Old 06-03-2013, 06:12 AM   #3571
G-rem's Avatar
Other little questions ;-)
-Why do you use EX chassis plate in stead of L chassis plate? I mean: when do you recommend using EX chassis for stock racers (10.5t/13.5t/17.5t in blinky mode)?
-In which conditions do you recommend using #3 damper? (outdoor/indoor, low/high grip,...). Are those dampers often used by drivers?
Other thing: racers use more often AM18-1 in stead of AM19 (q.v. Viljami or Freddy set-up @ ETS carpet race), is there any particular reason?
Best regards,
G-rem
G-rem is offline   Reply With Quote
Old 06-03-2013, 08:54 AM   #3572
hanulec's Avatar
Trader Rating: 23 (100%+)
Great questions (and my phone lost my first response... So this one will be shorter)
Ex/exl chassis vs l chassis -- I haven't gone back to back with the same setup yet. I suspect it will really be a fine tuning like change. On asphalt I believe the preference will be ex/exl due to rear bite. At the Reedy Kyle ran a A700EXL and Austin and Aaron ran the A700L -- they where the same speed -- fast!
#3 dampeners -- I ran them in Florida at the ROAR Nats. To be fair, I was still figuring out the car and how to tune it back then. In the heat of the sun I couldnt get the car to stop feeling springy. In the morning/evenings the car was really good.. But the change during the hot day wasn't something I could keep up with. The #3 I think will be very good indoors when not hot and outdoors in low grip scenarios.
I'll defer to Oleg or others on why folks are running am18 vs am19.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-03-2013, 09:15 AM   #3573
G-rem's Avatar
Once again, thanks a lot for your help
Old 06-03-2013, 10:28 AM   #3574
Magnet Top's Avatar
Am18-1 vs AM19
AM18-1 doesn't obscure removing the gear diff like AM19 does. ( not a big deal but.... A little less hassle ...,
But AM18-1 does make top deck removal a bit more of a hassle. It just depends on where your upper inner links are attached whether this is a hassle or not.
AM18-1 also allows a few more positions for fine tuning the upper link length.
AM19 allows lower inner upper links ( compared to Am18-1 ) This is nice !
Am19 also is stronger than AM18-1
It also offers a shorter position for inner upper links. ( see picture a few posts back )
My preference is to use AM19 on asphalt more than Carpet. I used Am18-1 on carpet because it gave more finer adjustment and because I tended not to use low inner ball position on carpet.
By the way, AM26 is the other good alternative for shorter upper links to achieve the most camber gain with less chance of ball / cup binding.
Also you can add more shims to the outside of upper links without fear of rubbing the wheels.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 06-03-2013, 10:43 AM   #3575
G-rem's Avatar
Thanks Jake.
And you, what do you think about using the EXL chassis plate in stock category (blinky 10.5t for example)?
Same question for #3 dampers ;-)
Best regards,
G-rem
Old 06-03-2013, 10:59 AM   #3576
Magnet Top's Avatar
Originally Posted by G-rem View Post
Thanks Jake.
Best regards,
G-rem
I really haven't tested the #3 dampers enough to make an opinion. I've been distracted by other things. Hopefully soon...
As far as the EXL vs the L , I think Mike answered it very well. It's a fine tuning thing. It really depends on your driving style. The EX chassis seems to have a little more rear grip but that can translate into less corner speed. The slower the class the L seems to have a slight advantage especially as grip increases.... But as Mike said, it is tough to say without back to back testing which I haven't done.
Also the L is a bit narrower , so there is less chassis rub than the EXL. Tough choice ! I tend to lean towards the EXL but only because I'm focusing more on Mod these days.
But to answer your question directly, it's a tough call but I'd get the EXL for 10.5 blinky.
Jake D.
Old 06-03-2013, 11:50 AM   #3577
G-rem's Avatar
Super cool, thanks for your reply, will try first with the L chassis and then, we'll see ;-)
Old 06-03-2013, 11:55 AM   #3578
I ordered the L chassis as well. Im super excited, should be here like thursday. After watching the cars at reedy and racing with Kyle... yea this is the stock car for sure! The 17.5 guys were running same lap times as the 13.5. Not sure I will know how to build it.. but i cant wait!
WEEZY is offline   Reply With Quote
Old 06-03-2013, 03:24 PM   #3579
Jerry P's Avatar
Trader Rating: 44 (100%+)
Just take your time. Make sure you find a flathead screw driver that is 2.5 mm wide. That makes the build of the axles go a lot smoother.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 06-03-2013, 04:16 PM   #3580
hanulec's Avatar
and this is coming from the 3rd place finisher in 17.5T at the Reedy Race!
Ryan was smart enough to see the advantage. lets see who else is
Old 06-03-2013, 05:07 PM   #3581
Magnet Top's Avatar
Set a pinion gear near the end of the screw driver tip to limit it.
Old 06-03-2013, 07:15 PM   #3582
Anybody switched to ceramic Bearings yet ???
bertrandsv87 is offline   Reply With Quote
Old 06-03-2013, 08:52 PM   #3583
hanulec's Avatar
hope to see a bunch of Awesomatix drivers at IIC this year. Scotty just opened up registrations...
Old 06-05-2013, 12:09 AM   #3584
josecarlo1129's Avatar
Good morning!
I would just like to ask before getting a set of optional parts.
Mike/Oleg,
Do this set-up (which I accidentally saw whilst browsing the web for possible settings) requires the combination of AM19 and AM18-1?
Thanks in advance and cheers to all!
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 06-05-2013, 12:45 AM   #3585
Originally Posted by josecarlo1129 View Post
Good morning!
Mike/Oleg,
JC
This is the classic old A700 on the pictures.
AM19 were the standard kit's parts for holding of the diff and spool that time.
AM18 ( not AM18-1 !) is on the picture also.
Oleg Babich is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17210 02-19-2017 03:16 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
