Like Tree21Likes
Old 01-31-2013, 12:15 PM   #2986
Hello, today was the first time i ran my awe a700 ex, and have to say is awesome.
i ran it in asphalt and fid that its very easy to drive, of courde i need to find wich is the best setup for that track and conditions, but i`m verry glad with it.
bye
Christian
osorron is offline   Reply With Quote
Old 01-31-2013, 02:31 PM   #2987
Trader Rating: 23 (100%+)
Does anyone have the height of AM26?
Looking for the measurement in mm for the left graphic.
See attached picture.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-31-2013, 03:00 PM   #2988
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
YGPM
OVA is offline   Reply With Quote
Old 01-31-2013, 07:29 PM   #2989
Please...
Oleg Babich is offline   Reply With Quote
Old 01-31-2013, 07:49 PM   #2990
Magnet Top's Avatar
http://www.youtube.com/watch?v=9JSJPCoeQeI
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 01-31-2013, 09:33 PM   #2991
Originally Posted by Oleg Babich View Post
Please...
спасибо
TEAMORCA.SHOP
Old 01-31-2013, 11:08 PM   #2992
Old 02-03-2013, 04:26 AM   #2993
I tested Viljamis setup from ETS and Kuusankoski in this weekend. I didn't have 3 dampers, only 6, I had 10.5 CS and Sweep 28's
The car felt fast and turned really well but In fast corners the rear was little loose for my driving style. I'd spin if I didn't get back to throtlle immediatly after cornering... Actually I have had the same problem every setup with AM26. No drag brake.
Do You have similar problems, or is it only my drivingstyle and /-skill problem...?
markova is offline   Reply With Quote
Old 02-03-2013, 04:31 AM   #2994
The car felt fast and turned really well but In fast corners the rear was little loose for my driving style. I'd spin if I didn't get back to throtlle immediatly after cornering... Actually I have had the same problem every setup with AM26 and short front links. No drag brake.
Old 02-03-2013, 06:30 AM   #2995
try moving the battery on F1 or F2..i think it will help stabilizin' a bit the rear of the car..of course you'll maybe loose a little bit of steerin'...
method699 is offline   Reply With Quote
Old 02-03-2013, 08:16 AM   #2996
hana166's Avatar
I found this to be a trait of the car in general. But there are quite a few things you can do to dial it out I agree very much with method699 about battery position. Spent months experimenting with it, and found out its fundamental to the whole character of the car. Other brands pretty much prevent the user from finding this out by fixing the placement.
I've reached the point where I use 4 scales and measure F-R weight distribution, and run 8-10g more in the rear than the front (without bodyshell). Completely OCD but anywhere outside this margin and I start to run into problems with the car snapping at the rear in fast corners or with pushing in tight corners.
I run position F1 with C01L or R1 with C01(EX) and careful use of ballast.
Also maybe a couple of things to try, take a look at perhaps running the rear RC about 1mm higher than the front (use rcrollcentrev162) and play with the flex.
When I looked at and tried team setups I was left thinking 'These guys are Aliens' - it just gives you an insight into their driving ability to hang onto a car with so much steering
hana166 is offline   Reply With Quote
Old 02-03-2013, 08:57 AM   #2997
frank b's Avatar
Hey Markova
How much rear tow are you running? I usually run 3.5 of rear tow in on my car and sometimes even more and I find it locks the rear end down and also settles the car down. That also depends on your track and how much grip there is on the track. I would try giving rear tow in a try first and I think it will settle down the car for you. Hope it works out for you...
Frank b
RCamerica Xray/ Reedy / Gravity rc / Grip works RC / RCtagz
frank b is offline   Reply With Quote
Old 02-03-2013, 10:51 AM   #2998
Thanks for advice
-3 deg, I'll try more
-I'll try to check weight balance too. How/where do you messure it, F-R? From tires, or where?
-F1 L and R1 EX? Do You have otherwise same car and are L and EX so different?
Old 02-03-2013, 04:17 PM   #2999
Airwave's Avatar
The more I study the new car, the more I understand you worked a lot on the roll centers...
That was the main problem I have to face when I race my A700... This car was so "well-centered" that it was very hard to make it roll...
I can see that the new parts will allow the car to be easier on low-grips tracks...
I'm just disappointed that I bought the first version...
Patience is a virtue...
Airwave is offline   Reply With Quote
Old 02-03-2013, 04:33 PM   #3000
Magnet Top's Avatar
Thanks for advice
Maybe Hana has other reasons for appearance of different weight distribution for either chassis, but its probably only due to the differing BATTERY mounting positions between the EX and L chassis and the reality is that he uses nearly the same battery position on both the EX and L chassis. A picture is worth a thousand words.... ( EX is on the right , and note: the angle of the picture distorts the offset somewhat )
Jake D.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
