Like Tree13Likes
Old 08-18-2014, 11:52 AM   #6946
G-rem's Avatar
If ever anyone is interested: Awesomatix A700 Evo + A700 + parts
G-rem is offline   Reply With Quote
Old 08-19-2014, 07:43 AM   #6947
ropezz's Avatar
First limited batch ready !
ropezz is offline   Reply With Quote
Old 08-19-2014, 07:43 AM   #6948
ropezz's Avatar
New chassis with innovative features for 1/10 EP under development !
Old 08-19-2014, 10:59 AM   #6949
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
this caster Tool is design for Hudy only?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 08-19-2014, 12:39 PM   #6950
ropezz's Avatar
It is ideal for Hudy set up tool.
Regarding other brands of set up tools, consider that Caster tool has 0,5 mm clearance with Hudy scale (see 1 picture for reference).
Also Caster tool sits aligned with Hudy set up tool, without adding shims for track width (see 2 picture for reference).
Old 08-21-2014, 09:37 AM   #6951
G-rem's Avatar
I am building my car with C01-AL-S and AM30-5 but I don't know which screw I have to put on AM30-5 to have a good flex starting set-up...
Do I have to screw all the holes on AM30-5, putting set screw (in this case, what king of?) or else? Can someone help me?
Thanks in advance,
Best regards,
G-rem
Old 08-21-2014, 09:54 AM   #6952
syndr0me's Avatar
Trader Rating: 32 (100%+)
Anybody tried using this in the AMX?
http://www.liverc.com/news/new_produ...ss_motor_line/
Does it interfere with the chassis? It can only stick out the side at a right angle to the solder tabs. It replaces the center ring, so no motor scratching or sliding or other movement.
syndr0me is offline   Reply With Quote
Old 08-21-2014, 10:12 AM   #6953
geeunit1014's Avatar
Thanks in advance,
Best regards,
G-rem
Are you running carpet or asphalt? Low or high grip?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-21-2014, 10:25 AM   #6954
hanulec's Avatar
Trader Rating: 27 (100%+)
Thanks in advance,
Best regards,
G-rem
All screws but first and last.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-21-2014, 10:33 AM   #6955
Magnet Top's Avatar
Thanks in advance,
Best regards,
G-rem
Although I have not put my C01-AL-S on the track yet, but considering how flexy it is, yeah, what Hanulec said " All screws but first and last " Also, if you have the top deck try it too since it is easy to remove.
Note, be careful with the length of the screws that hold AM-49. The screws need to be very short. If they are too long the screws will run into AM30-5 and cause AM30-5 to bend away from the chassis or deform the chassis.
Jake
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 08-21-2014, 10:35 AM   #6956
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
It only fits the D4....and you are going to figure out you dont want to run those turds in TC!
Just kidding. The D4 just requires some different setup to get it to run Ive heard. I just havent figured it out because Ive spent more time on my car than my motor program so far!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-21-2014, 11:10 AM   #6957
G-rem's Avatar
Jake
Thanks for answering guys, appreciate!
Understood for AM49, nice tip
I'll try it first on a large low grip asphalt track with the C21 top deck, then I'll try it on carpet but I was told C01-AL would be better suited...I will see when I try.
G-rem
Old 08-21-2014, 11:24 AM   #6958
kartermdb's Avatar
Trader Rating: 15 (100%+)
Stock chassis, doesn't hit, but I think it is a touch too close to the motor.
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 08-21-2014, 11:29 AM   #6959
syndr0me's Avatar
Perfect, thanks!
You could shim it out a bit if it's too close maybe?
Old 08-21-2014, 12:11 PM   #6960
G-rem
If it was me I would start with a softer setting(say half screws) for aspahlt and add screws if you feel the car is too stuck and lazy. For carpet I would do all but the first and last as hanulec suggested
Mike Gee
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
