Old 10-27-2013, 06:12 PM   #4621
Magnet Top's Avatar
Originally Posted by Simon Noton View Post
Great, thanks Jake I thought as much.
Has anyone looked at running a combination of short and long links?
do you mean what is pictured ( see attached ) ?
or do you mean short on front suspension and long on rear suspension ?
Typically unequal length upper arms ( as shown in the attached picture ) is NOT used in favor of using shims under equal length upper arms ( see picture: 0mm and 2mm shims ). Both are ways to manipulate re-active caster but shimming is the preferred method.
In case you haven't seen , there are setup sheets here :
http://www.awesomatixusa.com/p/setup-sheets.html
here :
http://www.petitrc.com/reglages/awes...matixA700.html
and here :
http://awesomatix.com/download/
Cheers,
Jake D.
Awesomatix EP Touring Car (A700 Shaft Drive)-screen-shot-2013-10-27-5.09.07-pm.png
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 10-27-2013, 07:19 PM   #4622
I meant different lengths at either end of the car. The idea of short in the front and long in the rear. Steering through the shorter front but having the stability of the longer links in the rear?
Simon Noton is offline   Reply With Quote
Old 10-27-2013, 09:12 PM   #4623
Jake,
There is a third link regarding setups.
Arn0 is offline   Reply With Quote
Old 10-28-2013, 12:37 AM   #4624
Magnet Top's Avatar
Originally Posted by Arn0 View Post
Jake,
edited. My sincere apology for the oversight! FIXED !!!
Jake D.
Old 10-28-2013, 05:18 AM   #4625
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by hanulec View Post
Congrats to Karl Hoffmeister on converting his tq in 17.5 to a win this afternoon at the Halloween classic. Close behind Karl was Mike Gee and Larry Fairtrace in 2nd and 3rd. Overall 5 cars in 17.5 --- the most of any one manufacture.
It was great to meet new racers and see all of the classes with Awesomatix cars in them. Thank you everyone. Should be a great season...
Congrats to Karl. In the tough field that shows up to the classic that was no easy Feat.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
Jerry P is offline   Reply With Quote
Old 10-28-2013, 10:26 AM   #4626
geeunit1014's Avatar
Awesomatix had a great weekend at the Halloween Classic to say the least. TQ + 2nd in VTA, TQ + 1-2-3 in 17.5 TC, 3rd in 13.5 TC and 4th in Mod TC, along with having 5 cars in the show in 17.5 TC. The team was outstanding, im glad to be a part of it.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-28-2013, 11:38 AM   #4627
Nice, but Mod domination is still elusive.... Lots more work to be done....
bertrandsv87 is offline   Reply With Quote
Old 10-28-2013, 12:14 PM   #4628
Magnet Top's Avatar
Congratulations guys. Nice work.
Jake D.
Old 10-28-2013, 06:32 PM   #4629
My congratulations and thanks to the team!
Oleg Babich is offline   Reply With Quote
Old 10-30-2013, 12:47 AM   #4630
How many shims (if any) and on what side are you guys recommending for the metal gear set?
Cheers
Simon
Old 10-30-2013, 12:47 AM   #4631
I have also seen some setups running two metal two plastic gears? Any reason for this?
Old 10-30-2013, 02:40 AM   #4632
It will running smoother, and save some weight!
veloxrc is offline   Reply With Quote
Old 10-30-2013, 02:54 AM   #4633
Thanks for that.
So are you saying the two larger gears are metal and then run two plastic and two metal on the cross bridge. Are you running any shims?
Sorry for all the questions.
Cheers
Simon
Old 10-30-2013, 03:41 AM   #4634
With all metal gears i'm running 2 x 0.1 shims on each side under the bearing.
Hope this helps.
Cheers
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 10-30-2013, 05:08 AM   #4635
hanulec's Avatar
Trader Rating: 23 (100%+)
when running metal gears -- I don't bother to shim. the metal gears work good enough w/o shimming and don't require the exact shimming that the plastic gears need in order to survive.
i've never tried mixing metal/plastic. i mostly run stock -- and i like the confidence the metal gears give me. just one less thing to focus on.
running just two of four gears helps yield a smoother feel with the metal gears. over course you must put thicker fluid in. to me -- 2 gears w/ 5K feels heavier than 4 gears w/ 2K, but lighter than 4 gears w/ 3K
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17198 Today 01:13 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
