Like Tree25Likes
Old 10-17-2013, 05:53 PM   #4546
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Travis S View Post
6mm ride height? Sounds like you are 4x4en Also I understand the ORH on the other 2 setups for droop but you have 5.2mm but then have 6mm ride hight. How does that work?
if your looking at my setup -- i measured the ride height while on hudy setup gauges. 6mm on hudy equaled just a bit over 5mm when running on jacos.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-17-2013, 06:04 PM   #4547
Travis S's Avatar
Trader Rating: 46 (100%+)
OK thanks. That makes more sense now.
BTW I plan on buying a ORCA 21.5 motor and some doodles next weekend. I assume you will have that stuff with you at the Halloween classic? I want to give that motor a shot in USGT.
Travis S is offline   Reply With Quote
Old 10-17-2013, 06:05 PM   #4548
hanulec's Avatar
doodles - got em.
21.5 - sold out a while ago...
Old 10-18-2013, 10:28 AM   #4549
Default My EXL cannot drive straight !
Hello, i need some guidance. I bought my EXL months back and since im done fixing it my car cannot drive straight. I did setup few times but end up with the same results. Anyone experienced this ?
RGKL is offline   Reply With Quote
Old 10-18-2013, 10:43 AM   #4550
syndr0me's Avatar
Trader Rating: 32 (100%+)
Many of you will have seen on Facebook that a certain Atsushi Hara has been busy building a variety of electric touring cars over the past few weeks. Talking to him last week about this he said with no contract to a manufacturer this is a good opportunity to see where everything is at. Having built 5-different cars he said next on his list are Schumacher and Awesomatix.
syndr0me is offline   Reply With Quote
Old 10-18-2013, 12:00 PM   #4551
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
doodles - got em.
I will be at the Halloween race and can bring ORCA motors with me if you need some.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-18-2013, 12:31 PM   #4552
geeunit1014's Avatar
Double check all your alignment, toe, camber, caster. if its not that, check weight distribution, droop, spring preload.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-18-2013, 01:02 PM   #4553
Diff issues ????
bertrandsv87 is offline   Reply With Quote
Old 10-18-2013, 03:26 PM   #4554
Magnet Top's Avatar
I haven't had this issue ...
Too many possibilities . But I'll throw a needle into the haystack of possibilities. Make sure your rear toe links move freely. Sometimes a long stud on rear of top deck protrudes too far and binds up the rear toe ball cup causing all kinds of mischief.
Does your car appear to have equal droop side to side ? Not that that is the cause, but it is a sign something is binding !
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 10-18-2013, 04:45 PM   #4555
Travis S's Avatar
EA
PM Sent
Old 10-18-2013, 08:28 PM   #4556
hanulec's Avatar
the awesomatix family keeps on growing....
hope to see the new member at my local track tomorrow...
Old 10-18-2013, 10:30 PM   #4557
Jake D.
Hi jake, i just realised my gear diff is located on the left instead in the right like in the manual. Is that the case ?
Old 10-19-2013, 11:42 AM   #4558
Magnet Top's Avatar
Make sure that the spool is on the "left" and the diff on the "right".
*If* you installed them both on the same side the effect will be that the front and rear gear train will fight against each other ( spin in opposite directions ). So when you place the car on a surface and try to accelerate it will make horrible noises... that is, until something in the weaker side breaks or the motor smokes. In this scenario, my guess is that the spool gears might have come away from the carrier. If not, re set up your esc and radio so it goes forward now because you have the gear diff on the correct side now.
Old 10-19-2013, 06:41 PM   #4559
Trader Rating: 16 (100%+)
Originally Posted by syndr0me View Post
I will be surprise if he will NOT try it....he was well aware of this car when the team awesomatrix has been racing at TITC since 2010.
I am going to run my AWESOME car this weekend for the 1st time....I hope I will have a good time with it, but I know I have about 2-3 ppl are inline to test try the car so I hope I will get the car back in 1 piece...
Old 10-21-2013, 02:59 AM   #4560
Congratulations for our UK driver Luke Hobson!
Luke won Stock Class at Essex Winter Series 2013-14 Rd1.
Four Awesomatix cars were in A final of Stock.
2013 BTCC Champion Richard King finished 6th in Pro Stock.
http://www.redrc.net/2013/10/essex-w...rt/#more-72833
Oleg Babich is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
