Like Tree21Likes
Old 08-21-2014, 02:22 PM   #6961
G-rem's Avatar
Originally Posted by geeunit1014 View Post
If it was me I would start with a softer setting(say half screws) for aspahlt and add screws if you feel the car is too stuck and lazy. For carpet I would do all but the first and last as hanulec suggested
I think I'll do like you said because when all is built together (AM30-5 full screwed, C01-AL-S and C21), it feels a bit stiff...I'll give it a try like that, then I will remove the upper deck or try upper deck + different combinaisons of screwing AM30-5.
I also installed parts to convert my FFG into FFG 1.1, it's super smooth, I've never seen my FFG 1.0 with such a smoothness, great job
G-rem is offline   Reply With Quote
Old 08-21-2014, 02:52 PM   #6962
Trader Rating: 1 (60%+)
i win again
cico is offline   Reply With Quote
Old 08-22-2014, 03:01 AM   #6963
G-rem's Avatar
Again with my screwing questions
When I use set screw on AM30-5, do I have to use 5mm length set screw or 6mm length?
At home, I have 5mm and it seems to not much outstrip out of the chassis, and 8mm length is 1.5mm too long... I guess 6mm will be ok but I'd like to have confirmation
Thanks in advance,
G-rem
Old 08-22-2014, 05:05 AM   #6964
hanulec's Avatar
Trader Rating: 27 (100%+)
Thanks in advance,
G-rem
5mm set screw. wow. that is fancy. i only have 3, 4, 6, 8, 10, 12, 14mm ones. based upon your description im guessing i'm using the 6mm ones...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-22-2014, 07:08 AM   #6965
G-rem's Avatar
Yeah I know, I can't even say where there are from^^
Let's buy some 6mm grub screws so thanks
Old 08-22-2014, 07:01 PM   #6966
hanulec's Avatar
after two rounds of tricky qualifying in Mod TC at the Euros, Freddy is 2nd overall (13 points), and Viljami is 8th overall (27 points). games with when and how to run your two tires are a foot. different drivers not running both of the first two of five qualifiers.
best of luck to the Awesomatix runners at the Euros...
Old 08-22-2014, 07:01 PM   #6967
hanulec's Avatar
http://www.myrcm.ch/myrcm/report/en/17353/139056
Old 08-22-2014, 10:56 PM   #6968
While there is nothing wrong with my original a700 I'm thinking about getting a new one to run in another class. I'd really like to try the soft aluminium chassis with the ffg (I mostly race low/med grip outdoor) and the new double jointed drive shafts look fantastic. Anyone know if any kit will have this combination any time soon? Spending an extra few hundred over the kit price for the alu chassis seems a bit of a waste
Simon
Team_Krusty is offline   Reply With Quote
Old 08-23-2014, 03:13 AM   #6969
hanulec's Avatar
Simon- what motor class do u race?
Old 08-23-2014, 05:22 AM   #6970
13.5 blinky. I'd demote the old car to 21.5 or maybe even step up to mod.
Old 08-23-2014, 07:47 PM   #6971
hanulec's Avatar
For non-mod the stock "L" chassis is more than fine...
Old 08-25-2014, 12:26 PM   #6972
geeunit1014's Avatar
We found this past weekend using 4 screws (2 around the ffg brace, and one at either end ond hole from the end) and no topdeck had very good results on medium grip asphalt. Hopefully Hanulec can post the rest of the setup on the site as well, because the car was the best car I have ever driven on aspahlt ( mod class)
Also for anyone else running asphalt looking for more corner exit/on power grip should try swapping the rear dampers left/right and run asymmetrical damping, this has been a big improvement, and should help over bumps as well
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-25-2014, 12:36 PM   #6973
Trader Rating: 23 (100%+)
Yo G.
I get the ASY working well. Do that already.
But - can you explain why swapping L to R, R to L improves the rate? It seemed to me that the 'stiction' felt the same whether you spin the dampener cam clockwise or counter-clockwise. Perhaps I am missing something.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-25-2014, 01:00 PM   #6974
bkspeedo's Avatar
Originally Posted by MDawson View Post
Yo G.
Swapping L to R does nothing unless your running asymmetrical. By swapping it will change the direction the dampening is soft versus stiff. I believe by default dampening is soft on compression and stiff on rebound.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-25-2014, 01:14 PM   #6975
Yo G.
Swapping l/r and running asymmetrical makes it so the bump is stiff, and the rebound is soft. On the track this gives more forward drive, I think because it keeps the outside corner from dumping over and it allows the inside tire to stay on the ground better. If you run symmetric then there is no difference if you swap l/r. This change really allows you to let the car have good mid corner rotation and also be planted on power
Mike Gee
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
