Awesomatix EP Touring Car (A700 Shaft Drive)
#3152
The web store is now live at - shop.awesomatixusa.com
and even made a prettier web page -
http://www.awesomatixusa.com
#3154
Now three.
#3156
im sure its been asked before, but there is a ton of pages to go through and im tired and lazy right now. anyways, is there a video on how this suspension works? the setup is pretty cool looking and id like to see some suspension vids and what not. i thought 800 for a 1/10 when i first saw it then after looking at more pics, this car is so advanced over many onroad cars. totally love this kit!
#3157
+ YouTube Video | |
#3158
thanks for the quick reply. pretty much how i thought it worked from the pics. are they oil filled or is there some hidden technology inside them shocks. amazing design.
#3159
The dampers are oil filled, but you never need to change the fluid. You simply slide the dampers in and out to adjust the damping.
#3160
Hello, i´m also interested in how does this dampers work, could some one explain me how its done, i mean what happens sliding the damper (A) adjust, and what happens sliding the srew (B) adjust.
thanks
Christian
thanks
Christian
#3161
Sliding the damper changes the springs leverage on the damper, and the leverage of the spring rate/ride height screws on the spring. Sliding the damper out (more gap) is more damping and a stiffer spring rate simultaneously. Changing the screws (B) only changes the spring rate.
#3162
Mechanical Advantage FTW!!! Flex your engineering muscles!!
On a serious note... It's nice to finally have a distributor to service and support the NA market. I haven't seen this much interest and activity in some time. I wish all the Awesomatix drivers the very best at the upcoming ROAR Carpet Nats!!
#3163
thanks for your answer, can you explain it to me compared to a conventional shock? spring/oil.
thanks
thanks
#3164
Sliding the damper out would be like putting on a stiffer spring, and putting in thicker shock oil at the same time. Sliding the screws would be changing just the spring. You can use a combination of these 2 to change just the "shock oil". Hope that helps.
#3165
perfectly understood!!!!!!
thanks
Christian.
thanks
Christian.
