Like Tree11Likes
Old 03-11-2014, 06:23 PM   #5911
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Magnet Top View Post
Yes !
our track is awesome No boards
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-11-2014, 06:55 PM   #5912
Magnet Top's Avatar
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 03-11-2014, 06:59 PM   #5913
Travis S's Avatar
Trader Rating: 46 (100%+)
You have it backwards. A is the lower and B is the upper.
See attached picture.
Ahh I will fix that post now. Hopefully the visual is helpful to people.
Travis S is offline   Reply With Quote
Old 03-11-2014, 07:08 PM   #5914
Like this Jake!
Kody is offline   Reply With Quote
Old 03-11-2014, 07:10 PM   #5915
Magnet Top's Avatar
Old 03-12-2014, 05:11 AM   #5916
Quantra's Avatar
Here's how I consider the operation and set up of the Awesomatix dampers.
The damper and spring are a unit. The damping value is fixed by the oil viscosity within the damper. The spring value is variable, we can change it by altering the B value which I call the spring gap. Changing the B value changes the effective leaf spring length. The shorter the leaf spring the stiffer it becomes, we can validate this by holding a ruler (leaf spring) over the edge of a table and pressing down on it whilst altering it's length.
The A value then changes the leverage applied to the whole unit. More leverage is achieved with a smaller A value and the greater the leverage the softer the spring and damping will feel. I guess this is more synonymous with moving conventional shocks in and out on the lower arm than it is laying them down on the shock tower.
The way I think the set up sheet works is that it produces a wheel rate based on the leaf spring length and lever length acting on that leaf spring. It does not include the resistance felt from damping. So when setting the shocks so the wheel rate is the same but damping is different does produce a different feeling shock, due to the different resistance from different damping. Perhaps a way to validate this is to remove the spring and feel only the damping at different A values.
Hanulec - I get what you are saying, I guess all I disagree with is that I'd expect them to feel different with different damping values at the same spring rate. I have big respect for you if you can push down on a car and then translate that feel onto your own car. It's something I tried for many hours when I got my first Awesomatix, as I wanted to match it to my xray but I could never get there. Very interesting to see how different people take different approaches and ways of thinking of things, hopefully there is something for everyone =]
Vince Coleman
Quantra is offline   Reply With Quote
Old 03-12-2014, 06:50 AM   #5917
MikeXray's Avatar
Trader Rating: 73 (100%+)
It maybe hard to feel a small difference when you are in the range and close, but I realized my car was setup in the stiffer range, but I had put on the softer range settings by doing the press test on JerryPs car. I didn't have time to swap the screws, so I set it by feel to get close, and the spring was almost maxed out.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-12-2014, 10:46 AM   #5918
hanulec's Avatar
Trader Rating: 25 (100%+)
Setup sheets from 17.5T ROAR National Champion Kyle Klingforth now available-
http://www.awesomatixusa.com/p/setup-sheets.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-12-2014, 11:43 AM   #5919
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Travis S View Post
I was thinking the same at first, but when you move A in or out, the distance on B or the "hook" does not change.
However, if you look these 2 pictures. The first one shows B = 3mm A = 3mm making the spring rate = 108.4 gf/mm
If you just change the A to 4mm that now makes the spring rate 117.6 gf/mm
Now if you want to increase A but keep the same spring rate you would also need to change B to 3.9mm. (I know .9 is not an option with the gauges but this is just for demonstration.)
" B " is a "passenger" of " A " ( the carrier ).
Simply, for example : if the goal is to maintain spring rate but change damping rate : Move " A " some distance , then move " B " the equal distance but OPPOSITE direction.
( Note. " B " is the position of the RHS ( ride height screw ). The RHS acts as the leverage point on the "leaf" style spring that determines spring rate )
So if you move " A " 2mm East, then move " B " 2mm West. You have successfully changed your damping rate and kept your spring rate exactly the same as before you started.
The only issue comes up when you don't have enough adjustment range in "B". So you sometimes have to use SRS I or SRS II depending on what you are trying to accomplish. The difference between SRS I and SRS II is 4mm.
Jake D.
This is great information guys!! Thank you
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-13-2014, 06:20 AM   #5920
Quantra's Avatar
Just wanted to say another big thank you to awesomatixusa.com for shipping another order out to me in the UK. One of the few places in the US I order from as they are very efficient and have cool things I can't get in the UK like the BSR hard bumper. Also a great price on WTF fans. It is worth doing a bigger order though to make full use of the postage costs but if you aren't in the US and need some Awesomatix goodies don't overlook awesomatixusa.com =]
Not often I go around plugging rc shops but I'm always impressed with the service so thought I'd share the love <3
Vince Coleman
Old 03-13-2014, 08:46 AM   #5921
Congratulations for Simon Noton who TQ'd and won the 13.5 boosted class and for Jamie Holmes who was 2nd at the New Zealand National championships!
https://www.facebook.com/awesomatixRC
Oleg Babich is offline   Reply With Quote
Old 03-13-2014, 01:13 PM   #5922
G-rem's Avatar
Oleg, any availability date for the relase of the Awesomatix servo? I need a new one and will be interested in it ;-) what about its specs?
Are G07 and G08 the pinions for GD2 diff (and WA02 and WA03 the washers that suits the best for it)? So no need the Xray parts anymore if so?
Any other new items to come?
Cheers,
G-rem
G-rem is offline   Reply With Quote
Old 03-13-2014, 08:20 PM   #5923
skypilot's Avatar
Trader Rating: 14 (100%+)
Jake D.
SERIOUSLY? dude what have you done to me.... you don't expect me to try and learn this or remember it do you. Say Hi to your pit table sharing mate. AKA your shadow
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 03-13-2014, 08:30 PM   #5924
You can try to retrofit your ARC shock towers and shocks onto your car
malkiy is offline   Reply With Quote
Old 03-13-2014, 09:40 PM   #5925
Magnet Top's Avatar
Great job guys ! New Zealand National Champion and Runner up too !
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
