Like Tree25Likes
Old 04-18-2014, 01:48 PM   #6166
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Awesoman View Post
Hi all,
I've been testing my Evo on a big asphalt track.
I'm using the standard setup for the Evo, which is designed for carpet.
I don't have enough steering off power and my rear end gets loose every time I hit the brakes or get out of the corners. The only difference to the standard setup is my diff oil. I'm running 1000cst.
I'm running non-boosted 10.5 and a Speed6 shell.
Can anybody please give me hints to get the car dialed in? It's really undriveable at the moment
Cheers.
I don't really know what the kit setup is... So please post a setup sheet and include tires info.
Try-
More rear droop
More front droop
Lowering the front lower balls as compared to the rear lower balls
Dial down your brakes in esc or start using drag brake. If your car sides under braking then that is a huge problem.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-18-2014, 01:59 PM   #6167
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Hey guys, what parts are needed to run a bearing in the ffg for smoother movement instead of that block?
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 04-18-2014, 02:02 PM   #6168
http://www.petitrc.com/reglages/awes...arpetSetup.pdf
You can find the setup under this link
Could the sliding under braking come from a diff problem, a problem with the gears?
Thanks for your answer
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 04-18-2014, 02:06 PM   #6169
You need a nut as used in the steering, a 1mm spacer, the bearing and a screw.
Awesomatix | LRP
Old 04-18-2014, 02:14 PM   #6170
hanulec's Avatar
What tires?
How is the surface prepped?
I don't think this will work outdoors. We have the worlds wa up setups now to post. They would be a better option. Will upload tonight.
My suggestions otherwise include---
You should be running "soft" springs - spr01s.
Hole #2 on the front camber links is better for steering response.
Lenghten your wheel base to 0 caster.
4mm of shim below am23 and at21 for rear toe link is too much of you have rear traction issues. Go to 1.75mm
On the center post perform 0.2mm of shimming front and rear instead of 0.
Old 04-18-2014, 02:15 PM   #6171
hanulec's Avatar
B74rs
St08
Misc screw and shims..
Old 04-18-2014, 02:18 PM   #6172
Thanks mike, as which alloy chassis would you recommend? Building evos for both stock and mod, is the hard coated chassis better?
Colin Roussel
Old 04-18-2014, 02:21 PM   #6173
Tires are Panaracer 36 and the surface isn't prepped at all.
These are the spec tires in France.
I will try what you said and thanks a lot.
Awesomatix | LRP
Old 04-18-2014, 02:44 PM   #6174
hanulec's Avatar
There is no perf difference. The hard coated was a limited run -- and sold out globally.
No track prep -- oh boy. That doesn't sound good. Is the dirt/dust blown off?
What about traction compound on tires?
I don't think we have any setups for un-prepped track. You need to make the suspension very soft. Look at the shock setup within--
https://docs.google.com/file/d/0B0Z2...U5NURWWTQ/edit
Old 04-18-2014, 05:18 PM   #6175
just ordered the FFG today, Will you have some of the chassis available at Reedy? Might have to spend the first night rebuilding.
WEEZY is offline   Reply With Quote
Old 04-18-2014, 06:20 PM   #6176
rosko's Avatar
Hi all,
Cheers.
An ltc-r would probably be a good idea instead of a speed 6
rosko is offline   Reply With Quote
Old 04-18-2014, 11:52 PM   #6177
G-rem's Avatar
Hi all,
Cheers.
Hi
here is my set-up sheet for a big un-prep asphalt track with a boosted 10.5t:
https://drive.google.com/file/d/0BzZ...it?usp=sharing
Compared to my set-up sheet, I suggest you to lower the rear lower balls as compared to the front lower balls in the front and in the rear (0.5mm is a good starting point); it will avoid the car getting loose at on-power steering.
I also suggest you to harden a bit the rear shocks and try a softer diff oil.
And as already said, a LTC-R will give you the steering you're lacking of.
PM me if you have any questions.
Best regards,
G-rem
G-rem is offline   Reply With Quote
Old 04-19-2014, 01:03 PM   #6178
We are alowed to use traction compound on the tires as well as tire warmers
The track isn't blown off at all and full of pollen and dust these months.
I will try to make everything soft, altough it already is quite a lot
Thanks!
@G-Rem
Thanks for the setup!
I will also try an LTC-R for more steering.
Awesomatix | LRP
Old 04-19-2014, 01:22 PM   #6179
G-rem's Avatar
Did someone already use the C01-Al chassis in stead of the carbon one on asphalt track? Wich works better?
Old 04-19-2014, 02:18 PM   #6180
hanulec's Avatar
i don't think we have a definitive answer yet. at the worlds warm up carbon chassis were better. i've heard from my friends in sunny regions of the usa that the aluminum chassis works really well. i think the next big test in the usa will be at the Reedy Race.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
