Old 02-25-2014, 06:24 PM   #5746
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by haywood View Post
I think this maybe a long frustrating build when my first step is to dremel on the brand new chassis plate! Ugh!
You don't know this but it is so much better then trying to glue them in place and not making a mess with CA. Also I have had issues with the glue not even holding when trying to change droop...This is a good change. It does stink the chassis isn't just made this way.
Travis S is offline   Reply With Quote
Old 02-25-2014, 06:42 PM   #5747
Quantra's Avatar
How important is the 0,25-0,5mm chamfer?
I'm not sure but with a needle file it shouldn't take long to put in. The chassis I did yesterday already had it, the other one I did was an alloy chassis which is ready cut for these.
The way I did it was to file the new cut in until I could see it (this took about 10-15mins each hole with a 1.5" long file -.-). Then try and push the insert in a little with my thumb. If I couldn't get it in then I used a watch makers screwdriver and slid the insert onto it and supported it on the handle. This way it was easier to keep it straight whilst applying some force. If I could not get it in like this I filed some more. Once it was in a little way I turned the chassis over and pressed down on it, on a hard surface, until it went it.
When the insert is seated fully pop the grub screws in and slice off any insert sticking out the other side.
If it wasn't for the filing it's much faster build, more reliable and tighter than glueing in the round ones =]
Vince Coleman
Quantra is offline   Reply With Quote
Old 02-25-2014, 07:24 PM   #5748
geeunit1014's Avatar
It doesnt have to be super accurate, just enough to fit the p06-1 in
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-26-2014, 11:53 AM   #5749
I notice there are two aluminum chassis listed. C01AL and C01AL-H. Are there any identifying features that differentiates one over the other?
malkiy is offline   Reply With Quote
Old 02-26-2014, 12:08 PM   #5750
chiefj48's Avatar
ok I'm at step 6. and if I use the SF3x8 for the AT21's the screw is too long. if I use SF3x6 it's about right, but AT21 still spins freely for the rears. I know the front uses a SH0.5 spacer, and should take up the free spinning. am I doing something wrong??
chiefj48
Home of the; 2016 ROAR On Road Asphalt Nationals
Special Thanks to , Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 02-26-2014, 12:15 PM   #5751
syndr0me's Avatar
Trader Rating: 32 (100%+)
According to the mothersite, the H is hard coated.
syndr0me is offline   Reply With Quote
Old 02-26-2014, 01:27 PM   #5752
Quantra's Avatar
6mm counter sunk screws should work fine without spacers. That's what I have with the carbon and alloy chassis, I run without spacers front and rear.
I should be able to start a 3rd EVO build next week... Going to be able to do these in my sleep soon =] Such nice cars to build, I wouldn't mind doing 1 a week xD
Vince Coleman
Old 02-26-2014, 01:40 PM   #5753
Yes I know it's hard coated but is there an identifying feature that differentiates the normal from the hard. I was hoping color or texture.
Old 02-26-2014, 01:57 PM   #5754
Hard coating of C01AL-H chassis is true black.
Oleg Babich is offline   Reply With Quote
Old 02-26-2014, 08:47 PM   #5755
hanulec's Avatar
Trader Rating: 23 (100%+)
Awesomatix now available at Stormer Hobbies
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-26-2014, 08:57 PM   #5756
JayBee's Avatar
Trader Rating: 31 (100%+)
That's very welcomed news!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-26-2014, 10:39 PM   #5757
WillieSTi's Avatar
why kit is cheaper in SH?
Willie S.
Yokomo
WillieSTi is offline   Reply With Quote
Old 02-26-2014, 11:49 PM   #5758
Smile
Thank you Lord !!!!!!
bertrandsv87 is offline   Reply With Quote
Old 02-27-2014, 01:06 AM   #5759
G-rem's Avatar
Is there any advantage of getting the hard coated chassis in term of "abrasion resistance" in comparison with the normal alloy one?
Can we have pics of both to well see the difference of colour?
Will Freddy and Viljami use the alloy chassis this weekend at the ETS? Have any of you already used the alloy chassis on asphalt? Better results than carbon one?
Thanks for all,
Best regards,
G-rem
G-rem is offline   Reply With Quote
Old 02-27-2014, 02:48 AM   #5760
Thanks for all,
Best regards,
G-rem
Hard coated chassis ( hard anodized) is much more "abrasion resistance" of course.
The pics will be available soon. But "black" is the black and the regular alloy chassis has the same colour as all our "dark gray titanium" alloy parts.
Freddy and Viljami will not attend this weekend at the ETS.
Both are very busy at their main jobs at the moment.
LRP TCM will be the next race for Freddy and Viljami.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17198 Today 01:13 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
