Like Tree13Likes
Old 07-27-2014, 08:04 AM   #6826
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by dragonracing View Post
Had to retire the A car today. just too many breakages. track was rough and my setup just would not work. could not be consistent with the car. had to go to my backup tc 6.1. my parts did not arrive in time to get them changed over. still waiting on the parts. managed to tq end ended up 2nd.
the a car just dont like the bumps on this track (rough at best) but with the hard springs and its current setup it was not happening. next race is back to smooth asphalt. and the car will shine. i did shorten up the links in one hole and it made things worse for me so im going to keep long links. i like how it works that way.
Have you tried signifigant damper value changes? Although my issue was not with bumps, I just prefer my car with smaller damper values. (softer)
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-27-2014, 01:16 PM   #6827
Yes mike. I will try softer damper values. Still waiting for damper tool to arrive in the mail.
dragonracing is offline   Reply With Quote
Old 07-27-2014, 01:18 PM   #6828
Originally Posted by OVA View Post
well doug
maybe your car didn't like the bumpy track. my A car. seem to be working fine, and I was at least 5 sec faster than your best TQ time. the dang ball cup kept popping off..I'm just too lazy to change it ilol
Some how my servo just lock on me
Remember franko. I did not qualify with my "A" car at all. Just the 6.1. I practiced all morning with the "A" car then switched right before qualifying.
Old 07-27-2014, 01:33 PM   #6829
hanulec's Avatar
Trader Rating: 27 (100%+)
when in doubt -- you can use anything the measure thickness of the A or B values. 1.5, 2.0, 2.5, and 3.0mm hex tools work in a pinch. i often just eyeball the dampener value by looking at the space at the bottom of the chassis --- especially when i'm making quick track side adjustments with a 2.0mm wrench.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-27-2014, 04:30 PM   #6830
thanks, never thought of that. might try that if i need to.
Old 07-27-2014, 07:20 PM   #6831
well doug
i dont think you were faster than my final tq. but you have to finish a qualifier first or it doesnt mean squat. and didnt you change cars for the main? oh yeah you did. i lapped you
Old 07-27-2014, 08:29 PM   #6832
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
I know
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 07-27-2014, 08:48 PM   #6833
OVA
OVA's Avatar
Okay Doug
First of all... yes I tap the pipe on my final lap. And the dang ball cup keep popping off just before I could finish... yes you would be 6 sec slow compare my qualifier. You are right I didn't finish ...lol
In the A-main ,yes ,I borrow the B main driver car with the half dead batteries .Plus I never drove the guy TC before and not bad for the first time driving a strange car and finish 4th..and I noticed the guy radio steering was set only 75 percent ...it all good
Old 07-27-2014, 08:55 PM   #6834
ouch. 75% steering? ugh. my parts should be here tomorrow and a new setup goes on the car. going to ask now since i have a couple weeks before the next series race. large track 200' straight. sweeping corners. nothing too technical from the pics of the track. am i going to want the stock stiffer springs or the softer springs. i am going to stay with the longer links for now. its easy to drive that way for me. as long as i can keep from tapping the pipe ill be good. the last track everybody was tapping the pipes. rough surface. big bumps. i seen more cars airborne on that track without hitting anything. the bumps are bad. its a fun and challenging track for sure. i really lliked the layout. had fun. so to my question...hard or soft springs for a larger track?
here is a over head shot of the track. timezone raceway.
Old 07-27-2014, 09:12 PM   #6835
OVA
OVA's Avatar
I ran soft spring all last year ...and work great at the TZ ...Most of the set up sheet today are soft spring setting . Soft spring seem to work better in most applications...
Old 07-27-2014, 09:36 PM   #6836
good to know. i remember you saying really? when i stated i had the hard springs. your running the soft ones right?
Old 07-28-2014, 02:52 AM   #6837
Trader Rating: 55 (100%+)
Doesn't the evo kit come with the soft spring?
Jamison R is offline   Reply With Quote
Old 07-28-2014, 04:46 AM   #6838
hanulec's Avatar
Dragon -- what motor class are you running?
Yes- all 2nd gen (L, EX, EXL) and 3rd gen (EVO) cars come with "S" soft springs -- spr01s.
Old 07-28-2014, 05:54 AM   #6839
OVA
OVA's Avatar
yes Im running soft spring in stock and SS..
Mike H. Doug is running 21.5 USGT
Old 07-28-2014, 05:54 AM   #6840
21.5. Scale spec. Usgt/vta class
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
