Old 11-01-2013, 03:47 PM   #4666
yumlailai's Avatar
will there be a conversion kit from A700 EX to A700 EVO ??
yumlailai is offline   Reply With Quote
Old 11-01-2013, 04:03 PM   #4667
JayBee's Avatar
Trader Rating: 31 (100%+)
Some pages back, there was talk that there will be.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-01-2013, 05:18 PM   #4668
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by bkspeedo View Post
I'm having problems loosing swaybar mounts, P05. If you tap a corner hard enough with the wheel turned the wheel can turn in hard enough to hit the swaybar causing the mount to pop out and fall off the car. I've done a few things like put longer screws in the steering block to stop the wheel from turning in to far, and I've put the sway bar in upside down so the angle at the end is up versus down but everyone once in awhile I hit a corner just right and loose a mount.
hi brent - got few questions for ya---
#1 are you running a real front bumper??
#2 is there any play in your P04/C04 and the ball studs for the AM06(s)?
#3 when was the last time you replaced your P04? the P04 wear out, and if you unmount them, and send them down slightly you'll feel them tighten up again. this should help increase the life of the P04
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-01-2013, 05:49 PM   #4669
syndr0me's Avatar
Trader Rating: 32 (100%+)
Running an aluminum chassis on his Awesomatix, Sudhoff said it was a great way to start the new season. Describing the new A700L EVO as suiting his driving, he said the new diff has given him a very consistent car. Featuring a screw that allows the diff to be filled fully with oil and void of any air, this helps in a way he said that ‘only Oleg (the car’s Russian designer) can fully explain & understand’.
Very interesting stuff. Freddy has the pace to match Ronald which is no easy feat.
syndr0me is offline   Reply With Quote
Old 11-01-2013, 05:56 PM   #4670
Travis S's Avatar
Trader Rating: 46 (100%+)
aluminum chassis???
Travis S is offline   Reply With Quote
Old 11-01-2013, 06:25 PM   #4671
hanulec's Avatar
Originally Posted by Travis S View Post
aluminum chassis???
Yes sir..
Old 11-01-2013, 06:39 PM   #4672
I guess the aluminum chassis lowers the center of gravity even more than the CF chassis !!!
bertrandsv87 is offline   Reply With Quote
Old 11-01-2013, 06:42 PM   #4673
bkspeedo's Avatar
#1 - Yes, better than most actually
#2 - nope i check them periodically tightening down P04
#3 - I have not replaced one yet but i my mind it's not something i should replace on monthly bases.
I'm trying the heat shrink idea i had we'll see how it works.
Man i hope Freddy can keep up this pace this would be huge for Awesomatix.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-01-2013, 06:56 PM   #4674
I guess air in the gear diff causes cavitation just like in the shocks, which might make it inconsistant.....
Old 11-01-2013, 07:10 PM   #4675
Travis S's Avatar
Yes sir..
Pic's or it didn't happen.
Old 11-01-2013, 07:13 PM   #4676
I've seen it!
Monti
Monti is offline   Reply With Quote
Old 11-01-2013, 07:14 PM   #4677
hanulec's Avatar
Your only hope for pics is the ets race or Oleg... Sorry
Old 11-01-2013, 07:16 PM   #4678
hanulec's Avatar
It must be all of those speed tips we have him at IIC
Old 11-01-2013, 07:17 PM   #4679
Travis S's Avatar
Where was your aluminum chassis at the halloween classic??? Oleg is holden out on you. Oh wait I never did come look at that EVO you had there... A lot of man meat to pass to get over to your pit space. Did it have an aluminum chassis on it???
Old 11-01-2013, 07:53 PM   #4680
hanulec's Avatar
Aluminim chassis should happen ttomorrow for me...
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17202 Yesterday 09:34 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
