Like Tree1Likes
Old 07-30-2014, 11:34 PM   #6871
G-rem's Avatar
Originally Posted by G-rem View Post
For those who are interested in, I sell a nearly brand new A700 first generation with parts, I'll post it in the F/S thread tonight, PM me if interested
Cheers,
G-rem
AWESOMATIX A700 + parts
I also have an A700Evo full options to sell, possibility to sell it with the A700 to get spare parts
G-rem is offline   Reply With Quote
Old 07-31-2014, 09:41 AM   #6872
Originally Posted by dragonracing View Post
Oleg, do you still have this schematic available?
my track rods are already done this way. but thanks for the heads up.
Please:
Oleg Babich is offline   Reply With Quote
Old 07-31-2014, 11:10 AM   #6873
-jacob-'s Avatar
does anyone know who makes the longest body posts that i can put on the rear???.. I have a body that requires a couple of more holes
Thank you
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 07-31-2014, 11:37 AM   #6874
G-rem's Avatar
Originally Posted by Oleg Babich View Post
Please:
Super nice, will give it a try asap
Are there any other update like that or new parts coming soon?
Best regards,
G-rem
Old 07-31-2014, 11:59 AM   #6875
Magnet Top's Avatar
Thank you
You can stack some shims/washers under the posts and use longer screws.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 07-31-2014, 05:50 PM   #6876
Please:
thank you oleg. im assuming thats in mm. so off i go to strip the car and cut.
dragonracing is offline   Reply With Quote
Old 08-01-2014, 01:26 AM   #6877
G-rem's Avatar
Mike, can you explain us the cuts in your L chassis that you used in this set-up:
http://www.petitrc.com/reglages/awes...od20140524.pdf
Are they the same as the picture Oleg posted above? How does it perform compared to a raceberry chassis or C01AL?
Thanks for answering,
G-rem
Old 08-01-2014, 05:10 AM   #6878
hanulec's Avatar
Trader Rating: 23 (100%+)
G-rem
Grem- the picture posted by Oleg of an L chassis with big cuts under the motor and battery is what May me Gee ran. He hasn't tired an RB. Not sure if he went back to back with a c01al. I think the c01al is too stiff outdoors --- and that is why we now have the c01al-s.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-01-2014, 11:41 AM   #6879
G-rem's Avatar
Thank you
Old 08-03-2014, 09:01 AM   #6880
hanulec's Avatar
good luck in the A-finals to Josh Cyrul, Kyle Bergstrom and Mark Burt today in sunny and hot Florida at the ROAR Nats.
17.5- Mark Q3
13.5- Josh Q2, Kyle Q3, Mark Q6
Mod- Josh Q6, Kyle Q10
Watch live at http://live.liverc.com/77-ROAR_Elect...oad_Nationals/
Old 08-03-2014, 09:11 AM   #6881
geeunit1014's Avatar
G-rem
As Hanulec said, the cuts were done as the picture oleg posted earlier. The C01AL is not as good imo, it doesnt have as much steering. I dont have a raceberry chassis, but having driven other cars with them, I do feel that this is the best option. Not sure how the CO01Al-S will be. Being softer should help, but the wheelbase is different, shorter front and rear, which is opposite of what I have been doing mostly, which is adding rear caster to extend rear wheelbase.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-03-2014, 12:00 PM   #6882
G-rem's Avatar
Thanks for the feed-back Mike.
You said you tried the Raceberry chassis on other driver's cars, how did the cut C01-L perform compared to the Raceberry? Did you feel the cut C01-L approached the Raceberry feel in term of behaviour?
Thanks again,
G-rem
Old 08-03-2014, 12:16 PM   #6883
Thanks again,
G-rem
They are fairly similar in balance, but with the raceberry the car stays flatter due to the lower cg from the thinner chassis, so it just feels a little nicer to drive. I feel like I could exploit that to find some more speed from my setup. Maybe next outdoor season ill get one
Mike Gee
Old 08-03-2014, 01:09 PM   #6884
G-rem's Avatar
Thank you very much for these explanations Mike
Old 08-03-2014, 05:01 PM   #6885
Hanulec, thanks for the setup. worked fairly well. had to make a couple changes as the rear was too stiff. a bit loose on power out of the corners. softened the rear springs, removed the rear swaybar and reduced front camber and it was better. still needs some more tuning but was pretty decent. had a fully cut top deck and going to try a non cut top deck next weekend. car had a little push on entry and a little loose on exit. got the loose figured out now working on the entry push. thanks for the setup and help. any suggestions for the entry push?
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 04:26 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17211 02-22-2017 05:13 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
