Like Tree25Likes
Old 05-13-2014, 12:45 PM   #6406
JayL's Avatar
Originally Posted by FreddySudhoff View Post
keep cool guys !
The new parts from Fun Parts are great, not a must have but makes the work a little easier. I have tested them and they do great!
We saw many people struggeling to setup the caster/ camber correctly. The doodles are fine, too I think many people like the "bling bling" effect so give the new tools a chance!
Freddy
Thanks for the input! Always nice to have comments from a world class level driver. Especially as you have actually used the product
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 05-13-2014, 02:39 PM   #6407
Setup from Freddy:
Oleg Babich is offline   Reply With Quote
Old 05-13-2014, 03:20 PM   #6408
Penz316's Avatar
Just receive my kit from awesomatixusa.com and i'm very very happy.
I would like to thanks Mike for the quick answer, great service and fast shipping ! I will not hesitate a second too buy again from him !
Now, time to built it !
Alex
Alex Fournier
Team Associated | Reedy | Team Scream Racing | Hyper Hobbies
Penz316 is offline   Reply With Quote
Old 05-13-2014, 11:42 PM   #6409
Setup from Oliver Franke:
Old 05-14-2014, 06:35 AM   #6410
josecarlo1129's Avatar
Hi Oleg. When will the FCB be released? TIA.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 05-14-2014, 10:00 AM   #6411
Originally Posted by wildrace View Post
Hi Oleg,
your measurements of torsional stíffnesses are very interesting.
You set the reference point 100% for C01L 3mm carbon chassis and no top deck.
Is it possible to give the ca. %-value for the standard A700L with uncut top-deck and fixed setting with only 2 ST09 upper collars?
Would be very helpful as I would like to move the stadard flex settings from my A700L to my new Evo which I'm currently building.
Thanks in advance!
C01L with the uncut standard C02-1 top deck has ~ 250% of the torsional stiffness.
Old 05-14-2014, 10:50 AM   #6412
Hi guys,
I've just received my alu chassis and directly put it on a my setup board (in fact a glass plate)
It seems like it is not 100% flat. Is this normal or is that a manufacturing error? One side is a liiiiittle bit higher than the other. Will this disappear when the car is built?
And do we still really have to glue the P06-1 to the aluminium chassis?
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 05-14-2014, 10:50 AM   #6413
Awesomatix | LRP
Old 05-14-2014, 11:55 AM   #6414
Originally Posted by Awesoman View Post
Hi guys,
One side ( left or right) or one end ( front or rear)?
What is the height difference?
Usually the preform has some insignificant curvature in transverse direction.
The final shape of our alloy chassis depends on AM30-1 stiffener correct screwing also.
Please use the glue for P06-1 as you will have to cut the protruding part of P06-1 from the bottom side after installation.
Old 05-14-2014, 12:11 PM   #6415
Oleg,
The height difference is from left to right.
With the stiffener on (AM30-1) it becomes bigger.
It maybe is about 0.1-0.2mm without the stiffener. As said above, nothing is mounted to the plate yet
Awesomatix | LRP
Old 05-14-2014, 01:41 PM   #6416
Oleg,
0.1-0.2mm is within the acceptable tolerance for flatness that our manufacturer provides for 2mm 7075 T6 alloy plates.
Old 05-14-2014, 01:59 PM   #6417
Travis S's Avatar
Trader Rating: 46 (100%+)
So when will the EVO start to come with the GD2? Would also be nice if you had options for an the Alloy chassis EVO or Carbon chassis EVO. We all know this car is a lot of money vs other cars out there, so this would be a welcome change IMO.
Travis S is offline   Reply With Quote
Old 05-14-2014, 02:01 PM   #6418
Thanks a lot Oleg
Awesomatix | LRP
Old 05-14-2014, 05:13 PM   #6419
haywood's Avatar
Trader Rating: 48 (100%+)
Default A700 Evo
Kicking around selling my near new Evo. Raced it two weekends on carpet. Pm me for info.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 05-15-2014, 06:34 AM   #6420
cosmokitten's Avatar
Default Build Problems with GD2?
Guys,
Assembled my GD2 for the first time last night with the Shepherd metal gears. First assembled without oil to make sure the fit is good. Everything was OK until I fully tightened the diff halves, then the diff was locked. Triple checked everything, the diff halves spin nicely with the internal gears when separate, they also spin nicely during attachment of each diff halve (ensuring the gears are aligned), but when performing the final tightening of the halves, the diff is locked.
I'm wondering whether I should omit the spacers behind the two larger internal gears? Has anyone else experienced this when assembling GD2 with Shepherd gear combo.
Appreciate!
cosmokitten is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
