Like Tree11Likes
Old 04-20-2013, 06:21 PM   #3361
hanulec's Avatar
Trader Rating: 25 (100%+)
Originally Posted by vadersing View Post
What is the difference between the 3 models of Awesomatix kits?
http://www.awesomatixusa.com/p/kits.html
Also check the Racerlog wiki link in my SIG..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-20-2013, 06:26 PM   #3362
hanulec's Avatar
Originally Posted by hanulec View Post
Just posted - Aaron Young's Asphalt NorCal Hobbies Setup
http://racerlog.com/wiki/Awesomatix_A700#Setups
http://www.awesomatixusa.com/p/setup-sheets.html
note - the setup sheet has been updated. one or two measurements where left off.
AYs shock setup is perfect for 17.5 blinky. Tried it today at middle river in the main outdoors and it helped me be super consistent lap to lap. Would of won if it wasn't for some bad luck.
Old 04-20-2013, 07:07 PM   #3363
KHoff7's Avatar
Thanks to Awesomatix USA kingpin Mike Hanulec for visiting our track today! Very nice to have a distributor who cares about racers.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 04-20-2013, 07:20 PM   #3364
Definitely a cool dude
JOE SI is offline   Reply With Quote
Old 04-21-2013, 05:25 AM   #3365
The Teacher's Avatar
Trader Rating: 47 (100%+)
hanulec, thanks for bringing my package down with you today and coming out to MRH to race
The Teacher is offline   Reply With Quote
Old 04-21-2013, 10:09 AM   #3366
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Awesoman View Post
I'm using Anti Wear Grease from 3Racing and it works quite good.
Do you use the same stuff on the cvds?
Originally Posted by MDawson View Post
Dry bicycle lube works extremely well
Any specific brand? Or are they all good?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-21-2013, 09:28 PM   #3367
No, on the cvd's i use graphite grease from Hudy
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 04-21-2013, 11:23 PM   #3368
Trader Rating: 19 (100%+)
All nearly the same, they apply in liquid form and quickly evaporate to thin dry lube.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 04-22-2013, 04:38 AM   #3369
Trader Rating: 1 (60%+)
awesomatix a700L and full full parts
cico is offline   Reply With Quote
Old 04-23-2013, 08:59 AM   #3370
Good to know. Thanks guys!
Old 04-24-2013, 01:07 PM   #3371
hello, i want to know if someone can tell me how to make the steering less nervous, i feel comfortable with the car but i think the steering is very nervous, i run is asphalt only, and my car is is the EX one with longitudinal motor.
thanks
Christian.
osorron is offline   Reply With Quote
Old 04-24-2013, 01:14 PM   #3372
thanks
Christian.
Can you tell us more about the setup, body, tires and surface?
The most dramatic change you can make that will effect steering that you can A/B test is changing the body. Let us know where you are at.
TEAMORCA.SHOP
Old 04-24-2013, 01:25 PM   #3373
hello, im using protoform mazda speed6, and run in asphalt.
thanks
christian
Old 04-24-2013, 03:35 PM   #3374
geeunit1014's Avatar
Generally, you can try the following:
1. Reduce front toe out
2. Add negative expo on your tx (-10%)
3. Change bumpsteer (less shims under the steering links on both outside and inside)
If we knew more about your setup we may be able to help more
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-24-2013, 03:51 PM   #3375
Magnet Top's Avatar
Also, to make the car less nervous you could try softer spring settings and or softer stabilizer ( anti-roll bars ).
But as others said, I'd try add a bit of expo in the transmitter.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
