Old 03-23-2014, 12:57 PM   #6001
Originally Posted by haywood View Post
Second outing with the car and I am sitting 8th in the A going into the mains today. Pretty happy with the car and I'm enjoying learning how to tune it!
Might want to cut your wing down a bit, should give you a bit more speed.
HawaiiBob is offline   Reply With Quote
Old 03-23-2014, 01:42 PM   #6002
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
if you do that ,it also loose up the rear end...most of the racer like it tall rearwing for high speed out door track and stable rear traction
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-23-2014, 03:54 PM   #6003
JayBee's Avatar
Trader Rating: 31 (100%+)
+1
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-23-2014, 03:59 PM   #6004
G-rem's Avatar
Originally Posted by Quantra View Post
Do you find it frees the car up and lets it rotate better at all? I was speaking with an xray driver on friday who suggested I tried this to help my car rotate a bit better.
The rear rotation is a bit better, yes
G-rem is offline   Reply With Quote
Old 03-23-2014, 04:34 PM   #6005
Quantra's Avatar
Sweet, thank you. Time to build some more drive shafts then =]
Vince Coleman
Quantra is offline   Reply With Quote
Old 03-24-2014, 03:19 AM   #6006
ApexRCProshop's Avatar
a video of the FFG at RWC... a nice look at the suspension and FFG
video
Apex RC Exclusive North & South American Pro-Spec Distributor
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
ApexRCProshop is offline   Reply With Quote
Old 03-24-2014, 03:31 AM   #6007
kgombe's Avatar
http://youtu.be/A2VLxwHrEZs
here you go...
Kijana Crichton
kgombe is offline   Reply With Quote
Old 03-24-2014, 03:41 AM   #6008
Originally Posted by Jerry P View Post
I'm skipping the Reedy but will be at the Asphalt Nats and IIC so i'll see you boys in vegas.
AWW you need the Reedy... it will be fun...
Old 03-24-2014, 07:53 AM   #6009
oeoeo327's Avatar
Trader Rating: 70 (100%+)
I've been looking to upgrade the chassis on my A700EXL, and want to try the Raceberry hard chassis. It's described as working best with the newer Evo car, but does anyone know if I could use the Raceberry chassis to upgrade an older car?
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 03-24-2014, 08:41 AM   #6010
MikeXray's Avatar
Hey Barry, as I understand the AL and hard chassis are meant for evo with no top deck, I think without FFG you really shouldn't run without one.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-24-2014, 09:35 AM   #6011
Just about finishing my awesome new A700 Evo but I have two questions that have come up:
1. The setup sheet shows more holes than exist on the car. So if I am using a setup sheet how do the holes on the sheet align with the ones in the car? ie outermost holes line up and you count inward from there?
2. The camber links seem long and I'm having difficulty tightening them up enough for appropriate camber while using the second from outermost hole on the car. Is there an upgrade/alternate set of camber links to use in those situations?
trackout is offline   Reply With Quote
Old 03-24-2014, 09:45 AM   #6012
geeunit1014's Avatar
1. The setup sheet shows more holes thbulkhead.2n the car. So if I am using a setup sheet how do the holes on the sheet align with the ones in the car? ie outermost holes line up and you count inward from there?
For the rear, The 3rd shortest hole on the sheet is the shortest hole on the bulkhead. The 2 shorter holes come from the optional am19 or am18-1 mounts. The front should be correct, the 3rd hole is the countersunk hole used to attach the mount to the bulkhead.
Putting a little grease on the threads of the turnbuckles will help. You should be able to use the kit turnbuckles with the shortest hole on the bulkhead in the rear and the 3rd hole on the front. You will need different ones if you want to use the optional mounts. would suggest getting Lunsford turnbuckles if you want to get optional ones.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-24-2014, 09:57 AM   #6013
MikeXray's Avatar
Hey Gee, what settings to you tend to adjust for fine tuning a setup once you're set on the big changes?
Old 03-24-2014, 10:04 AM   #6014
Mainly springs and droop. Although it depends on what you define as a big change. At the track I'll change almost anything but shims on the lower arms and diff oil, only cause those are a pain in the butt I don't really consider anything to be more of a big change than anything else, I just try to see and feel what the car does on track, and then make the appropriate adjustments
Mike Gee
Old 03-24-2014, 10:35 AM   #6015
oeoeo327's Avatar
Hmmm... I was thinking if the bulkheads were located the same distance apart on either chassis, it wouldn't matter since you'd be able to use the top deck if your application requires one. The only thing I hadn't researched is whether or not the FFG bulkheads mount the same distance apart from front to rear, and utilize the same mounting points.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17203 Today 04:17 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
