Like Tree13Likes
Old 08-08-2013, 03:52 AM   #4006
nutsisneat's Avatar
Hello Oleg
I heard, Raceberry is producing a thin chassis too.
What are your thoughts about that?
Or do you even work toghter in a way with Toni?
Regards
nutsisneat is offline   Reply With Quote
Old 08-08-2013, 03:52 AM   #4007
I don't think u have to add any support to the current car. I have been driving it for more than half year.
The only I ever have boken is my own lap record :d.
At the monent its only Mike Gosvig and I who drive the car. We hope to get atleast som 1 or 2 drivers more during the winter season.
I most the floating spool is very impressiv and really inovativ design, so great work Oleg keep it up.
Cp Grafix is offline   Reply With Quote
Old 08-08-2013, 04:29 AM   #4008
zoomster's Avatar
Default Chassis
Hi
The only problem that i can see with the Raceberry chassis is the big motor cut out on one side of the chassis,surely this would cause different flex from side to side,also i can not see any milling out for the dampener body. Also the price 95 Eur plus postage.
zoomster is offline   Reply With Quote
Old 08-08-2013, 04:41 AM   #4009
Originally Posted by G-rem View Post
Oleg,
could we have some pics or drawings of the new parts? Can't wait to see the 2014 version of the car
Do you plan to make a conversion kit for all current owners of A700L/EXL?
Best regards
G-rem
The LRP EC report plus some more pictures are here:
http://www.lrp.cc/en/news/news/news/...f71702874e84cf
As we plan to produce new parts for 2014 cars so all new parts will be available as the spare parts and all will be suitable for the current cars also.
Oleg Babich is offline   Reply With Quote
Old 08-08-2013, 04:47 AM   #4010
Originally Posted by Oleg Babich View Post
Hi brolÝs,
Do you have any problems with the chassis bumper area strength now? Please let me know.
Our first A700 chassis have had the additional holes under the front gearbox but we have removed them later for increasing of the strength.
L and EX chassis have 2.5mm thikness under bumper already.
We don't have now any reports from the customers concerning the breaking of the chassis near the damper.
BD7 and 417 cars also don't have the additional supports for bumper.
Do you think that we have to add such supports for new car?
Hi Oleg
I have trained with a xray driver here in denmark and he make a little crash but the lower deck was broken in the front. I think if it not will be a problem with the awesomatix is it okay without. I have not a problem with that. My car works really good and keep up all the good thinks you make on the car
best regards
Frederik BrolÝs Mikkelsen
Yokomo bd7 2014 Black Edition - Muchmore - Sanwa
brolÝs is offline   Reply With Quote
Old 08-08-2013, 05:52 AM   #4011
Can anybody explain how to dismount the Spool? I need to clean my bearings and have no clue how to get them out of it
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 08-08-2013, 06:00 AM   #4012
@zoomster
Hi,
The cutouts on the sides of the chassis are for laying down the dampers. It replaces the milling of the std chassis.
Also, the price isn't higher than the price of the std plate
Awesomatix | LRP
Old 08-08-2013, 06:36 AM   #4013
zoomster's Avatar
Hi,Awesoman.
With the dampeners you will find you need the slot in the chassis but the diameter of the barrel part of the dampener with hit the chassis,you will need to raise it about 1mm just like you have to do with the factory 2.25mm chassis,my main problem i see with the Raceberry is the large motor cut out in the chassis,on one side.
Cya
Old 08-08-2013, 06:53 AM   #4014
John.C's Avatar
Trader Rating: 36 (100%+)
Hi brolÝs,
The front bumper area of my "L" lower deck failed on it's 1st run. It split and came apart, the cause of the breakage was user error (I crashed). I also owned the original A700 and never had an issue with the lower deck. I've applied CA to fix it, however, it'll split again if I hit a board hard enough.
BTW, I don't CA any of my CF pieces. It's a risk I'm willing to take to ensure that the pieces fit and flex as designed. I'm just sharing my experience, nothing more.. nothing less.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-08-2013, 08:28 AM   #4015
syndr0me's Avatar
Trader Rating: 32 (100%+)
How much should I fill the gear diff? Mine still seems too tight after many runs with the metal gears.
I'm definitely curious to see how the car feels with a thinner chassis. I think a bumper brace would be a good idea just to be safe.
syndr0me is offline   Reply With Quote
Old 08-08-2013, 10:07 AM   #4016
hana166's Avatar
FWIW I made a 1.9mm baseplate a short while ago, no big cut outs and symmetrical flex. It came out really nice. I shimmed the drivetrain +3mm (2mm over std) to straighten out the driveshafts, and cut off the 5th leg of the bulkheads. Car has been quite consistent and easier to drive but so far no faster over a single lap. And of course I don't know if that's due to the baseplate or the raised drivetrain. But I have still some way to go before I have an outdoor setup for modified with which I am truly confident. Just wanted symmetrical flex to help my OCD about these things, but can't say either way if its better. Nothing wrong with the original plate. Think I'm gonna make a belt conversion for fun to see what its like
hana166 is offline   Reply With Quote
Old 08-08-2013, 10:25 AM   #4017
Where can you get these in the US?
shaftboy is offline   Reply With Quote
Old 08-08-2013, 10:25 AM   #4018
JayBee's Avatar
Trader Rating: 31 (100%+)
Default A700
Hey fellas,
Just pulled my A700 off the shelf and finally doing something with it
Any sources for an VTA/17.5 carpet setup?
Thanks in advance
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-08-2013, 10:34 AM   #4019
syndr0me's Avatar
awesomatixusa.com
Old 08-08-2013, 10:51 AM   #4020
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by JayBee View Post
Hey fellas,
Thanks in advance
Hey JB
For the A700 Go to PetitRC .com
look under Ivan Laptev ETS carpet track I think the date 10.2011
this set up is very easy to drive and more forgiving...
OVA is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 Yesterday 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
