Like Tree11Likes
Old 01-23-2014, 10:26 PM   #5386
Morning guys,
They will only fit into the GD2! Please note this.
They work fine and the small difference compared with the plastic gears is the weight.
The car is a little bit easier to drive but has also less on power steering. It's another good setup thing to play with.
Plastic gears: more steering and little less rear traction
Metall gears: less steering, very easy to drive
I recommend to use #2000-#3000 oil inside.
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 01-23-2014, 10:41 PM   #5387
syndr0me's Avatar
Trader Rating: 32 (100%+)
The discussion tonight is whether or not 17.5 sedan needs to be split into shaft and belt classes, kinda like we did with boosted and blinky.
The Evo was really good tonight in club racing. The grip came up more than usual and traction roll became a real problem for me. I imagine a softer shock package might help. I tried less front camber and a wider front and still flipped twice in the main with the lead. With Sweeps, though, it sure seems like glue is the only real fix.
syndr0me is offline   Reply With Quote
Old 01-23-2014, 10:41 PM   #5388
Thanks Freddy...
bertrandsv87 is offline   Reply With Quote
Old 01-23-2014, 10:47 PM   #5389
Talking
For traction rolling issues low roll Centers + softer springs + widest track width + gluing tire edges Work everytime !!!!
Old 01-23-2014, 11:08 PM   #5390
When my car traction rolls I always use, before I make any setup change, super glue on the front tire sidewalls.
Setup changes are always bad as you must do a compromise somewhere which results most time in slower laptimes. You don't want to loose steering, rear traction etc so stay with the setup and try supre glue on the sidewall.
Also a front gear/ ball diff will help against traction roll.
Freddy
LRP - Awesomatix
Old 01-24-2014, 12:03 PM   #5391
Ive been reading and watching for sometime now and have two minor question left ....
Im seeing the A700 US Spec and a A700L listed seperately .... I run indoor rubber 17.5
Whats the difference and/or preference and why?
Last question ... what doesnt come with the kit that is good to add on?
Sway bars - Spool - 2/4 gear rear diff - Different top plate for flex (ive read about cutting the top plate) -
Appreciate the help
Robbob is offline   Reply With Quote
Old 01-24-2014, 12:47 PM   #5392
bkspeedo's Avatar
Appreciate the help
Check out Hanulec's racerlog. Here's a list of parts to buy right away and in the future.
http://racerlog.com/wiki/Awesomatix_...2F_Consumables
Suggested add-ons from the start
G05ST, G06ST - Metal Gears for rear diff - http://shop.awesomatixusa.com/a700-g05st.html, http://shop.awesomatixusa.com/a700-g06st.html
AM24 - floating servo mount - http://shop.awesomatixusa.com/awesom...a700-am24.html
Extra hard bumper - http://shop.awesomatixusa.com/awesom...am-bumper.html
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-24-2014, 02:12 PM   #5393
geeunit1014's Avatar
Appreciate the help
US spec comes with the am06s short hubs. Regular L kit comes with am06. Most of us run the am06s hubs. Kit comes with a spool and the sway bar sets. If you plan on cutting the topdeck getting a spare one may be good, Otherwise you don't need it. I run a non cut topdeck for carpet.
I would get the metal gears for the gear diff and the stiff front bumper, as well as some common spares and go from there
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-24-2014, 06:25 PM   #5394
hanulec's Avatar
Trader Rating: 25 (100%+)
http://www.cambergain.com/post/74438...awesomatix-usa
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-24-2014, 06:35 PM   #5395
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by hanulec View Post
Wow...Congrats FJ.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 01-24-2014, 06:57 PM   #5396
syndr0me's Avatar
Outstanding!
Old 01-24-2014, 07:59 PM   #5397
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
bamm...
wow...that is some news...
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 01-25-2014, 02:00 PM   #5398
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by olhipster1 View Post
bamm...
1+
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-25-2014, 03:26 PM   #5399
Ultra_Aussie's Avatar
Is there an upgrade kit that you can get to take the original released A700 to current spec? I might have access to an unbuilt A700 kit at a very good price so keen to know if there is a kit or what the list is of parts that must be replaced and are good to replace. Thanks
Ultra_Aussie is offline   Reply With Quote
Old 01-25-2014, 09:35 PM   #5400
hanulec's Avatar
Upgrade #1
A700 to A700L Conversion Kit
Upgrade #2 (optional, but will bring you upto the Evo Kit)
FFG Upgrade
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
