Old 07-28-2014, 07:23 AM   #6841
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Originally Posted by dragonracing View Post
Had to retire the A car today. just too many breakages. track was rough and my setup just would not work. could not be consistent with the car. had to go to my backup tc 6.1. my parts did not arrive in time to get them changed over. still waiting on the parts. managed to tq end ended up 2nd.
the a car just dont like the bumps on this track (rough at best) but with the hard springs and its current setup it was not happening. next race is back to smooth asphalt. and the car will shine. i did shorten up the links in one hole and it made things worse for me so im going to keep long links. i like how it works that way.
Soft springs and soft damper settings should make the bumps a lot easier to navigate, but getting it right takes a little bit of testing. Most setups these days are using the soft springs, and it seems that you should have an appropriate range of spring rate adjustment between the Type1 and Type2 SRS/RHS arrangements to cover most (if not all) track conditions.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 07-28-2014, 07:27 AM   #6842
Originally Posted by hanulec View Post
McMaster Carr has some good bulk screws....
Yeah but they won't ship to Canada anymore. I've got local supplies but I was wondering about the spec of the screws in the kit and locating an exact match.
I've notice that Awesomatix.com carries the kit screws, I'll order them through there.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 07-28-2014, 07:49 AM   #6843
hanulec's Avatar
Trader Rating: 23 (100%+)
21.5. Scale spec. Usgt/vta class
Well I'd go after the softest possible setting (like my stock setup). You're not going mac 1 so the suspension doesn't need to be that stiff...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-28-2014, 07:52 AM   #6844
Trader Rating: 54 (100%+)
Another noob question. How can I tell the difference between am06 and am06s?
Jamison R is offline   Reply With Quote
Old 07-28-2014, 08:13 AM   #6845
geeunit1014's Avatar
AM06 is silver, AM06s is the anodized color awesomatix uses (gunmetal?). The s blocks are also shorter, easy to see if you have the 2 side by side
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-28-2014, 08:26 AM   #6846
Thank you
Old 07-28-2014, 11:05 AM   #6847
Stogie's Avatar
Suffered my first spool failure yesterday... drive teeth ring separated from the aluminum body. Was back up and running again in minutes with the help of CA glue and it held the rest of the day, but I have a pretty low degree of confidence in how long it's going to hold. Anyone have luck permanently reattaching these? Maybe JB-Weld? I don't have easy access to an actual welder.
Perhaps this would be a good candidate for enhancement/redesign in the future, seeing as this appears to just be a press-fit attachment. Possibly a grooved spline or simply welded together - since this does not appear to be a serviceable item?
Stogie is offline   Reply With Quote
Old 07-28-2014, 11:18 AM   #6848
JayL's Avatar
they already have a new spool and it's awesome
at03m-s
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 07-28-2014, 01:54 PM   #6849
hanulec's Avatar
There are a few loctite solutions to reattach the ring. We van try and repair if it is free. Done 5+ successful repairs in 1yr
http://www.awesomatixusa.com/p/spool...ar-repair.html
Old 07-28-2014, 04:25 PM   #6850
hanulec's Avatar
to be honest a 3mm screw is a 3mm screw. there isn't that much variety in quality. i'd personally recommend you ask around for dealers like mcmaster in candada.
Old 07-28-2014, 05:53 PM   #6851
Trader Rating: 32 (100%+)
Have you tried
http://www.fastener-express.com
Monti
Monti is offline   Reply With Quote
Old 07-28-2014, 06:35 PM   #6852
parts arrived today. will be changing set up during the week. will go with hanulecs stock setup. ordered more parts last night. but the AM06S are out of stock. can anybody tell me the difference between the am06 and the am06s? i understand the am06m as its like the am06s but narrower.
dragonracing is offline   Reply With Quote
Old 07-28-2014, 07:03 PM   #6853
Magnet Top's Avatar
The distance between the axle and the lower ball ( st03 ) is shorter than AM06 by 1mm. Am06s effectively lowers the roll center.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 07-29-2014, 08:48 AM   #6854
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Monti View Post
Have you tried
Monti
Also www.teameam.com has full Titanium Hiro Seiko kits and Titanium bottom and Alloy top screw kits in stock!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 07-29-2014, 10:40 AM   #6855
JayL's Avatar
EA
Great Screws! I just decked out my EVO with the Ti ones.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17198 Today 01:13 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
