Old 05-12-2013, 02:12 PM   #3436
nutsisneat's Avatar
I had my first outing this weekend at the nationals (Pro-Stock 13.5 blinky)
During practice, on used tires, i could almost go the pace of the fastest guys(+0.2-+.3 sec), but with new handout tires, my car had just not enough traction (about 0.6 sec slower).The race was affected by some rain, track dried up, afterwards i was just off the pace (about 0.6 sec slower than leaders). I had .5 shims under rear lower arms and i'm still using AM26. Is AM06S a must have to get the lowest possible roll center, i see it on almost all setup sheets, most often with 0mm under arms. Any other hints? THX
nutsisneat is offline   Reply With Quote
Old 05-12-2013, 03:45 PM   #3437
Originally Posted by nutsisneat View Post
I had my first outing this weekend at the nationals (Pro-Stock 13.5 blinky)......
AM06S + 0mm under arms provide the lowest possible roll center and also the possibility of the increased camber gain at the moderate low roll center.
The additional tip for the further lowering of the roll center - removing (grinding) 0,5mm of material from the foot face of the lower AT21 balls. This tip is indicated as AT21S in the setups ( for example in the latest setup from Dominic Vogl ).
Oleg Babich is offline   Reply With Quote
Old 05-12-2013, 04:00 PM   #3438
nutsisneat's Avatar
@Oleg
Thanks for your quick reply.
So you think i'm working in the right direction to cure the traction issues?
Just double checking...
THX
Old 05-12-2013, 04:50 PM   #3439
hanulec's Avatar
Trader Rating: 23 (100%+)
@Oleg
THX
Lowering the roll center helps.
Other options are trying alternate link lengths and inner/ outer camber link heights
It can depend how the car is (or isnt) rolling..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-12-2013, 08:58 PM   #3440
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Oleg- Does the center driveshaft flex under power or braking? If so, is it a lot? I want to mount my capacitor under it. Doesn't seem like they would touch, but I figured I'd ask.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 05-12-2013, 09:20 PM   #3441
Send a message via AIM to kyle478
I'm curently running my cap right below the shaft. The capacitor is 1-2 mm away from the shaft and it hasn't rubbed at all.
I have run the car with and without am11 and haven't had any rubbing.
Hacker Brushless USA www.hackerbrushless.com
Aero-Model www.aero-model.com
kyle478 is offline   Reply With Quote
Old 05-12-2013, 09:31 PM   #3442
Trader Rating: 15 (100%+)
Default Shaft flex
There's a ball bearing guide that keeps it from flexing to the left and down.
AARON YOUNG is offline   Reply With Quote
Old 05-12-2013, 09:36 PM   #3443
@Oleg
Just double checking... THX
My current point of view: we should keep the inner lower balls of A700 suspension as low as possible as we can easy transform it either to very low roll center or to the additional camber gain.
Old 05-12-2013, 09:50 PM   #3444
Trader Rating: 19 (100%+)
If you run the center driveshaft guide it should prevent deflection. I have not issues of space or rub issues with a ORCA power cap directly mounted under the driveshaft.
MDawson is offline   Reply With Quote
Old 05-13-2013, 12:05 AM   #3445
I figured the guide would keep it from flexing, just wanted to make sure. Thanks guys!
Old 05-13-2013, 05:38 AM   #3446
hanulec's Avatar
And just so everyone is clear -- this requires the "hand making" of the at21s by grinding 0.5mm off the bottom of the at21 balls.
Dawson shared with me his method --
1. Using a long screw, drive the screw through the top of the ball
2. Using a dremel with sanding disk trim the excess metal off the top of the ball from step 1 until appears smooth
3. Measure that balls height using a caliper.
4. With the screw inserted through the new hole at the top of the ball, start grinding the hex bottom of the at21. Continue to measure the ball height to only remove 0.5mm.
5. Always repeat the measurements of step 3 for each ball as their overall heights will be slightly different after breaking through the ball top.
Does anyone have a better method to make a at21s??
Old 05-13-2013, 05:49 AM   #3447
Jerry P's Avatar
Trader Rating: 44 (100%+)
No issue here either. I was running my LRP cap directly under the shaft. With the guide in place there is no way it would hit what's below it unless the shaft actually fell out.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 05-13-2013, 08:35 AM   #3448
hana166's Avatar
That's brilliant. Didn't think of that. I don't have a better way but as I found AT21S out of stock,
I bought a carbide counterbore, used a 3mm drill blank as a guide and set depth stop to deepen the recesses from 0.5mm to 1mm. So I can just carry on using the standard AT21. Just ripped off the wishbones and bulkheads to do the job. Good if you know anyone with access to a workshop as it takes 5 mins to set up and about a minute to do a plate. If I can find the time I might be able to do a handful for others.
hana166 is offline   Reply With Quote
Old 05-13-2013, 09:48 AM   #3449
hanulec's Avatar
Wow - drilling the chassis! Go you! That is an approach, but I rather wreck some at21 balls than a chassis plate.
Old 05-13-2013, 04:24 PM   #3450
Hello, have someone heard about a program called rc crew chief?
osorron is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17198 Today 01:13 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
