Old 09-15-2013, 09:18 PM   #4351
bhambrent's Avatar
Thanks man that helps a lot.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 09-15-2013, 09:23 PM   #4352
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Travis S View Post
Most people I see on here are running the A700L USA version for stock and the EXL for Mod.
Here is a post about the spare parts. http://www.rctech.net/forum/9984890-post1002.html
I'd also recommend people take a look at the additional "parts bundles" posted online. These are similar, but different, than the original first aid kits.
http://shop.awesomatixusa.com/awesom...e-bundles.html
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-16-2013, 10:29 AM   #4353
Congrats to Richard King !
Richard is Schumacher BTCC 2013 Champion in 13.5 class!
Awesomatix EP Touring Car (A700 Shaft Drive)-richard-btcc-2013.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-richard-car.jpeg
Oleg Babich is offline   Reply With Quote
Old 09-16-2013, 11:43 AM   #4354
blackshark3's Avatar
Dear Oleg,
Me and my friend together bought two A700EX from my local hobby shop early July, and since day 1 I've asked the hobby shop, who stock no parts for the A700, to order the gear diff upgrades ST23 ST26 and the metal gears. Now two months down the road, all I got are just promises that they would come some day.
During these times one car already ran but the first day it clipped a sidewall, the drive cup popped and the plastic gears shredded. As the parts are not yet arrived, I tried to make shift by using Spec R gears, coupled by your recommended modifications, including adding shims and putting a plastic stick to hold the drive cup. On the second day, the drive cup again popped, this time before the car even finish half the battery. The second car is still in the box, unassembled, just don't want to cannibalize it for parts, and even if we do, the gear just won't last for long anyway.
Frankly I am really disappointed on the gear diff design, it just ruined the whole car design. There was just nothing to hold the drive cup except for that flimsy o-ring, which is inadequate for today's high power motors. Couple with the extraordinary design of the car overall I would expect a more foolproof diff design, maybe with the ST23 and ST26 comes standard, or just make the shaft of the ST07 drive cup longer so that a pin could be used to hold it in place instead of having the ST20. I still remember when the car first ran it was so good, until the gear diff failed, it just ruined the whole experience. I tried things to revive the car, fix the gear diff, short of asking a machine shop to custom made two drive cups that could be pinned.
Anyway, I would be highly appreciated if you could check whether you received any orders from Hong Kong, and if so please ship that out ASAP. If there has been no orders from Hong Kong please pm me, I would have a word with my hobby shop and would order from you direct instead. Its just a shame for the car to sit gathering dust.
Thank you for your attention.
Regards,
Jason
blackshark3 is offline   Reply With Quote
Old 09-16-2013, 12:09 PM   #4355
Talking
Originally Posted by blackshark3 View Post
Dear Oleg,
Regards,
Jason
I think you probably built the diff wrong! The diff is a work of art! Both me and my dad have been running the car for the past two years and have never had a problem with the diffs! And my dad tests the durability of cars alot! Lol
T garnham is offline   Reply With Quote
Old 09-16-2013, 02:08 PM   #4356
....Frankly I am really disappointed on the gear diff design, it just ruined the whole car design. There was just nothing to hold the drive cup except for that flimsy o-ring, which is inadequate for today's high power motors. Couple with the extraordinary design of the car overall I would expect a more foolproof diff design, maybe with the ST23 and ST26 comes standard, or just make the shaft of the ST07 drive cup longer so that a pin could be used to hold it in place instead of having the ST20. I still remember when the car first ran it was so good, until the gear diff failed, it just ruined the whole experience. I tried things to revive the car, fix the gear diff, short of asking a machine shop to custom made two drive cups that could be pinned.
Regards,
Jason
Jason,
Please inform me via PM what Hong Kong shop supplies Awesomatix cars and parts for you now?
Please contact to our official distributor for HK (and Awesomatix Asia Team leader also) Mr. Wen Ping Chiang (Taiwan) to get the direct help and advises for our cars, diffs etc.
Mr Wen supports our Asia drivers a lot now.
You have possibility to order and get the parts from our main webshop (Taiwan based) http://shop.awesomatix.com/ also.
My recommendations for diff:
1. http://www.rctech.net/forum/12475909-post4130.html
2. Put less oil into your diffs. Some volume of air should be inside of the diff to compensate the expansion of the oil at the heating during operation.
Old 09-16-2013, 02:23 PM   #4357
bkspeedo's Avatar
Over filling the gear diff will put pressure on the out drives and possibly cause them to pop out. If you look at the manual and fill the diff per Oleg's instructions you will not have problems. I've had my car now about 6 weeks and have probably ran about 4000 laps. Not once have the out drives popped out and I've had some very high G traction roles.
As for the plastic gears, yes there are some mods that need to be made in order to make them last. Either file the top ST20 that protrudes through the main gear so it's flat with the top of G05 and than places 3-4 .1mm shims between B85 and OR05 to push the gear up.
Or what I've done is just cut small paper shims from card stock that's used as part of the packaging on parts you buy for the car. Cut to the size of the small slots on the G05 gear. I usually put 2 in each slot, approx .5mm. This pushes the main gear up towards the planetary gears so they mesh together better. If done on new gears they should last a long time.
The long term solution is to buy the metal gears.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-16-2013, 11:22 PM   #4358
Congratulations to our Team driver Ahn and his brother!
Ahn won and his brother was 2nd at recent Sweep Challenge Race in Korea.
Awesomatix EP Touring Car (A700 Shaft Drive)-1379241211296.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-1379241211806.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-1379241211955.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-1379241212162.jpg
Old 09-17-2013, 03:22 AM   #4359
Dear Oleg,
Regards,
Jason
Dear Jason
How may I help you and your friend in anyway?
You may contact me through my mail or pm me.
Over filling seems like the cause for diff half to pop out
Here is the step by step how to fill up the diff
1. assemble the diff and fill up the oil (dont worry about over filling at this step)
2. tighten the assembly, leave AT24 face up and not to insert ST07 on this end
3. heat the unit to operating tempeture (around 60' C usually work for me)
4. after the excess fluid comes out from the AT24 then clean it.
5. insert ST07 into the place slowly, more excess fluid may still come out.
6. pull out ST07 and repeat step 5 as needed.
7. Put two orings into ST07 or the trick Oleg mention before.
Now you have a diff complet with proper fluid level, this trick works with all other cars as well.
If you have time you can use vacumm pump that we use for shocks, try to pump the air out before step 4.
I hope this will help you to have more track time before your new parts arrives.
Best regard
Wen
rcpinky is offline   Reply With Quote
Old 09-17-2013, 04:28 AM   #4360
Dear Oleg,
Regards,
Jason
hihi Jason
I am Angus form hk
pls check your pm
boyangus is offline   Reply With Quote
Old 09-17-2013, 04:57 AM   #4361
yokemad's Avatar
Well done Richard !
he is a good racer but also very helpful and friendly person...
A_C
yokemad is offline   Reply With Quote
Old 09-17-2013, 08:43 AM   #4362
Thanks very much everyone for the reply and support. Today I went to the hobby shop and ask again, the owner said he is chasing up my order. Shall see how that goes in a few days and would keep Oleg, Wen and Angus posted. Meanwhile I shall communicate with Wen and Angus by pm. Thanks again for the response!
Old 09-17-2013, 09:13 AM   #4363
Skiddins's Avatar
Can someone please tell me how much a ready to run A700 diff weighs?
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-17-2013, 11:15 AM   #4364
Skiddins
20.5g plastic gears plus bearings
26g with metal gears plus bearings
r king is offline   Reply With Quote
Old 09-17-2013, 11:45 AM   #4365
Hi all,
I just have a short question. Is any 2014 race kit in planning? Ill buy a second Awesomatix in either way,
but if there won't be a new one, ill just buy another L car
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17198 Today 01:13 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
