Like Tree25Likes
Old 06-05-2014, 03:10 PM   #6526
The FFG's left right action presses on the sides of the bottom P10, dislodging it it is not secured properly. The alleviate the excessive pressure from the top plate pressing on the P10, add 0.3mm shims on all four corners. I added a layer of elec tape on the bearing holder on the top side to take up the space created by the shims. Now the bottom P10 stays in place securely, and the side to side action should not pop them open.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-06-2014, 02:08 PM   #6527
mr.preay's Avatar
I'm very new for A700 Evo.
Very impressive feeling...
Please suggest the Clearance of the gears,
I don't know when should I add more shim.
And what kind of grease should be used?
Thank you.
RC City, Bangkok Thailand, Hobbywing Thailand Technical Support Lead, Awesomatix Thailand, Cube Traction, Suwannakorn Hobby.
mr.preay is offline   Reply With Quote
Old 06-06-2014, 02:39 PM   #6528
There should be a little clearance, not much, like the gear mesh between your spur/pinion.
I never use grease on the gears.
Hope it helps
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 06-06-2014, 05:57 PM   #6529
Hello im thinking of getting the a700 evo as they look absolutly brilliant and an engineering master piece. I was wondering could anyone tell me what there like on the track and how awkward are the dampers to set up.
tom1987 is offline   Reply With Quote
Old 06-06-2014, 07:16 PM   #6530
They are quite nimble on the track and the dampers are easier to set up than regular shocks, also easier and much quicker to make spring and oil adjustments.
HawaiiBob is offline   Reply With Quote
Old 06-07-2014, 05:09 AM   #6531
hanulec's Avatar
Trader Rating: 27 (100%+)
Good luck to our ETS runners this weekend.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-07-2014, 06:32 AM   #6532
Happy days, also what is the lowest turn motor that can be used with the ffg?
Old 06-07-2014, 01:56 PM   #6533
You can use every 540 motor available on the market without any problems, from 2.5T like Bert to 21.5T and higher
Awesomatix | LRP
Old 06-08-2014, 02:12 PM   #6534
Delete
Awesomatix EP Touring Car (A700 Shaft Drive)-20140424_182353.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-20140430_204750.jpg
NickGroves is offline   Reply With Quote
Old 06-09-2014, 03:39 AM   #6535
Questions??
Since the instruction manual didn't states the size of the bearing use in the A700 Evo kits
Does anyone know what are their size and quantity for each?
Are the bearing for A700EVO Ceramic ?
thanks in Advance
Bangkok, Thailand | Awesomatix Thailand
moodesmo is offline   Reply With Quote
Old 06-09-2014, 05:16 AM   #6536
Hi,
I was at the ETS Race the weekend, an had a chat to some of the Team driver's there.
In Stock Mike Gosvig ran an nearly out of the box car with only few tuning parts. Same to Oliver Franke who ran the bearing modification on the FFG. Mad Max Mächler was runing his custom carbon chassis (look a few pages back where he posted pictures) with the top deck.
Mike ran a very soft Setup as he told me.
Freddy was runing the Raceberry Chassis with the FBC front an rear.
Oleg who was also there to support the Team Driver's an all other Awesomatix driver's will certanly post the setup's very soon.
All four had the new AM06M hubs on the car's.
Claude
toroloco is offline   Reply With Quote
Old 06-09-2014, 08:38 AM   #6537
hanulec's Avatar
thanks in Advance
Steel bearings
At awesomatixusa.com in the "downloads" page you can find the detailed parts lists within quality assurance forms
Old 06-09-2014, 08:55 AM   #6538
hanulec's Avatar
Thanks for the info Claude.
In my own testing I've been trying am06m in two different configs - 1) only in the rear; 2) all four corners.
I believe am06m in the rear are better -- at least for me. It has a better feel without impacting my lap times.
Old 06-09-2014, 01:02 PM   #6539
Smile
I run Acer ceramic Mr84 & Mr106 in my A700ex transmission... No way I'm ever using steel Bearings on a $1000 Rc Car... Even my mod tc4 has ceramics in it........
thanks in Advance
bertrandsv87 is offline   Reply With Quote
Old 06-09-2014, 01:50 PM   #6540
Trader Rating: 23 (100%+)
Anyone?
What is the maximum amount of steering throw you can get? Full lock - what steering rack and steering arm are you using?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
