Like Tree21Likes
Old 07-15-2014, 09:35 AM   #6781
Originally Posted by G-rem View Post
Wow, this chassis looks very impressive, I would be scared of bending it...
Better on low/mid-grip outdoor tracks than C01AL? And for carpet track, will you recommend to use C01AL is stead of the soft one? (regarding this last point, will you soon restock C01AL or the C01AL-Soft replaces it finally)
Anyway, it is very pleasant to see all the pictures of parts on the website, nice job!
I hope that C01AL-Soft will replace all our alloy chassis on all tracks.
Oleg Babich is offline   Reply With Quote
Old 07-15-2014, 09:45 AM   #6782
G-rem's Avatar
Haha^^
Can't wait for feedbacks
G-rem is offline   Reply With Quote
Old 07-17-2014, 12:22 AM   #6783
Trader Rating: 1 (60%+)
i win 13.5 stock blinky
Awesomatix EP Touring Car (A700 Shaft Drive)-10557547_10152509027734373_9107969846053121544_o.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-10440857_732249273491610_109543420841288625_n.jpg
cico is offline   Reply With Quote
Old 07-17-2014, 08:13 AM   #6784
Congratulations, Çağhan !
Are you the Turkey Champion now?
It will be very interesting to get small report and setup from you.
Old 07-17-2014, 10:46 AM   #6785
chasingthepack's Avatar
another stock win to be proud of oleg,shauns been very quick of late
http://www.redrc.net/2014/07/brca-cl...rt/#more-83849
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-17-2014, 01:23 PM   #6786
My congratulations for Shaun!!!
Old 07-18-2014, 04:56 AM   #6787
Trader Rating: 23 (100%+)
Hi all,
i'm after some building tips for gd2 w/metal gears. it's leaking from the outdrive and was wondering what others do to combat this or am i the only one? it's just seeping out and cakes up with dirt after a race meet.
i've built it using the Max's recommendation of the small shim behind the big gears.
thanks in advance!
poop is offline   Reply With Quote
Old 07-19-2014, 12:53 PM   #6788
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Hi poop,
I had this one time also. The problem is that i filled to much oil in! I found it out by running in the diff direct after the build. After this i cleaned it and no more leaking.
If you put in to much oil then it will be leaking out of the orings by the outdrives during the run/heating up. So it regulates the oil levle itself ;-)
Tip: When i finish building a gd2 i put it into the car and run it in.
Car is on the car stand and i hold alternately the left/right rear tire with my hands and hit the throttle constantly on the transmitter.
I do this ~2 minutes , then the diff will reach 25-35 degree.
If you put to much oil into diff it will regulate itselfe during this "run in" method.
In case it dont stop leaking please check the orings on the outdrives. I also saw some who damaged it during the build because the put the orings first into diff case. But this is wrong.
I put o-rings on shafts first and then insert the shaft with bearing and o-ring into diff case.
I also installed and tested the updated FFG 1.1
Super smooth and nice function with the new parts. Feels more free and "softer" now.
It also prevent the problem with the "tweaked/blocked" FFG after a hard crash. Also its no more dangerous to run without the diffcovers like recommended with the first version of FFG.
Best Regards Max
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / FUTABA / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Old 07-19-2014, 02:43 PM   #6789
I have had good success building the GD2 - fill to capacity, leave one bleed screw undone and insert into a shock pump with that open bleed screw facing up. Apply a couple pumps of the vacuum pump. Excess oil/air will bleed out of the hole. Apply set screw + outdrive and pin.
The shock pump helps clear excess air and settles the oil with the spider gears + cross pin and main gears.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 07-20-2014, 12:40 AM   #6790
Thanks for the gd2 building tips!
questions for those running FCB: what tool are you using to adjust the camber nut? Also, do you bottom out the camber screw first, adjust caster, then set camber? what's the correct procedure?
Thanks again!
Old 07-20-2014, 02:51 AM   #6791
Trader Rating: 55 (100%+)
I have a Awesomatix noob question. Onroad has recently returned to our lhs and a few of us have picked up the car. My question when reading the directions for shock settings. When moving the hook further from the shock(meaning towards the car or wider gap) does this soften or harden the spring rate?
Jamison R is offline   Reply With Quote
Old 07-20-2014, 04:29 AM   #6792
elee32's Avatar
Trader Rating: 18 (100%+)
Wider gap = softer
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 07-20-2014, 04:38 AM   #6793
!Mad Max!'s Avatar
Hi,
Yes bigger gape is softer spring.
Its a easy way to check that. I hava a PDF reader on my iPhone and have a clear editable A700 Evo setupsheet in.
There you can check the stiffnes of spring and damper. You can put in 2mm spring and 1mm damper for example and see then the gF/mm of your setup. This is the way i alsways do when i want to change the rates.
Best regards Max
Old 07-21-2014, 05:49 AM   #6794
Trader Rating: 32 (100%+)
Hanulec,
I was able to get back to Leisure Hours yesterday and tested the stiffer sway bars. The track had the same lay out but the grip was a lot lower than it was two weeks ago. After rd 1 I was tq, radio issues hampered my next two qualifiers and I lost TQ. In the main I started 2nd and got bumped around at the start and fell all the way back to dead last. I worked my way back to third with the top 4 finishers crossing the line with in 1 sec!
The sway bars were a huge help with the car not getting tight and carried more corner speed. Thanks for the suggestions.
If anyone is in the Mid-West area, there is going to be a race in Cincinnati on Aug 9th. This race will be part of the Mid-West nitro series and EP TC will run on Saturday only with three heats and a main, 17.5 and Mod only. This race is also in conjunction with the Hamilton Co fair so there will be food, rides, and demolition derby Saturday night.
Monti
Monti is offline   Reply With Quote
Old 07-21-2014, 06:11 AM   #6795
bkspeedo's Avatar
Originally Posted by !Mad Max! View Post
Hi,
Best regards Max
For those interested here's an Excel spreadsheet i created you can use to calculate your suspension stiffness. It works on a smartphone if you have an MS Office app.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
