Like Tree13Likes
Old 10-10-2013, 11:29 PM   #4501
hanulec's Avatar
Trader Rating: 27 (100%+)
Rest time. Hitting the reset button for tomorrow. 4 cars in 17.5 with more looking from the outside. 2 cars in 13.5 top 5 - Freddy with the TQ. Freddy's mod car keeps on getting better...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-11-2013, 12:08 AM   #4502
Originally Posted by Oleg Babich View Post
The setups sheets from some our drivers still have the mistakes in the top deck setting indication.
So I have to explain again the main ideas of red dots in the flex settings of our setup sheet ( both for top deck and lower deck also):
#1. The red dot indicates that this point is fixed against any shifting ( lateral and longitudinal). You can provide it by screw or by AT21/AT21S/ST24 ball stud.
#2. ST09 under outer (side) screws/AT21/AT21S/ST24 on the top deck prevents the fixing of this point of top deck and it should be indicated without a red dot according to #1.
(This is due to ST09 are higher than top deck thickness and these outer holes are bigger than ST09 diameter).
#3. ST09 under the central screw on the top deck doesn't prevent the fixing of this central point against the lateral and longitudinal shifting as the central hole has exactly the same diameter as ST09.
So this point should be with red dot even with ST09 installed into this hole (according to #1).
In case of somebody will be able to transform these rules to the more clear and shorter form I will be very grateful.
Then, how can I fix the outer hole of top deck?
Without ST09, the link of top deck will be dislocated easily at every crash.
JW_SHIM is offline   Reply With Quote
Old 10-11-2013, 12:43 AM   #4503
Do not hesitate to tighten the outer screws (or AT21) as much as possible.
Please see for example the popular video from Jilles Groskamp.
On this video Jilles applies a lot of power at tightening of the screws over the top deck.
Oleg Babich is offline   Reply With Quote
Old 10-11-2013, 06:34 AM   #4504
Where do you find the video for Groskamp?
Juan Aveytia is offline   Reply With Quote
Old 10-11-2013, 08:03 AM   #4505
geeunit1014's Avatar
I think he means the series he did with redrc on youtube
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-11-2013, 02:33 PM   #4506
Airwave's Avatar
Originally Posted by bertrandsv87 View Post
There will come a day when 9 out of 10 cars in the top ten will be Awesomatix !!!!
Yeah IIC will probably happen at the same time as a major World Championship again in the future
Airwave is offline   Reply With Quote
Old 10-13-2013, 01:48 AM   #4507
Magnet Top's Avatar
Default IIC
Congrats to the entire team at IIC.
Especially Freddy, coming "across the pond" to race in such unfamiliar conditions and yet doing so well in both classes he entered. Super Stock, TQ and 2nd overall in the "one and done" main format of IIC and also getting into "the show" and maintaing position in Mod TC too. I know I am missing much of the team , but I'l just name off a couple highlights. I believe Kyle Bergstrom had a great showing backing up his strong performance at the Reedy Race in 17.5 TC.
Mike Hanulec also was in a great position to keep his spot in the A but when the track conditions allowed the fastest runs , Q4 , he had his worst luck.
I believe 6 cars were faster than TQ in the "A" sort of the 4th round and many in the "B" sort also beat TQ from Round 3 , showing how deep the field was in 17.5.
As a buddy of mine said, the traction conditions change so much at this race its almost as though qual points need to be used !
Congratulations guys !
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is online now   Reply With Quote
Old 10-13-2013, 03:29 AM   #4508
Jerry P's Avatar
Trader Rating: 44 (100%+)
Wow what a great time in vegas. I Maximum failed in 17.5 tc at the IIC. I wasted a good car by making one too many mistakes especially on 2 amain runs. I ended up starting 5th in the C main and ended up taking 3rd. I also qualified 5 in the A of spec GT and ended up 5th.
I want to thank Awesomatix usa for the awesome support at the IIC. It was also great meeting Freddy, he dealt with our jokes all weekend and joined in on a few!. I'm sure he's taking a few new terms/words back with him to Germany. All in all it was a great time. now time to start thinking about the Halloween classic in ohio. Then the Festivus Grand Prix at Horsham raceway in December.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 10-13-2013, 07:41 PM   #4509
hanulec's Avatar
just got home a while ago from Vegas. all of the Awesomatix runners had a fantastic weekend. we all didn't get the runs we hoped for --- but a TON of folks took notice about the chassis. Awesomatix cars were within every touring A-Main!! It was a fantastic team effort -- no matter if your a "team" driver or not. Big thanks to Freddy Sudhoff for coming from Germany for the event. We really enjoyed making him part of the team this past weekend---
Mod TC - Freddy Sudhoff (7th)
13.5 TC - Freddy Sudhoff (2nd)
17.5 TC - Kyle Klingforth (4th after leading for the first 1/2 of the race) and Kyle Bergstrom (6th)
Amateur 17.5 TC - Ryan Cooper (2nd), Ray Presnall (6th) and Thomas Keiser (10th)
Spec GT - Jerry Perez (5th) and Ray Presnall (9th)
Old 10-13-2013, 08:38 PM   #4510
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Hopefully this a little better for you guys:
IIGQ4U is offline   Reply With Quote
Old 10-14-2013, 09:10 AM   #4511
Travis S's Avatar
Trader Rating: 46 (100%+)
How many from this group are going to the Halloween Classic in a couple weeks? Can someone post the names/screen names of these guys. I met Monti at the USVTA Southern Nationals last month, but that is about all I know so far. Would be nice to be able to put some faces with names.
Travis S is offline   Reply With Quote
Old 10-14-2013, 10:05 AM   #4512
The Teacher's Avatar
Trader Rating: 48 (100%+)
Man what a great weekend of racing at the IIC. Want to thank all of the guys from Awesomatix USA for helping me get my car sorted out. Special thanks to Mike and Jerry for putting up with all my questions. Great fun hanging out with you guys, looking forward to Horsham. Really wish my spur would have held on for the main......sucks starting 6th on the grid in the "A", getting up to 2nd on the first lap and then having the spur go out after a traction roll
The Teacher is offline   Reply With Quote
Old 10-14-2013, 10:27 AM   #4513
Jerry P's Avatar
Motor Screws my Friend motor screws. I'm glad we could help. We tried to make the rounds and make sure everyone driving the awesomatix had what they needed. It was great to see so many cars out in the pits.
The car had lots of look last week so i feel like there may be a few new people rolling out there with the Shaft car.
Jerry P
Old 10-14-2013, 04:09 PM   #4514
dizzy1's Avatar
Trader Rating: 24 (100%+)
Thanks to Mike and the guys for everything this weekend, I know us AZ boys liked seeing the team out in the pits and helping with tips/tricks.
For anyone on the fence, this car is for real!! I've been running HB for over 8 years and finally made the switch a few weeks before IIC. Car was so fast and easy to drive at the same time. And why I watched everyone changing oils and springs thru the rounds taking 30-60 minutes, I'd make a slight change in only a few minutes. Car reacts to the slightest change and so easy to dial in. I finished 3rd in the B-main in 17.5 but if I ran my old HB, I'm sure I would have been struggling to just make the C-main. Looking forward to more time with the new car to see how fast it can go!
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 10-14-2013, 04:15 PM   #4515
hanulec's Avatar
Daniel S
David Z
Ryan C
Ray P
The Mangler
Kyle B
Teacher
Kyle K
Dawson
Brent K
Jerry P
Freddy S
FJ
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
