Like Tree21Likes
Old 10-16-2013, 06:51 AM   #4531
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by tqboy View Post
I was looking at setup sheet and have a question about standard spring and s spring. Would it be safe to assume that s spring on sheet is the soft one.
Yes. The soft springs have an "S" on the spring itself.
Travis S is offline   Reply With Quote
Old 10-16-2013, 09:39 AM   #4532
@JayBee
There is no real other effect. Just that the angle of the toe in link will change. You should always adjust the shims so you not change the "bumpsteer" in rear. Also the position of the stud ball from the camber link will be slightly different, but you will not feel any difference here, thats it
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 10-16-2013, 09:53 AM   #4533
blackshark3's Avatar
Is it true that Awesomatix would release a belt drive car? Saw image of that car, but don't know how to post it here...
blackshark3 is offline   Reply With Quote
Old 10-16-2013, 10:17 AM   #4534
hanulec's Avatar
Trader Rating: 27 (100%+)
It is not true. Many pieces/parts might have existed in the past.
The 2014 car will be shaft driven... Overall just an evolution of the current cars.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-16-2013, 10:17 AM   #4535
No, there will ne no belt drive car in the near future! All current existing belt cars are self made, most time by Steen Graversen.
LRP - Awesomatix
Old 10-16-2013, 11:33 AM   #4536
CL
CL's Avatar
Trader Rating: 32 (100%+)
Yeah, I saw one on the For Sale forum.
Awesomatix A700
More racing and less typing!
CL is offline   Reply With Quote
Old 10-16-2013, 02:16 PM   #4537
dizzy1's Avatar
Trader Rating: 24 (100%+)
Freddy,
You mentioned the bumpsteer in the rear, is there a certain way the link should be? So do we want to keep it level if we are adjusting wheelbase? Also what is the norm for the steering link, level as well?
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 10-16-2013, 02:30 PM   #4538
Magnet Top's Avatar
Just shim until rear toe stays constant while you compress the car while on (Hudy style) setup stands.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 10-16-2013, 03:01 PM   #4539
erchn's Avatar
Originally Posted by dizzy1 View Post
Freddy,
Possibly useful, likely not applicable and probably overkill post I sent many moons ago.
Awesomatix EP Touring Car (A700 Shaft Drive)
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 10-16-2013, 03:22 PM   #4540
JayBee's Avatar
Trader Rating: 31 (100%+)
That's a great explanation buddy!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-16-2013, 03:30 PM   #4541
Magnet Top's Avatar
It appears this is for the original kit ( not the L and EX kits )
The inner pickup points for the REAR toe link have changed location in the L/EX kits so the geometry should have changed too.( The inner rear toe link is non adjustable and makes the link length longer than in the original kit. Now the ball stud screws directly in the bulkhead ).
Still, a great reference, not totally applicable but still very useful. Thanks Ethan!
Old 10-16-2013, 04:26 PM   #4542
hanulec's Avatar
IIC setups posted online - http://www.awesomatixusa.com/p/setup-sheets.html
Old 10-17-2013, 04:36 PM   #4543
Jerry P's Avatar
Trader Rating: 44 (100%+)
I'll be trying some of those setups on Saturday and Sunday.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
Jerry P is offline   Reply With Quote
Old 10-17-2013, 04:47 PM   #4544
Travis S's Avatar
Originally Posted by hanulec View Post
6mm ride height? Sounds like you are 4x4en Also I understand the ORH on the other 2 setups for droop but you have 5.2mm but then have 6mm ride hight. How does that work?
Old 10-17-2013, 04:50 PM   #4545
Jerry P's Avatar
Im pretty sure that is the measurement of the arm off of the flat board.
Jerry P
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
