Old 10-04-2013, 11:31 AM   #4441
The units can't be converted across. Gram-Force/mm is a unit of torque.
malkiy is offline   Reply With Quote
Old 10-04-2013, 11:50 AM   #4442
Huh? grams per millimeter is a wheel spring rate, isn't it? I seem to remember Oleg explaining that he looked at the apring rates and motion ratios of competitive cars to valculate their wheel rates, in order to determine the starting point for the A700. You should be able to go the other way, no?
-Mike
Old 10-04-2013, 12:06 PM   #4443
Gram and lb are a units of weight. Gram-force is a gravitational metric unit of force.
Old 10-04-2013, 02:39 PM   #4444
Please note that gF/mm ( springs rate unit ) is not the same as gFmm ( torque unit).
Oleg Babich is offline   Reply With Quote
Old 10-04-2013, 02:50 PM   #4445
There's also a pounds force, too, though, isn't there? The force exerted by 1 pound at standard gravity. While grams force is the force exerted by 1 gram in standard gravity. Since both include gravity, you can just ignore gravity and compare grams to pounds.
1 gf / mm * 0.001 kg / g * 2.2 lb / kg * 25.4 mm / in = 0.05588 lbf / in
58.6 gf/mm = 3.27 lbf / in
70.9 gf/mm = 3.96 lbf / in
That seems awfully soft for a wheel rate on a TC, though. But I'm not sure what a typical TC motion ratio is.
-Mike
Old 10-04-2013, 03:30 PM   #4446
-Mike
The difference in suspension leverage, on the leaf spring, might have something to do with the lower numbers needed.
Old 10-04-2013, 06:46 PM   #4447
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Hey Grippgoat
You have remember ,there is no shock towers
Mike right .. the suspension leverage ,they are not compression
OVA is offline   Reply With Quote
Old 10-04-2013, 07:07 PM   #4448
OVA
OVA's Avatar
Grippgoat
most of us still learning the suspension stiffness and dampering..
it take a lot of time to get is right setting for every tracks grip condition. just .2mm increment will make a differernce .
Old 10-05-2013, 08:33 AM   #4449
Travis S's Avatar
Trader Rating: 46 (100%+)
Have a couple questions about the Larry and Mike setup sheet and a request for Oleg.
Mike/Larry Setup:
On the top deck there is only 1 screw shown. Is it with or without the screw collars? That leads me to this: Is there a way to add a checkbox next to the top deck that says with collars or something.
For the rear there is 2 holes this ball stud can be mounted in. What one is it? Also can this be added in the pdf.
Oleg: Anyway you can get some wider wheel hexes made for optional parts? Or can you just over engineer a way to make them adjustable! I know you can use shims but there is a limit on how many you can use with some rims.
Awesomatix EP Touring Car (A700 Shaft Drive)-screen-shot-2013-10-05-9.19.22-am.png
Travis S is offline   Reply With Quote
Old 10-05-2013, 08:52 AM   #4450
hanulec's Avatar
Trader Rating: 23 (100%+)
Travis - #1 a single st09/red dot in the center of the top deck front and rear shows a "fixed" top deck design. Four other screws are used - 2 front, 2 rear.
#2 the setup sheet has only one hole. I use the hole that creates the shorter link (nearest to inside of car).
I"be never tested the different holes for the rear toe back to back in attempt to understand their perf impact.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-05-2013, 08:59 AM   #4451
hanulec's Avatar
I don't think it matters to be close to the to 190mm. The wider the car, the less lateral grip you have. If you want to be wide to combat fears of traction rolls, I'd recommend just lowering your roll centers.
if you don't cut your axles (which is crazy to do indoors...) You could always use more and more wheel shims.
Take a look at Gees last two stock setups. There he adds a shim under the am06s. This widens the car -- which can make it easier to drive. His base shock settings are very aggressive so you have to be a "wheel" to hang on to them.
Old 10-05-2013, 09:44 AM   #4452
Travis S's Avatar
Well, this wasn't really for 17.5. It would be a GREAT option to have for USVTA. That may not be a big deal for you guys but it tends to be the class of choice in this area having rather large turnouts and national events. If you run into EA in Vegas ask him how much he liked running USVTA at the southern nationals a few weeks ago.
I doubt this will happen, but I guy can dream can't he and it doesn't hurt to ask.
Is there something that shows the "implied" stuff on the setup sheet. That might stop me from asking so many questions.
Old 10-05-2013, 11:01 AM   #4453
hanulec's Avatar
Petitrc has a break down of setup sheet "translations ". After iic I'll see what we can do to make this more clear. At iic I'm going to make sure to take a pic or two of Freddy setting his droop with gauges.
Old 10-05-2013, 01:23 PM   #4454
Please let me know what popular rims are not suitable for our wheel hexes + shims? Are the using of these rims so important for good race result?
In case of sufficient inquiries we can produce the wider hexes of course.
But I would like to know first:
What is the width limit for USVTA cars?
What is the reason to get the wider USVTA car? Traction rolling issue or anything else?
Old 10-05-2013, 02:05 PM   #4455
Mike/Larry Setup:
For the rear there is 2 holes this ball stud can be mounted in. What one is it? Also can this be added in the pdf......
The setups sheets from some our drivers still have the mistakes in the top deck setting indication.
So I have to explain again the main ideas of red dots in the flex settings of our setup sheet ( both for top deck and lower deck also):
#1. The red dot indicates that this point is fixed against any shifting ( lateral and longitudinal). You can provide it by screw or by AT21/AT21S/ST24 ball stud.
#2. ST09 under outer (side) screws/AT21/AT21S/ST24 on the top deck prevents the fixing of this point of top deck and it should be indicated without a red dot according to #1.
(This is due to ST09 are higher than top deck thickness and these outer holes are bigger than ST09 diameter).
#3. ST09 under the central screw on the top deck doesn't prevent the fixing of this central point against the lateral and longitudinal shifting as the central hole has exactly the same diameter as ST09.
So this point should be with red dot even with ST09 installed into this hole (according to #1).
In case of somebody will be able to transform these rules to the more clear and shorter form I will be very grateful.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 Today 07:05 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17196 Yesterday 01:50 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
SEO by vBSEO 3.5.0
