Like Tree25Likes
Old 04-29-2014, 04:50 AM   #6256
Dragobrat's Avatar
Default gd1
Hi , first time I have heard of only running 2x of the spider gears.
Are you finding that you still need to shim the main gears?
Thanks.
Originally Posted by oeoeo327 View Post
Metal gears for GD1:
Outdrive Gears - G05ST 20T Steel Gear x 2
Spider Gears - G06ST 10T Steel Gear x 4
Since switching to metal diff gears, I only use 2 spider gears. If I were driving the car in mod, I'd probably rebuild the diff to use all 4 spiders...
Dragobrat is offline   Reply With Quote
Old 04-29-2014, 06:05 AM   #6257
hanulec's Avatar
Trader Rating: 27 (100%+)
Thanks.
when running metal gears w/in the GD1, i don't ever re-shim.
when you install only two of four small satellite gears you will produce the smoothest possible GD1 diff with metal gears. to offset the removal of two gears, you must increase the thickness of your diff oil to have the same overall feel. i believe 5K CST w/ a GD1+2 gears feels like it is softer than 3K but harder than 2K in a GD1+4 gears
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-29-2014, 02:26 PM   #6258
JayL's Avatar
Any of the guys that ran the Speedtech race at Tamiya post up their setup, 13.5?
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-29-2014, 04:05 PM   #6259
Dragobrat's Avatar
Thank you Sir, that's really great info.
Old 04-29-2014, 08:16 PM   #6260
gijoe64's Avatar
Trader Rating: 30 (100%+)
Hey, has anyone used shorty packs in there A700L Spec? If so how do you like it and what are the disadvantages?
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 04-29-2014, 08:20 PM   #6261
hanulec's Avatar
there is no good way to mount a shorty pack on the 'L' chassis. this can be done easily on the 'EX' chassis.
a shorty is 202g, a mod pack is 280g, a stock pack is 330g. this will likely just make one size of your car super light/off balance.
Old 04-29-2014, 08:24 PM   #6262
Travis S's Avatar
Trader Rating: 46 (100%+)
The L doesn't have stock mounting options for a shorty pack. The EX chassis does with the option to put the servo in front of it.
^^^ looks like someone was faster then me.
Travis S is offline   Reply With Quote
Old 04-29-2014, 08:41 PM   #6263
geeunit1014's Avatar
Also, shorty batteries do not have the horsepower big packs have...
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-29-2014, 08:43 PM   #6264
KHoff7's Avatar
What about the size, are the differences outweighed?
Please Respond,
Regarts
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 04-29-2014, 08:57 PM   #6265
Travis S's Avatar
The higher mah battery you run the longer your battery will be at a higher voltage while racing. The higher the volts the more punch/power you will have. In stock this is big in mod not so much. So unless you are trying to drop weight in the car there is no reason to pick a shorty IMO.
Old 04-29-2014, 09:01 PM   #6266
gijoe64's Avatar
Thanks guys I understand and will be using standard packs.
Raymon Robinson
ARC, LRP Go Blue!!
Old 04-29-2014, 09:29 PM   #6267
Suspended
Not quite true !!! In stock 17.5t a 3300mah TP(208gram)) pack is very competitive with any other overweight pack out there..... I've tested tp5300 packs vs the 3300's and there was no real difference at all after six Minutes..... It's the myth that they use to get your money !!! LoL.....
bertrandsv87 is offline   Reply With Quote
Old 04-29-2014, 09:54 PM   #6268
KHoff7's Avatar
Have you compared side-by-side with sanyo 3300 product?
Karl Hoffmeister
Old 04-29-2014, 10:07 PM   #6269
kartermdb's Avatar
Trader Rating: 15 (100%+)
What about GP 3300's?
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-29-2014, 10:33 PM   #6270
Travis S's Avatar
I am not saying to get some 10000mah pack that will make your car overweight for stock racing, but I am saying if you use the larger MAH pack that you should have more volts going to your motor then a lower pack toward the end of the race. So I would run the largest MAH pack you could get that keeps you at or under weight.
Simple test is to run your 3300's and then see what the voltage is at the end of a 6 min run. Then run your 5300 for the same time see what your voltage is after and compare the 2. The 5300 should come off with higher voltage then the 3300, thus theoretically you have more volts or power going to the motor...
So I would just save that 3300 for your 2.5 mod car since it must be awesome.
If you are not consistent driver and spend a lot of time hitting crap then the little gain of the higher MAH/Volts won't make a difference anyways... I don't know your driving skills but maybe that is why the 3300 is the same at your 5300 or maybe that pack is not very good.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
