Like Tree13Likes
Old 07-01-2014, 01:36 AM   #6661
Originally Posted by HawaiiBob View Post
If you use 64p gears a 96 tooth spur gear should be fine for the gear ratio you are looking for. A 96/43 spur pinion combo gets you to a 4.64 final drive ratio.
Ok but if You look at gear ratio chart in the manual 36t pinion is the largest listed with a 96t 64p Spur.
Are you sure 96/43 will fit?
So now an other question comes up what is the largest pinion with 96t Spur that still fit's with enough play between both spur and pinion?
Claude
toroloco is offline   Reply With Quote
Old 07-01-2014, 03:50 AM   #6662
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by toroloco View Post
Thank's but with 96t the FDR is way to short need an FDR around 4.6.
So we need to wait till Oleg comes out with his own one's ?
I cannot believe that Oleg design an build's something that we can only use with one Spur Gear so please Oleg help us
I've found some other smaller gears that could work -- but haven't focus on trying the SD1 much. I really like the at12m with the normal at20. It prevents the possibility of your spur getting loose and allows you to run any gear brand you like.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-01-2014, 06:10 AM   #6663
bkspeedo's Avatar
You don't need a spear gear with just 2 holes. I've used Kimbrough, CRC, Xenon, Xray for both stock classes and Mod. With CRC you do have to be careful the width of the gear is a bit wide and may rub on the motor bulk head so you have to sand one edge to make it clear.
For 17.5 and 13.5 use a 82 64p
for Mod us 96 64p
If your running a 10.5 to 8.5 with little or no timing from the ESC I would use something around 88-90.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-01-2014, 06:47 AM   #6664
for Mod us 96 64p
All this Brands with Spur Damper SD1?
Old 07-01-2014, 07:11 AM   #6665
bkspeedo's Avatar
Yes.
My son has been using Xray. I've used Kimbrough, ARC, CRC so far.
I'm currently using ARC and like it the best so far, there narrow and strong.
Brent Klingforth
Old 07-01-2014, 07:31 AM   #6666
MikeXray's Avatar
Trader Rating: 73 (100%+)
Without the SD1 I like the RW white gears, the nut seems to dig into the material well and not come loose.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-01-2014, 08:18 AM   #6667
hanulec's Avatar
+1 for Arc gears + SD1
Old 07-01-2014, 12:47 PM   #6668
Big Thank's to all of You for all the Info's.
Will go for the ARC spur.
Claude
Old 07-02-2014, 12:50 PM   #6669
-jacob-'s Avatar
I still got some left.. Brand new in a packaging Awesomatix parts on ebay
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 07-03-2014, 05:46 AM   #6670
daktulos's Avatar
Hi!
Another new proud A700L owner!
I am a little curious is screwing the ballstud from under AM18-1 can achieve the same link/roll center setting than AM19 without any shim? Probably not very practical or the ballcup may also hit something
I thought of that after ordering some AM19 to try an outdoor setup.
I know it was already talk about but just to be certain on the top deck screws setting a white dot mean something screwed without any ST09 and a red dot no screw or something with a ST09 under?
Thanks!
Alexandre
daktulos is offline   Reply With Quote
Old 07-03-2014, 05:47 AM   #6671
daktulos's Avatar
Sorry double post
Old 07-03-2014, 05:57 PM   #6672
hanulec's Avatar
Originally Posted by daktulos View Post
Hi!
Thanks!
Alexandre
welcome to the team
not sure where you are talking about the ball stud on the am18-1. the am18-1 will have a longer link than the AM19. am18-1 should be same length as FFG top mounts.
for the top deck -- red dot means st09 collar installed. more info about that here--
http://www.petitrc.com/reglages/awes...matixA700.html
Old 07-03-2014, 08:18 PM   #6673
daktulos's Avatar
OK thanks it's clearer now!
I don't want to look like a guy that's arguing so I will try to borrow an Am18-1 from a friend when I will receive the Am19 to take measurements and show what I mean if it's an interesting alternative for cheap guys like myself.
Sometimes even in French I have difficulty to make my friends understand me!
Cheers
Alexandre
Old 07-04-2014, 12:10 AM   #6674
Is Leespeed Spur any good? Anyone have tried them with SD1 or SD2?
Bangkok, Thailand | Awesomatix Thailand
moodesmo is offline   Reply With Quote
Old 07-04-2014, 12:58 AM   #6675
G-rem's Avatar
G-rem is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
