the track again
Also a good thing to know about the damper, fine tuning tip
G-rem is offline   Reply With Quote
Old 08-25-2014, 02:23 PM   #6978
Magnet Top's Avatar
I would classify the damper trick ( reversing l/r dampers and set in asymmetrical mode ) as being more than a fine tuning tip. For mod asphalt setups, , it will be staying on my car for the foreseeable future.
Jake
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 08-25-2014, 09:05 PM   #6979
hanulec's Avatar
Mod TC setup from August 23 2013 now posted online-
http://www.awesomatixusa.com/p/setup-sheets.html
Thanks again to Gee for the dialed setup
Old 08-25-2014, 09:45 PM   #6980
It's 2014...
-Mike
Old 08-25-2014, 10:31 PM   #6981
Originally Posted by grippgoat View Post
It's 2014...
-Mike
Better late than never
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 08-25-2014, 11:05 PM   #6982
G-rem's Avatar
Jake
That's noted Jake
But the swapping works only at the rear, is that correct?
Nice!
I have a question: I can see you are using AT31 instead of C31, can you explain us why?
Thanks a lot,
G-rem
Old 08-26-2014, 04:21 AM   #6983
hanulec's Avatar
That's noted Jake
Nice!
Thanks a lot,
G-rem
You can swap in the front too. Try it. We did. The car pushed more.
I ran the at31 as the super fast mod guys do -- and kits are now coming with the at31. I haven't compared the two back to back. With last weekend being my last "home" asphalt race, I wont be attempting to test a small change like that.
Old 08-26-2014, 04:33 AM   #6984
G-rem's Avatar
Ok, thanks for the explanations. I didn't know A700Evo kit came with AT31 instead of C31 now...I'm looking forward to test it soon
Old 08-26-2014, 05:31 AM   #6985
hanulec's Avatar
That is a recent running change. Other changes are the inclusion of P13-4 plastics instead of the P13 "tree".
Old 08-26-2014, 06:15 AM   #6986
G-rem's Avatar
These are nice changes, I've just upgraded to P13-4 too
Old 08-26-2014, 07:33 AM   #6987
AwesomatixUSA's Avatar
Just a heads up to folks.. Awesomatix USA will be on holiday starting this Wednesday to Tuesday next week. There is a large order in with Oleg for kits, chassis, new front drive shaft components, etc. Once these items are inbound we will post again.
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
AwesomatixUSA is offline   Reply With Quote
Old 08-26-2014, 10:27 AM   #6988
Hi,
the Euros are over now and Freddy was in the A-main and Viljami in the B it would be nice if Oleg could post the setup's. Also what do You Oleg thing about the damper swapping? How is the testing with the new suspention going ? It's sad that Mike Gosvig left the team ....
I hope that not more Top drivers will leave the Team because Oleg need's them to bring the car foreward and maybe a W.C. titel one day.
Claude
toroloco is offline   Reply With Quote
Old 08-27-2014, 12:26 AM   #6989
Originally Posted by toroloco View Post
Hi,
Claude
During this Euros Freddy and Viljami have tested a completely new suspension prototype with 3D-printed plastic parts and new carbon chassis that Freddy and Viljami have received just few days before the event. So their whole setups can't be used for the regular car. But some features of these setups can be useful for very bumpy tracks ( this Euros track was very bumpy): front kick up and rear anti dive, reverse asymmetric mode for front dampers, the increased ride height, no sway bars.
Oleg Babich is offline   Reply With Quote
Old 08-27-2014, 01:08 AM   #6990
Thank You Oleg
An other carbon chassis....
I think I will speak for many others... any chance of pictures of these parts?
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 Yesterday 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
