Like Tree25Likes
Old 05-28-2013, 01:33 AM   #3526
josecarlo1129's Avatar
Look who just got in here.
Thanks Mike, for taking care of my order (from NYc to here). It finally reached Bahrain safely (where I am currently stationed for work). Can't wait for my built then my initial test run at Sakhir International circuit rc-track.
Cheers to my fellow A700 drivers.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 05-28-2013, 02:45 AM   #3527
frank b's Avatar
Great job guys And an excellent race results.. Wished I could of made it this year but i will attended next years race if everything goes according to plan.
RCamerica Xray/ Reedy / Gravity rc / Grip works RC / RCtagz
frank b is offline   Reply With Quote
Old 05-28-2013, 05:44 AM   #3528
Our new option - Spur Damper set:
http://www.redrc.net/2013/05/awesoma...damper-system/
The RedRC info is not full so please see more pictures here.
Spur Damper set consists of:
AT20M Spur Axle M
AT12M Spur Nut M
SH2.7R Rubber Collars
OR09 9mm O-ring
M2x8 Cup Head Screw ( similar to RHS-1 Screw)
All these items are available now.
AT12M spur nut can be used with the standard AT20 also instead of the stock AT12 nut.
AT12M eliminates the 12mm wrench from the pit box.
You can use only 1,5mm hex driver as it no needs to tighten the AT12M nut too much. M2 screw tightening prevents the AT12M nut against the unscrewing.
The additional benefit of AT12M: the increased rotating mass reduces the gyroscopic and spin inertia effect from the motor's rotor.
Oleg Babich is offline   Reply With Quote
Old 05-28-2013, 06:19 AM   #3529
G-rem's Avatar
Added to cart ;-)
G-rem is offline   Reply With Quote
Old 05-28-2013, 06:21 AM   #3530
Oleg,
Did the test drivers feel a noticable difference on the track or did it just reflect in the lap times?
Patrick
XCELL is offline   Reply With Quote
Old 05-28-2013, 07:19 AM   #3531
Originally Posted by XCELL View Post
Oleg,
Patrick
With this spur damper the lap times are more consistent and the car is more easy to drive especially at low grip conditions.
Freddy and Viljami are using it now all times.
Old 05-28-2013, 08:15 AM   #3532
Magnet Top's Avatar
Oleg,
Patrick
I used the spur dampener prior to and at the Reedy race in Mod. It helps soften power delivery and also softens braking. Also I have to believe that it also saves spur gears. So far I've noticed the improvement and am now using it all the time now.
One small note, depending on how tight you secure the spur nut via M2x8 screw it can make the drive shaft removal and insertion slightly more difficult . The solution is easy, just temporarily loosen the M2x8 screw while removing and insertion of the main drive shaft.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 05-28-2013, 08:46 AM   #3533
Would I need the spur dampner system if I run carpet
tqboy is offline   Reply With Quote
Old 05-28-2013, 09:03 AM   #3534
Thanks for the quick reply's, will be placing an order once I get moved.
Patrick
Old 05-28-2013, 09:55 AM   #3535
Magnet Top's Avatar
I used it on carpet too and thought it made a difference there as well. It isn't a "must have" otherwise I believe Oleg would include it in the kit rather than offer it as an option but I will use it going forward as I see it as beneficial.
Just remember that until Awesomatix / Oleg offers a spur gear with the required 5mm holes you will not be able to use it *unless* you modify your own spur gear
**OR** use a small bushing. This would allow normal non modified spur gears to be used with the optional dampener.
The small bushings can be pieces of heat shrink tube or any other plastic tube (ball pen ink holder for example) .
The width of the AT20M pin is 2mm and the standard spur hole is 3mm in diameter. So the tube would need to be ~ 2x3mm caliber.
Jake D.
Last edited by Magnet Top; 05-28-2013 at 11:15 AM. Reason: Added solution for using standard spur gears with AT20M !
Old 05-28-2013, 10:29 AM   #3536
Freddy and Viljami use the spur damper on the carpet also.
I recommend to add a drop of the grease or the heavy silicone oil between the spur and AT20M/OR09 for smoother damping.
Old 05-28-2013, 03:09 PM   #3537
hello Oleg, im from spain, i use to buy parts in switzerland but the shipping is very very expensive, do you know any other distributor?
i want to buy the new spur damper set.
thanks
Christian
osorron is offline   Reply With Quote
Old 05-29-2013, 04:05 AM   #3538
Congratulations for our factory team driver Jung Hyun Ahn !
Ahn won the R-1 GP International Championship (Korea).
Ahn's setup is attached here.
Old 05-29-2013, 10:14 AM   #3539
hana166's Avatar
Cush drive is a very good idea, necessary.
hana166 is offline   Reply With Quote
Old 05-29-2013, 07:08 PM   #3540
hanulec's Avatar
Trader Rating: 27 (100%+)
Reedy Race summary at http://www.awesomatixusa.com/2013/05...-and-wins.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
