Like Tree21Likes
Old 12-06-2013, 07:39 PM   #4951
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
3.5mm above the chassis, I'd think there would be something wrong if they were below the chassis
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 12-07-2013, 12:31 AM   #4952
Originally Posted by SavageCanadian View Post
Hey guys, I picked up a EXL and cant wait to get it on the track!! Just a question, on the setup im putting on the car, the downstop says 6.2mm and 5mm, with a ride height of 5.5 all the way around. What is this measurement measured from? I cant for the life of me seem to figure it out.
Please note that all our European team drivers use the the downstop measuring method described in the Instruction Manual on the page #35.
So the downstop value in their setups is the distance from the chassis's bottom surface to the most outer lower edge of the arm.
I think that this is a very simple and straightforward method.
It does not allow dual interpretations and doesn't need any additional comments in the setup sheet in contrast to all others methods.
Oleg Babich is offline   Reply With Quote
Old 12-08-2013, 11:17 AM   #4953
Csaari77's Avatar
Trader Rating: 34 (100%+)
Got my car on track for its first run yesterday. I was pretty impressed. It was on pace with my previous car immediately. It was also very consistent and easy to drive. I didnt make a ton of changes to the Fairtrace setup, I mainly wanted to get a feel for the car yesterday. That being said, I managed to qualify 2nd in the A and finished 1st. I'm excited to see how much faster this car can get.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 12-08-2013, 01:01 PM   #4954
DS Motorsport's Avatar
For a custom car project I've been working on I hope to get the following measurement:
It's the distance from the inner bearing face till the center of the driveshaft pin. Basically the driveshaft length between upright and the outdrive.
I want to fit DJ CVD's to my custom car and the Awesomatix DJ's impressed me the most when I had my A700.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-08-2013, 08:35 PM   #4955
Old 12-09-2013, 12:55 AM   #4956
yumlailai's Avatar
How do you adjust ride height on this car?
Thank you
yumlailai is offline   Reply With Quote
Old 12-09-2013, 01:50 AM   #4957
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Thank you
Hi , we have 2 Screws by our damper.
One is the SRS (Spring Rate Screw) which you can change the spring rate setting.
The second screw beside is the RHS (Ride High Screw)! It is the screw which look more out....
Turn in the RHS to increase spring preload (car go higher)
Turn out the RHS to decrease spring preload (car go lower)
Hope this help you!
P.S. Here a screenshot from the manual
Best Regards
Max
!Mad Max! is offline   Reply With Quote
Old 12-09-2013, 07:54 AM   #4958
Trader Rating: 24 (100%+)
i just bought an A700 EX version new in the box... I race mostly carpet in the US here. What all sorts of parts would I need to get this thing to preform well ? narrow chassis? different hubs etc? I am new to this car as I have run an xray for a long time, but I wanted to try it out!
gocoogs is offline   Reply With Quote
Old 12-09-2013, 08:28 AM   #4959
Travis S's Avatar
Trader Rating: 46 (100%+)
The stock rubber 17.5 people mostly run the A700L USA spec. So that has the narrow chassis and lower hubs. I wouldn't go crazy with new stuff yet until you try it out the way it is. It's a great car stock. But I guess the only thing I would recommend is to be able to use shorter links that a lot of setups use:
AM-19 - http://shop.awesomatixusa.com/a700-am19.html
1-1/8" Turnbuckles - http://shop.awesomatixusa.com/lns1162.html
Also something I just changed over myself and it has made working on things so much easier are the Top Steel balls and ball cups http://shop.awesomatixusa.com/pa-hbs003.html and http://shop.awesomatixusa.com/tc-pmhs01.html
However, I have noticed a little more slop with these. If anyone has any recommendations on reducing this that would be great.
Travis S is offline   Reply With Quote
Old 12-09-2013, 08:52 AM   #4960
All Awesomatix kits for USA have the shorter AM06S hubs already.
In case of the traction level at your conditions (track+tires) is very high I recommend you the standard top links without the optional AM19 or AM18-1 ( please see the setups from Karl Hoffmeister and Kyle Bergstrom on http://www.awesomatixusa.com/p/setup-sheets.html).
For medium traction conditions the optional AM19 and shorter lower balls AT21S are useful but there are a lot of good setups that don't use these optional parts.
Your EX lower deck is good for all conditions, for stock and mod also.
Old 12-09-2013, 08:59 AM   #4961
erchn's Avatar
Thin plastic bag, put it over the ball and snap the ball cup over it. Less to no slop, still butter smooth and very simple to "install".
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 12-09-2013, 09:13 AM   #4962
Travis S's Avatar
Originally Posted by erchn View Post
Thin plastic bag, put it over the ball and snap the ball cup over it. Less to know slop, still butter smooth and very simple to "install".
Thanks! I will give that a try.
Old 12-09-2013, 09:40 AM   #4963
so im probably not the first one to comment on this, but Oleg, what are your thoughts on ball cups with holes in the top like the Xray? it seems like we are constantly adjusting roll centers and such and it would be way easier to be able to screw out the ball end with a hex than having to pop off the cup each time i want to adjust it 1/2 a mm. I guess i could just buy the xray ball ends and cups, but I am sure you guys have a reason for the choice you made... would appreciate any thoughts. thanks so much.
btw, i bought the A700 EX from a guy in Australia so it likely isnt the US version.. doh!
Old 12-09-2013, 09:44 AM   #4964
Travis, just read your note! thanks for the recommendation on the ball cups and ends... those seem to make a lot more sense!
Old 12-09-2013, 09:45 AM   #4965
Travis S's Avatar
Easy way to tell is if the hubs are silver they are the standard ones. If they are brown they are the short ones in the USA spec.
I think the Xray ball ends are not the same height as the stock kit ball ends, so this will have some effect on setup. The TOP Steel ball ends are the same height.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
