Like Tree21Likes
Old 02-09-2014, 04:10 PM   #5596
RichFox's Avatar
Thumbs up
Does anyone have a good basic setup for asphalt with EVO 17.5
RCAmerica l Xray l Hudy l T4 14 l Futaba
RichFox is offline   Reply With Quote
Old 02-09-2014, 04:16 PM   #5597
hanulec's Avatar
Trader Rating: 27 (100%+)
Rich-
I believe Evo asphalt setups will be coming soon. We got a few guys running them in Florida and California right now.
Otherwise, an A700L/EXL setup will work no problem.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-09-2014, 04:41 PM   #5598
geeunit1014's Avatar
Ran my Evo in 17.5 on carpet yesterday. Even for slower motors, it makes a big difference in how smooth it is. It is simply amazing. Cant wait to be able to run it in mod.
Like FJ said, older setups are a good place to start, just be sure to add the extra 1.5mm shims on the front upper links, and try to find one with the tires you will be using
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 02-09-2014, 05:15 PM   #5599
RichFox's Avatar
Thumbs up
The EVO front is 1.5mm lower than the others correct?
Old 02-09-2014, 05:23 PM   #5600
Where the upper arms mount, yes
Mike Gee
Old 02-09-2014, 05:24 PM   #5601
hanulec's Avatar
it depends. there is what i remember -- off the top of my head.
there are three non-Evo upper camber link options, so when using the FFG instead--
1. am01-1 (bulkheads) ->> and remember, the front front doesn't have a 2mm top deck on it ---- ADJUST by 1.5mm
2. am19 --- ADJUST by 0.3mm (or 0.5mm)
3. am18-1 --- NOT SURE -- i don't run am18, but i assume adjust by 3.5mm
Old 02-09-2014, 05:28 PM   #5602
hanulec's Avatar
Gee- i'd like to see what setups you end up with. i do think the car is smoother under power.
PLEASE NOTE - at Snowbirds, a few of us had issues w/ our FFG and having the front drive axle (st13) pop out of the spool because we were putting 1mm of shim under the AM06S (between the lower ball). This would cause issues when you say drill the chicane at full speed . This happened a few times to me before I said --- I guess I cannot 'just not hit' those boards. (this ended a few of my 13.5t tc runs..)
The alternative Oleg suggested was to add the 1mm shim under the carbon arm balls (at21/at21s) instead of under the AM06.
Old 02-09-2014, 06:01 PM   #5603
Still working on setups. New parts plus getting used to the team powers tires means there is still room for improvement before I put something out with my name on it
Mike Gee
Old 02-10-2014, 05:30 AM   #5604
Recommendations to users of FFG based on the several latest crash tests:
#1. Use P10 covers on the front FFG gearbox as the measure against the outdrives popping out and the front G03 gear damage.
or
#2. Insert ~2,7x11,4mm plastic or metal pins (cutted pieces of plastic tube or rod for example) in the central axial holes of ST07 on your AT03 spool.
or
#3. Use #1 and #2 together for maximum protection.
All these measures restrict the excessive torsion twisting of FFG gearbox at crashes.
#4. As the additional measure please use the suspension up travel limiters (upstops) on the front P12 sway bar holders. 14mm upstop is the good limit for this.
Oleg Babich is online now   Reply With Quote
Old 02-10-2014, 07:25 AM   #5605
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Is there a setup for a track with a high speed bump coming out of sweeper that leads to the straight? The car doesn't seem to have the proper dampening.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 02-10-2014, 05:15 PM   #5606
hanulec's Avatar
care to share your setup...
Old 02-10-2014, 05:24 PM   #5607
WillieSTi's Avatar
or
or
Oleg: My Evo kit is missing P10 covers. That means I need to wait to drive my car until Mike have them stock right?
Willie S.
Yokomo
WillieSTi is offline   Reply With Quote
Old 02-10-2014, 05:38 PM   #5608
No, you can drive it now. These are just precautions to take, especially if you run shims under the am06/am06s (like I like to do), to keep to dogbone ends from coming out of the outdrives if you hit something. I ran mine without any of these this past weekend with no issues, but I didnt run any shims under the am06/am06s.
Mike Gee
Old 02-10-2014, 06:35 PM   #5609
WillieSTi's Avatar
Great! Thank you Mike
Willie S.
Yokomo
Old 02-11-2014, 05:41 AM   #5610
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
hanulec,
when will the complete spur dampening system be back in stock?
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
