Like Tree25Likes
Old 08-12-2013, 07:39 PM   #4051
It's going to be done guys, and you will all switch to 3.5t/2.5t motors too, if you're brave .....lol....
bertrandsv87 is offline   Reply With Quote
Old 08-12-2013, 07:43 PM   #4052
See you in a month...
Old 08-13-2013, 04:33 AM   #4053
John Doucakis's Avatar
http://rcracingtv.net/2013/08/tyre-c...r-euros-part1/
John Doucakis is offline   Reply With Quote
Old 08-13-2013, 05:18 AM   #4054
Hey John,
Do you have any information on the new style upper arm mount from the link you posted?
Patrick
XCELL is offline   Reply With Quote
Old 08-13-2013, 06:13 AM   #4055
This is one of our new parts which are still under testing. They are called "flexible caster blocks". They work with a nice design idea and different o-rings for different flex.
Our suspension is pretty hard compared to other cars as we have no pins and no c-hubs. We found out that some additional flex here can be an advantage, specially on asphalt .
More infos later this year as we are still testing different designs and flex settings.
Regards
Freddy
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 08-13-2013, 06:33 AM   #4056
Thanks for the information Freddy, from the look of the design you can set the caster angle and then change the camber without having to adjust anything else. Also have you guys thought of making some new arms from fiberglass or different graphite with with flex characteristics?
Patrick
Old 08-14-2013, 05:12 AM   #4057
hanulec's Avatar
Trader Rating: 27 (100%+)
quick update for you stock carpet racers out there running spec solaris medium/jaco blue. the boys down at Middle River Hobbies have been hitting the rug pretty aggressively this summer. building upon their experience with the car over the summer, there is a new setup from Mike Gee for stock/super stock racing that has proven successful for other awesomatix drivers already. Syndrome tq + win last night at Denver/5280 in their 13.5 touring car class using this setup as documented by Gee.
Please look for the August 10 2013 carpet setup at http://www.awesomatixusa.com/p/setup-sheets.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-14-2013, 08:06 AM   #4058
syndr0me's Avatar
Trader Rating: 32 (100%+)
The car was great with Gee's setup last night. Lots of corner speed in very high grip, and stayed really flat through the turns. The car tends to corner naturally rather than hop through the turns when the grip is high. I couldn't be more impressed.
This setup actually uses 3.5 degrees of rear toe.
syndr0me is offline   Reply With Quote
Old 08-14-2013, 08:37 AM   #4059
hanulec's Avatar
Hopefully other people will try this setup over the next few weeks. The next time i hit the rug ill have my setup look like this for sure.
If what everyone says about 5280 overall grip/car handling/feel is right, then this base setup should work well at IIC...
Old 08-14-2013, 08:56 AM   #4060
so are those standard balls under arms or the at21..and I know this is a crazy question, but why lower the front upper balls compared to the rear balls on the front arm..is that basically making anti dive??
team az is offline   Reply With Quote
Old 08-14-2013, 09:19 AM   #4061
syndr0me's Avatar
I definitely wouldn't hesitate to start there. If I were leaving for IIC right now, that's the setup I would take. Gee did great work. Hopefully he's not laughing at me right now because it's some setup he filled in just to see if anybody would run it.
Reactive caster, I believe.
The Jaco Blue wheels rub ever so slightly with 3mm on the outside, but they grind a groove into the plastic after the first few laps and everything gets free again.
Old 08-14-2013, 09:38 AM   #4062
No cutouts for the topdeck? interesting....
mhavlena is offline   Reply With Quote
Old 08-14-2013, 09:56 AM   #4063
geeunit1014's Avatar
Lol. Not this time, anyway
No, but it does have full ST09 collars to make it floating, so it is softer
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-14-2013, 10:00 AM   #4064
so the standard balls under arms then??
Old 08-14-2013, 10:26 AM   #4065
syndr0me's Avatar
I ran the standard balls under the arms with .5 shims under them.
In my testing, I prefer the collars in all the holes in the top deck so that it "floats." I tried without using a solid top deck and didn't like the car as much. Maybe with some cutouts the fixed deck would work better.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
