Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 06-15-2014, 02:51 PM
  #6586
elee32's Avatar
Trader Rating: 18 (100%+)
Originally Posted by pandd2105
hi there i would like to ask is it possible and meanful to replace the servo rodst21 of the a700 evo to a turnbuckle if yes please provide the length of the servo rod as my a700 evo is still on shipment and.if its possible please also provide the length and quantity of the other turnbuckle because i want to change the colour lol and get ready before i assembly my a700 evo thak you very much for your attention.
There is not a lot of space in between the steering rack and the end of the ffg so a tunbuckle may not clear through the whole steering throw
elee32 is offline
Old 06-16-2014, 11:50 PM
  #6587
FCB (Flexible Caster Block) sets are available now.
Features:
1. Adjustable caster flex level.
2. Simple camber adjusting without turning of the top turnbuckles.
3. Fixed caster mode is available.
4. Simple caster adjusting (in the fixed caster mode only) without turning of the top turnbuckles.
5. Camber flex configuration is possible with optional inner o-rings.
http://shop.awesomatix.com/index.php?productID=1019
File Type: pdf
Oleg Babich is offline
Old 06-17-2014, 03:08 AM
  #6588
29TC's Avatar
Is the FCB specific to the front arms or can be used front/back?
29TC is offline
Old 06-17-2014, 03:16 AM
  #6589
josecarlo1129's Avatar
^I think it can be installed to both but let's hear Oleg's suggestion based on the team's testings.
Another innovation from AWESOMATIX. The car will surely be more responsive with this.
josecarlo1129 is offline
Old 06-17-2014, 03:23 AM
  #6590
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Both -
But I'd like to hear from Oleg if, when installed in the back, is Adjustable Caster Flex used, or only the Fixed Caster Mode?
hanulec is offline
Old 06-17-2014, 05:19 AM
  #6591
hana166's Avatar
Been out the game for some time.
I'd like to convert the inner upper balls from AT21 to ST24 and use P13-4. Should be neater and easier to make shim changes. Is the height the same?
Does anybody know the difference between ST24 included with FFG and ST24-2
hana166 is offline
Old 06-17-2014, 11:10 AM
  #6592
ST24 and ST24L balls are 0,7mm lower compared to AT21.
Old 06-17-2014, 11:55 AM
  #6593
JayL's Avatar
So how do you copy a setup that uses AT21? I only see 1.75mm shims, so it would be off by .05mm?
JayL is offline
Old 06-17-2014, 12:15 PM
  #6594
+/-0.05 mm is not so important as this is within the productional tolerance for combination of ball stud + any shim height.
Old 06-17-2014, 12:26 PM
  #6595
Magnet Top's Avatar
Last edited by Magnet Top; 06-17-2014 at 12:29 PM. Reason: Oleg already answered it
Magnet Top is offline
Old 06-17-2014, 04:13 PM
  #6596
hana166's Avatar
Thank you Oleg for your answer
hana166 is offline
Old 06-17-2014, 11:32 PM
  #6597
G-rem's Avatar
Oleg, can you please tell us how different are the new parts for the FFG set (AM42-1, AM46-1 and AM54-1) in comparison with the original ones (AM42, AM46 and AM54)?
Apart from these parts, is there any other updates for the FFG1.1 set in comparison with the first FFG?
What is the AM30-5 stiffner? How different is it from AM30-1?
How different are ST24-2 in comparison with ST24?
Thanks a lot for your support,
Best regards,
G-rem
G-rem is offline
Old 06-18-2014, 04:36 AM
  #6598
hanulec's Avatar
Best regards,
G-rem
FFG1.1 is a minor revision of parts (AM42-1, AM46-1 and AM54-1), and includes the bearing mod discussed on many prior pages.
AM30-5 is stiffer (6mm thickness) and has the additional holes for more precise flex adjusting for the future. AM30-5 is suitable for current alloy chassis also.
ST24-2 is a quantity=2 packaging instead of the ST24 quantity=4
hanulec is offline
Old 06-18-2014, 05:54 AM
  #6599
G-rem's Avatar
Fantastic Mike, thank you very much!!
Can we have pictures comparison of AM42 vs AM42-1, AM46 vs AM46-1 and AM54 vs AM54-1, please? Also, do you have any manual for this updated FFG kit(to see the bearing mod,...)?
Best regards,
G-rem
G-rem is offline
Old 06-18-2014, 06:54 PM
  #6600
Smile
P e r f e c t O l e g..... N i c e !!!!
Best regards,
G-rem
bertrandsv87 is offline
