Old 05-06-2014, 12:11 PM   #6346
Originally Posted by syndr0me View Post
Oleg, do you use any kind of dyno to make sure all the shocks are the same from the factory?
Yes, we check every damper with "dyno".
Very important: please check the tightening of SB25 screws on the back plate of the dampers regularly.
Damper switches to asymmetric mode in case of this screw is not tightened enough and rotates together with the output damper's shaft.
Oleg Babich is offline   Reply With Quote
Old 05-06-2014, 12:45 PM   #6347
MikeXray's Avatar
Trader Rating: 72 (100%+)
I'm not going to be doing much racing for a while, twin girls on the way in 6 weeks. So, I'm going to let one of my cars go instead of having it collect dust. PM me if interested.
Congrats and Condolences! Might as well start training for sleep deprivation now.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-10-2014, 04:17 PM   #6348
cosmokitten's Avatar
Default Clarifications needed for Kyle's Mod setup
Originally Posted by Magnet Top View Post
attached
Anyone happen to know te spring type that Kyle used for his mod setup?
Also, if I understand the setup sheet correctly, there is only one screw holding the rear gearbox to the chassis?
Would this mod setup work with a 4.5 motor (Kyle used a 7.5) at a track like Port Jervis NY?
Please confirm.
Thanks!
cosmokitten is offline   Reply With Quote
Old 05-10-2014, 07:01 PM   #6349
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Please confirm.
Thanks!
Soft springs as per the setup sheet, and look like all the screws are in except the 2 outer motor mount ones. Would see why that wouldnt work with a 4.5, im going to run it with a 5.0
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 05-10-2014, 08:05 PM   #6350
Thanks Mr.Canadian!
I'm wondering whether we're looking at the same setup sheet? The last one on awesomatixusa website. Nothing is chosen for the spring type and the last 4 holes on the chassis are not colored red, thus no screws? and all motor mount holes are colored red, meaning all 4 screws used.
Just wanted to make sure that I am indeed looking at the latest and greatest sheet.
Appreciate, thanks!
Are you planning on going to Port Jervis as well? If so, we would be the Canadian contingent...
Old 05-11-2014, 01:16 PM   #6351
hanulec's Avatar
Trader Rating: 23 (100%+)
cosmokitten - you'll find a TON of Awesomatix cars down at Jackson RC in Jackson, NJ (about 110m south of port jervis). i hear there is an all electric race being planned there .. so you'll probably see a few more Awesomatix cars at that upcoming event.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-11-2014, 03:07 PM   #6352
Has there been any talk about making the AM15-1 out of carbonfiber instead of aluminum or as an option?
Colin Roussel
Old 05-11-2014, 03:30 PM   #6353
hanulec's Avatar
i think you mean the AM05 (rear body mount -- mustache shape)
the cars previously had carbon rear body mounts but they were fragile -- didn't bend, just broke.
Old 05-11-2014, 04:54 PM   #6354
Thanks Hanulec! Will look into it...
I have a question when using P06-1 on raceberry chassis. P06-1 is obviously too high (long) for the slim raceberry chassis. What are racers doing about this?
Myself, I just left the extra length on top of the chassis (P06-1 is sticking out on top), does anybody see any issues with this?
When using P06-1 is alu chassis, is it still recommended to glue it on? or perhaps the new divot will suffice to keep it in place?
Appreciate, thanks!
Old 05-11-2014, 05:05 PM   #6355
hanulec's Avatar
Appreciate, thanks!
the P06 / P06-1 is too long for both the C01AL and Raceberry. If you insert the P06 from the top of the chassis, then just cut off the excess at the bottom.
P06 and P06-1 both require glue so they don't move up/down and change your droop.
Old 05-11-2014, 09:19 PM   #6356
Any ETA on the backordered Raceberry's from awesomatix USA?
Ricky Garner
Sponsors: My Wife and AVID RC
Mclarein is offline   Reply With Quote
Old 05-12-2014, 05:14 AM   #6357
hanulec's Avatar
Product was shipped day before the ETS race. Fingers crossed -- any day now.
Old 05-12-2014, 08:00 AM   #6358
Awesome, thanks
Ricky Garner
Old 05-12-2014, 10:47 AM   #6359
JayL's Avatar
hanulec: Please import the new digital caster gauge they showed at ETS
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 05-12-2014, 10:54 AM   #6360
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
That is a huge waste of time and money IMO. First and foremost your pit table will have to be perfectly level.
Second. That things looks heavy and large. When screwed into the steering it will be hanging off the backside and due to the weight will most def be twisting the whole setup downwards creating extra caster angle.
The doodles are fine IMO. If your caster is off by .2 believe me you wont notice.
Unless of course spending unnecessary money is something you are looking to do then by all means. Buy it.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17199 Today 02:45 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
