Old 03-04-2014, 10:07 PM   #5836
WillieSTi's Avatar
Originally Posted by WillieSTi View Post
Need Help!
FFG shaft is rubbing my servo ear. I'm using KO servo. see photo attached.
Is floating servo the solution? I did cut about 1mm of the ear look like will ok for now.
Willie S.
Yokomo
WillieSTi is offline   Reply With Quote
Old 03-04-2014, 11:49 PM   #5837
G-rem's Avatar
When using the floating servo mount, you have to cut the upper ear of your servo, so no problem anymore ;-)
G-rem is offline   Reply With Quote
Old 03-05-2014, 07:02 AM   #5838
bkspeedo's Avatar
You should only have to cut the servo ear if your using the center servo mounting position. If you use the offset position no mods area required to the servo.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 03-05-2014, 09:24 AM   #5839
I've found when running the FFG it is good to make room for the drive shaft even when running the outer mounting position. Gives the FFG plenty of room to move around and the drive shaft stays clear from the servo. AM24 floating servo mount does make it a little easier.
K
Kody is offline   Reply With Quote
Old 03-05-2014, 01:00 PM   #5840
haywood's Avatar
Trader Rating: 48 (100%+)
Default Gd1
I haven't ran the car yet but I notice a little diff fluid leaking out of one of the outdrives. Any fix for this besides buying the Gd2? :-) Would green slime on the o rings help?
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 03-05-2014, 01:35 PM   #5841
Originally Posted by hanulec View Post
Just a quick note. Forgot to mention I did use the Spur Dampening System. One spur gear lasted with taps and tumbles all weekend!
Kody
Old 03-05-2014, 02:08 PM   #5842
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Mine was doing the same thing. I took it apart and cleaned everything and coated the out drives inputs with green slime and inside of the halves where the bearings go and orings and I even put some on the threads near the oring so when the diff halves are threaded and assembled it would further seal it up and have yet to have a leak.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 03-05-2014, 04:47 PM   #5843
Jerry P's Avatar
Trader Rating: 44 (100%+)
There is 1 one Evo available on http://shop.awesomatixusa.com/ get it while it's hot!!
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 03-05-2014, 07:12 PM   #5844
Originally Posted by Navi View Post
I have my A700 Evo just finished the assembly and had run it for two days. I like this car so much but there are many areas that the instruction manual has not provided the needed information. I hope to get the answer here.
1) When should we increase the gap between AM49 and AM48/ AM50? what is the effect if we just increase gap at front AM48 or at rear AM50?
2) the optional top deck C21 is supposed to use on high traction condition correct? Then when to use the smaller top deck C18 ?
Thanks.
Resending.... May I get some help please ?
Navi is offline   Reply With Quote
Old 03-05-2014, 07:18 PM   #5845
hanulec's Avatar
Trader Rating: 23 (100%+)
this will adjust how weight is transferred front/rear and how the car twists around the center post. small changes have big benefits here. you're adjustments should be in 0.1/0.2mm differences. try the adjustments yourself -- or just stick to a 0.2mm gap and call it a day.
totally moving the dt04 collars away from the am49 will produce a ill handling, pushing car.
c18 is a brace, not a top deck. again, this adjust how the car flexes. i haven't tired it, but if it like any of the braces we tried against the C02-1, it will definitely make you loose rear bite under power.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-05-2014, 08:20 PM   #5846
hanulec's Avatar
Brent Klingforth's 2014 Carpet Nats setups are now online--
http://www.awesomatixusa.com/p/setup-sheets.html
Old 03-05-2014, 08:50 PM   #5847
josecarlo1129's Avatar
Kody
If I may ask, what brand of spur gear are you using? I am using a certain 'brand' but needs some mod to clear in the SDS. TIA. Cheers
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 03-05-2014, 09:11 PM   #5848
hanulec's Avatar
JC
"Spur is a Panaracer 96. Bought from Amain in the Yokomo package."
The Xenon TC 96T is the same thing if you look around you'll fin them available..
Old 03-05-2014, 09:59 PM   #5849
Cheers, Mike.
Old 03-05-2014, 10:55 PM   #5850
Questions??
Will any other Awesomatix Drivers be joining Brian Wynn at the Canadian On Road Nationals in Welland Ontario Canada near Niagara Falls?mThere are presently 73 Stock TC, 31 Super Stock, 21 Mod TC and 63 21.5 Powered Canadian Vintage TransAm entries to date. The Race is at the Centre Court of Seaway Mall. The Race starts a week from this Friday.
Paul - Xray, Keven - Associated, Andrew - Yokomo, Martin - CSO and other drivers will be there in Mod TC and Super Stock.
I'm sure many Canadian Drivers would like to see Awesomatixs in action.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17210 02-19-2017 03:16 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
