Like Tree13Likes
Old 04-10-2013, 01:39 AM   #3331
Well I can follow u, its annoying havning parts like that coming loose.
The only problem I have is that u have to turn the screw from the buttom.
Cp Grafix is offline   Reply With Quote
Old 04-10-2013, 08:06 AM   #3332
Originally Posted by Tof View Post
Hi all,
The plastic piece P06 for droop sometimes comes off when tightening the screw SS3x5. I'm not the first to whom it happens.
Why not make a piece square or hexagonal P06 or slip this piece with P12?
Best regards
Modification of P06 is planned.
Now I recommend to apply the layers of CA on the inner surface of the hole for some decreasing of the inner size of the hole.
After hardening of this preliminary layer of CA please insert P06 and glue it as usual with very thin CA.
Oleg Babich is offline   Reply With Quote
Old 04-10-2013, 09:19 AM   #3333
I found that if you use very thin ca glue that is new you don't have a problem with them coming lose .the second chassis that I done I use the same glue as the first ,but it had been sitting in my garage for a while and didn't run as well.
r king is offline   Reply With Quote
Old 04-10-2013, 09:29 AM   #3334
Company Representative
Trader Rating: 15 (100%+)
I put the PO6 on my Hudy 1.5mm driver... place CA ( thin and fresh) on the PO6 all around it, and then press the PO6 into the chassis... I find using the 1.5 driver lets you press it into the chassis square allowing the CA to set all around the PO6.. I find it easier then putting CA directly onto the chassis then inserting the PO6.
I have also drilled and tapped my arms in the past and had a conventional droop screw orientation..adjustable from the top of the car.. if you measure correctly for the hole(s) adjustment from the top of the car is very easy using droop blocks and a gauge.. and no, I have never broken a arm.
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 04-10-2013, 10:40 AM   #3335
Trader Rating: 22 (100%+)
Hi Korgae -
Can you post a picture of that modification?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 04-10-2013, 12:27 PM   #3336
I saw Frank Bortollzo's car, friend of Korgea's, he had the same droop screw modifications. Looked like a very good idea. If this isn't the preferred method why not get rid of the plastic barrel and just thread a set screw into the chassis. Maybe get a set screw made with deeper threads?
malkiy is offline   Reply With Quote
Old 04-10-2013, 12:34 PM   #3337
i have a chassis that doesn't use the P06 part. Instead, I lined the chassis droop hole with CA to add more material and threaded in a 4x4 or 4x3 mm set screw.
TEAMORCA.SHOP
Old 04-10-2013, 01:02 PM   #3338
Originally Posted by MDawson View Post
Hi Korgae -
I will try to get you some pics, Oleg wants me to post another mod I came up with as well.. so I will try to do both in the next bit here..
Like Malky said, he saw it on Franks car last weekend, it works really good, newer drivers should prob stay with the PO6 for the time being.. as the hole is centered in the arm and if you hit super hard, it could snap a arm, maybe?... I have been using a 3mm long set screw, but V2 will use a smaller 2mm screw.
I have suggested an idea to Oleg about arm design around this as well.
Old 04-10-2013, 01:09 PM   #3339
Default Droop
I did the same as korgae but used a little bigger driver that stretched the po6 a little and haven't had a problem . I like adjusting from the bottom because I don't use blocks and can hold the droop gauge and adjust at the same time.
AARON YOUNG is offline   Reply With Quote
Old 04-10-2013, 01:16 PM   #3340
Pics of droop screws
Old 04-10-2013, 01:34 PM   #3341
You can also see the other mod I do to the AT21's I sand the top of them flat, to expose the setscrew head. I then take a reamer and put a hole in the Kyosho HD ball cups, I get tired of popping off the ball cups all the time, this way you just unscew the assembly without popping the ball cups off. Works good.
Old 04-11-2013, 05:47 AM   #3342
hana166's Avatar
My favourite set up is new car, original bulkheads. Not exactly cost effective but I happened to have a set. Easy wrenching
hana166 is offline   Reply With Quote
Old 04-11-2013, 01:32 PM   #3343
AwesomatixUSA's Avatar
just an fyi - EX, EXL, and L kits are now in stock again at shop.awesomatixusa.com
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
AwesomatixUSA is offline   Reply With Quote
Old 04-17-2013, 03:55 AM   #3344
hanulec's Avatar
Trader Rating: 27 (100%+)
looking forward to running again this weekend on asphalt. i'll be at Middle River Hobbies running on their parking lot track Saturday, and then be at Jackson RC on Sunday. i'm finally strapping in some serious horsepower into my EXL. sound be a fun time.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-17-2013, 05:23 AM   #3345
hana166's Avatar
Default Schumacher Mi5
Seen some of this before..
2pc wishbones and steering arms without proper locators are asking for tweak problems.
But I would like very much a central motor option for A700. Steering rack joined to servo would be good if it hadn't already been designed by Oleg
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 Yesterday 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
