Like Tree25Likes
Old 07-10-2014, 09:30 AM   #6751
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Can I update my existing FFG with only AM54-1, and still use the old AM46(with brg), or do I need to get AM46-1 as well?
SLOWINSLOWOUT is offline   Reply With Quote
Old 07-10-2014, 11:55 AM   #6752
AM54-1 needs AM46-1.
You can also extend the oval hole of your AM46 on 2.3mm to the front direction, move the bearing ahead and use such modified AM46 with AM54-1.
In case of you use FFG with ball bearing already, such updating should be not so interesting for you IMHO.
New AM43-1, AM44-1, AM42-1 can be used with old AM46+AM54.
Oleg Babich is offline   Reply With Quote
Old 07-11-2014, 07:40 AM   #6753
Travis S's Avatar
Trader Rating: 46 (100%+)
Monti - Do you have that 700L 17.5 setup sheet you used @ Joliet? I might get lucky and get to go race there Saturday. Did you try it with sorex 36's?
Travis S is offline   Reply With Quote
Old 07-11-2014, 07:51 AM   #6754
geeunit1014's Avatar
I believe he said he was running Larry/FJ's jackson setup.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 07-11-2014, 08:08 AM   #6755
Travis S's Avatar
It sounded like he changed some things from his past posts, but I have been wrong before. I have that setup on it now, but if he found something that works better out there then I was going to change it over tonight.
Old 07-11-2014, 09:52 AM   #6756
hanulec's Avatar
Trader Rating: 27 (100%+)
Biggest change is am06m in the rear.
Otherwise using the posted setup from Memorial Day 2014.
hanulec is offline   Reply With Quote
Old 07-11-2014, 06:18 PM   #6757
Trader Rating: 33 (100%+)
No I have not changed anything. I did run Jaco oranges and Sorex 36's and it wasn't any different. I am running the am06m, but I was running those last time too. The only thing I do to my 17.5 car right now is blow the dirt off of it.
Monti
Good luck tomorrow 80% chance of rain! I am not going to make it.
Monti is offline   Reply With Quote
Old 07-11-2014, 08:07 PM   #6758
Travis S's Avatar
Monti
Thanks for the info. I saw the weather for there after I posted. Not going to make the drive over for that and can't do race on sunday. Maybe next points race...
Old 07-12-2014, 05:09 PM   #6759
stiltskin's Avatar
Trader Rating: 102 (100%+)
First race (and run) with my A700L today. Set TQ in the first round, reset it in the 3rd round by 3 seconds. The car got better each round and so far, it's very impressive. Still have alot to learn with the car, but so far, so good.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 07-12-2014, 06:18 PM   #6760
MikeXray's Avatar
Trader Rating: 73 (100%+)
Nice!
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-12-2014, 08:12 PM   #6761
Trader Rating: 23 (100%+)
Good work Rumple!
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 07-12-2014, 08:34 PM   #6762
hanulec's Avatar
Great job tony.
Curbs were rough at Jackson today. Got a ton o people in the main today.. Fast lap is all I could hope for after turn two...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
Old 07-12-2014, 08:45 PM   #6763
I got to run the new Awesomatix brushless servo today. It is dead nuts accurate, and it was noticeably quicker than the Futaba 9551 I had been running. Once I got used to it, it was almost telepathic. Also seemed like it was held in more solidly since the mount is built into the case. Its pricey, but definitely worth it imo.
Mike Gee
Old 07-13-2014, 03:51 AM   #6764
Trader Rating: 55 (100%+)
Thats because I wasn't there. See you next weekend on the podium Rump. Just you'll be one step lower
Jk good first run.
Jamison R is offline   Reply With Quote
Old 07-13-2014, 05:19 AM   #6765
stiltskin's Avatar
Jk good first run.
I was counting my blessings knowing you weren't going to be there yesterday.
Tony Rumple
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
