Like Tree13Likes
Old 11-25-2013, 01:21 AM   #4831
Originally Posted by Adam B View Post
I noticed an issue yesterday. The nut for the center bearing on the steering rack is rubbing the driveshaft. Only way I see to repair this is to shim between the steering rack and where it mounts. Am I missing something?
Please check: ~ 0,4 mm clearance should be between AT04 shaft and ST09 nut at proper installation and not damaged (bent) AM10-1 steering plate.
Oleg Babich is offline   Reply With Quote
Old 11-25-2013, 02:25 AM   #4832
Default AOC race
Just got back from the AOC final at Yatabe, What a great event! The car was great all weekend, qualified and finished 8th in the 17.5 A-main. Used Larry's Horsham set-up, the only change I made was to use 1.2 sway bars. Finals went okay, knew I could have finished higher, but got hit on the first lap in 1 & 2 and could work my way back to 8th. 3rd race had a great start, but made to many mistakes and finished 7th.
Patrick
XCELL is offline   Reply With Quote
Old 11-25-2013, 04:34 AM   #4833
Adam B's Avatar
Originally Posted by hanulec View Post
if folks haven't check out Karl H. setup from the Halloween Classic -- please do so. i took some aspects of this setup (swaybar and shock/spring) and applied it to my base setup this weekend. it was a bit quicker yet still easy to drive. i hope to apply the entire setup for this weekend...
That is going on my car for champs. Since I bought the car I have been using Larry's classic set up. BUT the champs requires sweep tires ran. Larry's set up seemed a little to aggressive for sweeps, even in the set up it states he used solaris. So my plan is a complete tear down and rebuild this week, then back to Cleveland.
Also thanks for your input Oleg I caught the problem. The nut had loosened up. I think it's great that you are active here on RCTECH, thanks sir.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 11-25-2013, 06:23 AM   #4834
KHoff7's Avatar
PRO TIP for anyone going to the indoor champs. If your car ever feels tippy glue the front sidewalls a little, don't overdo it though or your car will push. I used a little glue at the classic, it all depends on the grip level.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-25-2013, 07:30 PM   #4835
hanulec's Avatar
Trader Rating: 27 (100%+)
Write-up from the 2013 TimeZone Grand Prix
http://www.awesomatixusa.com/2013/11...c-gt-2013.html
Got option parts? GD2? AM12-1?
http://www.awesomatixusa.com/2013/11...nd-am12-1.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-26-2013, 10:56 AM   #4836
http://www.redrc.net/2013/11/2013-se...rt/#more-74339
Wow, I see Awesomatix logo on the winning TC cars.
Congratulations!
Old 11-26-2013, 09:45 PM   #4837
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi oleg,
what kit would i need for outdoor asphalt for best results
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 11-26-2013, 09:55 PM   #4838
hanulec's Avatar
Originally Posted by P.I.M.P View Post
hi oleg,
i think he would say the new A700 Evo -- coming out in December
Old 11-26-2013, 10:01 PM   #4839
Yes!
Old 11-26-2013, 10:32 PM   #4840
P.I.M.P's Avatar
thanks ill hold of till then
Vbc wildfire D06
clinton livingstone
Old 11-27-2013, 02:50 AM   #4841
hanulec's Avatar
If you cannot wait.. You can upgrade to the FFG later.
Awesomatix gives you great options like that...
Old 11-27-2013, 04:34 AM   #4842
Jerry P's Avatar
Trader Rating: 44 (100%+)
Great reason to run the awesomatix.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
Jerry P is offline   Reply With Quote
Old 11-27-2013, 05:01 AM   #4843
samshirley00's Avatar
i think when i sell my TRF 417V5 on ebay, i might get one, they look like very interesting cars, and they definatly can perform.
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 11-27-2013, 05:07 AM   #4844
Adam B's Avatar
Will this FFG kit be of any benefit in stock? I will probably buy another car for mod soon, but I can see how this could help in mod a lot.
Old 11-27-2013, 05:18 AM   #4845
Csaari77's Avatar
Trader Rating: 34 (100%+)
My new A700L kit comes home today! I can't wait to build it over the holiday weekend. It's going to be my first non-Tamiya kit in almost 10 years. Hopefully the performance is as good as everyone on this forum says it will be. I just could not get excited about the new crop of clones that everyone is producing, and this car is definitely not a clone.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
